#41
"Viperdoc" wrote: Have to agree that "looking" in response to a traffic call is reasonable. Saying "roger" makes it unclear as to whether you actually have the traffic in sight. Both responses are incorrect. "Traffic in sight (the correct response) makes it very clear that you have the traffic in sight. -- Dan C172RG at BFM |
#42
"Jonathan Goodish" wrote: I agree, except for "looking." When ATC calls traffic, you have three choices in my experience: Negative contact, traffic in sight (not "contact"), or looking. If ATC calls traffic, responding with "negative contact" before I have a chance to look is counterproductive. Counterproductive to what? No response while I look is also counterproductive, because the controller has no idea whether I heard the traffic call or not. Responding with "looking" acknowledges the transmission and tells the controller than I don't have the traffic but I'm not blowing it off. Why would the controller presume you are "blowing it off?" After I've had a chance to actually scan for the traffic, I will respond with either "negative contact" or "traffic in sight." Then "looking" was an extra, unnecessary transmission. -- Dan C172RG at BFM |
#43
I usually get dumped off at 5 miles. This happens when I am flying IFR or
VFR and receiving flight following. I fly between two class Cs into a small uncontrolled field, so I get flight following. I can make a position announcement, but it is also recommended that I say my intentions. I don't know my intensions until I know what runway is active. "Robert M. Gary" wrote in message ups.com... Jose wrote: It can be very useful when the freq is quiet. Often times you'll find that if students are in the pattern they only talk when turning. If a student pilot is on downwind, if you don't ask, you probably won't hear him on the radio until he's turning base, possibly in front of you. You should be listening on the frequency for long enough that such students have made several such turns before you are close enough for that to matter. Make your own position report. That should be enough of a prompt for pilots in the area to respond if warranted. That's hard for IFR pilots who often get dumped onto airports as close as 10 miles out. In my plane I'm usually approaching at 170 knots ground speed. Not much time to wait for the next transmission. If the freq is busy I agree with you, however, if the freq is dead it can be helpful. -Robert |
#44
"Bela P. Havasreti" wrote in message ... On Fri, 25 Aug 2006 15:05:57 GMT, Kris Kortokrax wrote: I try to come prepared arriving @ my destination airport and I'll tend to know in advance (with reasonable accuracy) which way the traffic pattern will be. I like to *listen* (miles away) on CTAF to monitor activities at my destination airport before I get there. If there is no activity, I'll try to dial up an AWOS or ATIS at a nearby airport and see what the winds are there (chances are if it's reasonably close by, the winds will be the same). What if your destination has no AWOS or ATIS, and the winds are light and variable? I fly into a small airport that has wind shifts on a regular basis, and does not correlate well with the winds from the class C 30 miles away. It is better to ask when the winds are not obvious. It is a lot safer than flying over the active runway and looking at the wind sock. |
#45
#46
I will admit of having used the "traffic in the area please advice".
