NTSB prelim report out
Old September 10th 06, 04:56 AM posted to rec.aviation.soaring
BTIZ
Default NTSB prelim report out
"Doug Haluza" wrote in message
Paul Buchanan wrote:
I have a question which the report doesn't clarify.
What type of airspace was the glider and bizjet flying
in at the time?
Controlled or VFR?
Paul Buchanan
http://www.glidingstuff.co.nz
Should have been class G. Glider was VFR, Jet was IFR in VMC.
Doug.. wouldn't it be Class E above 14,500MSL?
BT
  #32
Old September 10th 06, 12:28 PM posted to rec.aviation.soaring
Ron Natalie
in at the time?
Controlled or VFR?
Almost certainly IFR as they were descending from positive
control altitudes. It's rare (but not unheard) for bizjets
to not be operating IFR.
  #33
Old September 10th 06, 12:34 PM posted to rec.aviation.soaring
Ron Natalie
BTIZ wrote:
Paul, in the US, it can be "IFR controlled" and "VFR", where VFR aircraft
such as the glider can roam freely in VFR (Visual Flight Rules) or VMC
(Visual Meteorological Conditions) in the same airspace that IFR ATC
controlled traffic can be, the altitudes reported have been 13,500 to 16,500
MSL when they hit.
Actually there is a third category: IFR in uncontrolled airspace.
ATC can not provide control in class G airspace. However, there
is precious little of that in the at any altitude above a few
thousand feet AGL.
  #34
Old September 11th 06, 01:08 AM posted to rec.aviation.soaring
BTIZ
in at the time?
Controlled or VFR?
I'm sure you speak only of the BizJet.. the glider was VFR and not under ATC
control and not required to be under ATC control.
BT
  #35
Old September 11th 06, 02:21 AM posted to rec.aviation.soaring
Greg,
Very interesting indeed. If you have a transponder in your aircraft,
it needs to be ON. FAR91.215.c.(unless I am reading it wrong).. Much
different that not having a transponder, definitely NOT required in
that airspace.
Lucky that no one was killed. I feel sorry for the glider owner
that cared enough about safety to equip his sailplane with a
transponder yet it wasn't used during the flight.
Dean
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
18 Oct 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 19th 05 02:19 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
