Any traffic please advise
Old August 26th 06, 11:42 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
Default Any traffic please advise
"Alan Gerber" wrote in message
Nope. They always wait for you to have the traffic in sight before
issuing the clearance. I thought that was standard.
It's not.
  #122
Old August 27th 06, 03:58 AM posted to rec.aviation.piloting
Ron Lee
"Steven P. McNicoll" wrote:
"Ron Lee" wrote in message
I only have one radio.
What fast airplane do you fly?
If I recall correctly, the previous point was that you should be able
to monitor a Unicom frequency while still in contact with ATC.
Aircraft speed is irrelevant.
Ron Lee
  #123
Old August 27th 06, 04:40 AM posted to rec.aviation.piloting
Peter R.
B A R R Y wrote:
On Fri, 25 Aug 2006 22:53:11 -0400, "Peter R."
B A R R Y wrote:
They don't seem to like an instant "negative contact",
How did you deduce this?
Overhearing a controller asking aircraft if they can look for the
target.
Hmmm, a pretty silly deduction on that controller's part, then.
Often in my case I will hear a traffic call to the "other" aircraft first
and begin looking myself, providing me anywhere from a few seconds to 15 or
so seconds to attempt to locate the aircraft before receiving my end of the
traffic call.
My guess and experience to date suggests that a controller being annoyed at
an immediate "negative contact" is a rarity, not the norm.
Peter
  #124
Old August 27th 06, 04:56 AM posted to rec.aviation.piloting
Here is the previous point:
"I will admit of having used the "traffic in the area please advice".
However, I think I have a reasonable justification. When ATC drops you off 5
miles from an uncontrolled airport, you are flying a fast airplane, you
don't have a lot of time to figure out the other airplanes in the traffic
pattern."
  #125
Old August 27th 06, 12:13 PM posted to rec.aviation.piloting
Dan Luke
at
OTOH, sarcastic controller responses to silly phraseology are not such
rarities.
My favorite, in response to "with you":
"N12345, roger; could you go to the break room and get me a coffee?"
  #126
Old August 28th 06, 04:33 AM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
pattern."
Following your advice, today I tried monitoring CTAF 20 miles out while
being vectored for the approach. It was only a Piper Archer, so it was
not fast by any means. 15 miles out ATC clears us for the approach
"Archer XYZ, 10 miles from ABC, maintain... " right then someone makes
a downwind call at some airport. Although the volume was turned down
pretty low, it still distracted us enough to miss the rest of the
clearance. We ended up having to "say again". On the way back we
monitored CTAF again. While ATC was giving us some instruction, some
guy 25 miles away announces that he is taxiing to some runway. We end
up asking for "say again". Before someone says, I am not the type who
is afraid of the radio. I can handle ATC, ATIS and identify navaids
while reading a chart and fly a partial panel NDB approach, really. But
listening to CTAF while talking to ATC has got be stumped.
I would like to add that listening to ATIS or AWOS while talking to
ATC is not the same as listening to CTAF. These are recorded messages
that play at a known speed and rhythm. It is almost like background
noise that you can simply tune out when ATC calls your tailnumber. But
CTAF can be dead quite, but burst into activity right in the middle of
an ATC instruction.
  #127
Old August 28th 06, 06:33 AM posted to rec.aviation.piloting
Roger[_4_]
On 27 Aug 2006 20:33:47 -0700, "Andrew Sarangan"
It only works IF you are monitorning, but if you are talking to ATC
it's interferrence. If in contact with ATC I do not switch to either
the CTAF or UNICOM frequency until I no longer expect to hear from ATC
unless I'm only expecting to hear, "leaving our area". Here,
typically ATC will advise me if they see any traffic in the
neighborhood. IF ATC is busy listening to another frequency can be
hazardous.
As soon as turned loose by ATC I change frequency and anounce my
intentions.
pattern."
With a good many hours I still do not want CTAF interferring with what
ATC is saying.
an ATC instruction.
www.rogerhalstead.com
  #128
Old August 28th 06, 02:07 PM posted to rec.aviation.piloting
Bob Chilcoat
"Any NORDO traffic please advise."
Bob (Chief Pilot, White Knuckle Airways)
  #129
Old August 28th 06, 02:55 PM posted to rec.aviation.piloting
Jose[_1_]
ATC is saying.
Agreed. Tried it both ways. Sometimes I'll make a quick CTAF call many
miles out stating intentions, and then go back to ATC, hoping that when
I'm turned loose on top of the airport, whoever is out there will
remember. I don't know how much good that does though (and just adds to
the CTAF chatter).
Jose
The monkey turns the crank and thinks he's making the music.
  #130
Old August 28th 06, 03:39 PM posted to rec.aviation.piloting
Bela P. Havasreti
On Mon, 28 Aug 2006 09:07:00 -0400, "Bob Chilcoat"
Believe it or not, I've actually heard someone say
that on a local CTAF freq.
Heard another guy @ the same airport (maybe it was the same guy?)
issue "extreme warnings to all pilots in the vicinity of KXYZ airport
that there was a yellow airplane (Cub) not making any
radio transmission while flying around and around in
the pattern".
Bela P. Havasreti
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