However, I think I have a reasonable justification. When ATC drops you off 5 miles from an uncontrolled airport, you are flying a fast airplane, you don't have a lot of time to figure out the other airplanes in the traffic pattern. Someone could have announced a base-to-final turn couple of seconds before you tuned in. If you simply announce "citation xxx 5 mile final" the guy in front of you will assume that you heard his call and may not bother to repeat his call. If you say "traffic in the pattern please advice", that is a clear indication that you just tuned in and you did not hear his previous call. On the other hand, if you did hear his call, you would say "5 mile final, number two". So, there is a time and place where "traffic in the area please advice" has some use. Kris Kortokrax wrote: Just received the following from the FAA Designee Notification system. Checked out the AIM on the FAA web site and the wording is included. Kris -------------------------------------------------------- The inane practice of using the phrase "any traffic please advise" has become so wide spread that the FAA has finally included a "do not do this" in the latest version of the AIM. You will find the following quote at paragraph 4-1-9 G 1 in the latest version of the AIM: Self-announce is a procedure whereby pilots broadcast their position or intended flight activity or ground operation on the designated CTAF. This procedure is used primarily at airports which do not have an FSS on the airport. The self-announce procedure should also be used if a pilot is unable to communicate with the FSS on the designated CTAF. Pilots stating, "Traffic in the area, please advise" is not a recognized Self-Announce Position and/or Intention phrase and should not be used under any condition. If you do not have a current copy of the AIM, you can reference one online at: http://www.faa.gov/ATPUBS/AIM/ Bob Linenweber, ASI 314-890-4864 OPS DESIGNEE NOTIFICATION SYSTEM |
#47
You wait till 5 miles to start listening to unicom in a Citation that
is going fast, by your admission? Does it have 2 coms? Does it have a two man crew? I am listening to Unicom way before ATC lets me go, and that is in a 100 KT spamcan and single pilot. It's not too hard to monitor a second freq. No, that innane traffic call is not justified. On 25 Aug 2006 19:09:14 -0700, "Andrew Sarangan" wrote: I will admit of having used the "traffic in the area please advice". However, I think I have a reasonable justification. When ATC drops you off 5 miles from an uncontrolled airport, you are flying a fast airplane, you don't have a lot of time to figure out the other airplanes in the traffic pattern. Someone could have announced a base-to-final turn couple of seconds before you tuned in. If you simply announce "citation xxx 5 mile final" the guy in front of you will assume that you heard his call and may not bother to repeat his call. If you say "traffic in the pattern please advice", that is a clear indication that you just tuned in and you did not hear his previous call. On the other hand, if you did hear his call, you would say "5 mile final, number two". So, there is a time and place where "traffic in the area please advice" has some use. Kris Kortokrax wrote: Just received the following from the FAA Designee Notification system. Checked out the AIM on the FAA web site and the wording is included. Kris -------------------------------------------------------- The inane practice of using the phrase "any traffic please advise" has become so wide spread that the FAA has finally included a "do not do this" in the latest version of the AIM. You will find the following quote at paragraph 4-1-9 G 1 in the latest version of the AIM: Self-announce is a procedure whereby pilots broadcast their position or intended flight activity or ground operation on the designated CTAF. This procedure is used primarily at airports which do not have an FSS on the airport. The self-announce procedure should also be used if a pilot is unable to communicate with the FSS on the designated CTAF. Pilots stating, "Traffic in the area, please advise" is not a recognized Self-Announce Position and/or Intention phrase and should not be used under any condition. If you do not have a current copy of the AIM, you can reference one online at: http://www.faa.gov/ATPUBS/AIM/ Bob Linenweber, ASI 314-890-4864 OPS DESIGNEE NOTIFICATION SYSTEM |
#48
"Andrew Sarangan" wrote in message oups.com... I will admit of having used the "traffic in the area please advice". However, I think I have a reasonable justification. When ATC drops you off 5 miles from an uncontrolled airport, you are flying a fast airplane, you don't have a lot of time to figure out the other airplanes in the traffic pattern. Why not? What prevented you from monitoring CTAF prior to being "dropped" by ATC? |
#49
I want to complain about those that key the mike and start blabbing
before my squelch opens. Many times they don't announce the airport at the end of their transmissions either so I can only speculate where they are. I used "anybody on the frequency?" for a quiet radio, but maybe I'll quit after this. A good topic to air out. |
#50
Larry Dighera wrote:
I agree with your reasoning, but regulations only instruct the controller to provide the VFR traffic advisory; they don't require the controller to be concerned if you see the traffic or not. That said, it has been my experience, that a controller will make an effort to continue advising the traffic's position (if it is a factor) until the pilot reports "in sight." Everything discussed up to your post applies to IFR traffic advisories as well. However, in the case of IFR traffic advisories, additional instructions are most likely forthcoming the moment the pilot advises traffic in sight, such as "cleared for the visual approach," "maintain visual separation with the traffic, climb and maintain xxx," etc. -- Peter |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
