Clear coat peeling: Suggestions?
Old December 19th 06, 12:56 AM posted to rec.aviation.owning
Dave Stadt
Default Clear coat peeling: Suggestions?
s.com...
Dave Stadt wrote:
"Kyle Boatright" wrote in message
House of Kolor recommends doing just that. It provides a finish between
a
single and two stage job.
Just curious, is this just for darks or all colors?
-Robert
I only have experience with black for which they recommend up to 50 percent
clear in the last coat for added depth, gloss and color.
Old December 19th 06, 02:55 AM posted to rec.aviation.owning
Mike Noel
Just Curious. Does wax provide enough protection to allow a two stage paint
to hold up reasonably well when the plane is hangared? I used an acrylic
enamel to paint a fiberglass replacement tail strobe fairing and the finish
is glassy despite not having followed up with a clear coat.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Mike wrote:
We had our archer II painted in 1996, including a clearcoat. About 6 -
12 months ago the clear coat started peeling just a little, almost
exclusively on the control surfaces. (They were removed and painted
separately, so it makes sense they behaved slightly differently. Now
though, the clear coat is peeling in quite a few places, especially the
elevator and outer wing. Other the the peeling clearcoat, the paint is
in pretty good shape.
Any suggestions/recommendations for ways to 'fix' the clearcoat without
a relatively complete paint job.?? I'd like to get some good ideas
before talking to a shop.
Thanks!!
Mike Pvt/IFR PA28-181 N44979 at KRYY
I'm in the same boat with my Mooney. Every shop I go to just cringes
when they see that someone put clearcoat in an airplane. Apparently its
common for cars but generally considered quite hill-billy for airplanes
(the proper technique being to mix it in with the paint).
I don't think you'll find any major paint manufacturer that recommends
mixing the clear coat with the color coat. Paint systems are either
single stage (no clear coat) or two stage, in which the second "stage" is
a clear coat.
However, the good news is that after the initial horror of the peeling,
it will start to look much, much better. Once the clear coat is gone
you are left with nice paint.
The clear coat provides UV protection and gloss. On two stage systems, the
color coat doesn't hold up well once the clear peels off.
-Robert
KB
Old December 19th 06, 03:16 AM posted to rec.aviation.owning
Mike
Thanks!!
a clear coat.
House of Kolor recommends doing just that. It provides a finish between a
First, thanks for all the comments/info/suggestions....
I went back in our records to see what kind of paint they used, but it
was not on the workorder or receipt. I think it was to be JetGlow (?).
I seem to remember them saying it was a "all-in-one" product, with
color and clear coats going on at one time, but I can't imagine the
clear peeling like this if it was a "one step".
So the consensus is that there is no easy ("inexpensive") fix and the
only thing to do is strip and repaint...
Oh, the plane is tied down, no hanger, and is located just outside of
Atlanta, so the conditions are pretty harsh... not as bad as Florida,
but pretty tough on paint, I'm sure.
Thanks
Mike
Posted via a free Usenet account from http://www.teranews.com
Old December 19th 06, 04:38 AM posted to rec.aviation.owning
Dave Stadt
"Mike" bellsouth.net@mhammoc wrote in message
6 -
is
without
Thanks!!
is a clear coat.
a single and two stage job.
I went back in our records to see what kind of paint they used, but it was
not on the workorder or receipt. I think it was to be JetGlow (?). I seem
to remember them saying it was a "all-in-one" product, with color and
clear coats going on at one time, but I can't imagine the clear peeling
So the consensus is that there is no easy ("inexpensive") fix and the only
Atlanta, so the conditions are pretty harsh... not as bad as Florida, but
Thanks
Mike
Some paints have very stringent recoat times which if not followed will
cause loss of adhesion. One I am familiar with requires a wait of at least
one hour but no more than three hours. The 2 hour window can be hard to
meet if the paint job is not planned extremely well.
Old December 19th 06, 09:32 PM posted to rec.aviation.owning
Robert M. Gary
Or can you do what I did, ignore it (for me it was just one of the
wingtrip stripes though). About a year later the clearcoat is gone and
it looks great again.
-Robert
Old December 20th 06, 12:23 AM posted to rec.aviation.owning
Robert M. Gary
s.com...
a
-Robert
Ok, that may be true. The shop I was dealing with was looking at a
plane with white paint and clearcoat. The paint manager was just
shaking his head say someone had gone to the "I'll paint any car for
$99.95" guy.
-Robert
Topic Suggestions Wanted for 2006 SSA Convention Bob Gibbons Soaring 7 October 6th 05 07:55 PM
Gel Coat for Dummies Ray Lovinggood Soaring 12 December 24th 04 01:12 AM
Gel Coat for Dummies Ray Lovinggood Soaring 2 December 12th 04 08:15 PM
when does a "remain clear" instruction end? Arden Prinz Piloting 171 March 2nd 04 12:26 AM
Refinishing: Who has tried a shortcut? Ian Forbes Soaring 60 December 26th 03 09:30 AM
