Requesting a hold from ATC for descents
Old January 2nd 07, 10:30 PM posted to rec.aviation.ifr
Mxsmanic
Default Requesting a hold from ATC for descents
Jim Carter writes:
They also employ spoilers and can typically come down very quickly. Give
a more precise example of "becomes impossible to respect your descent
schedule" please.
I've tried spoilers and they don't always help enough.
I'm talking about the FMS disconnecting with a message like "ALT
UNACHIEVABLE" or something like that, when the deviation from the
expected descent profile gets too large.
Old January 2nd 07, 10:32 PM posted to rec.aviation.ifr
Mxsmanic
Jim Carter writes:
I seem to remember a "keep-em-high" program years ago that kept everyone
as high as possible for as long as possible to preserve fuel and reduce
noice. Could that policy still be in effect for some carriers?
I was thinking the same thing. They may have company policies that
require them to stay as high as possible for as long as possible to
save fuel (noise abatement probably isn't as much of an issue, but it
might still be a factor).
Old January 2nd 07, 11:39 PM posted to rec.aviation.ifr
Newps
The Keep 'em High program was an ATC program to keep aircraft at about
10K until 20 miles from the aiport. That program is no longer in
effect. All airlines have their own policies about this. As well all
modern aircraft can be told when to be at what altitude when and the
computer will handle it.
Old January 3rd 07, 02:11 AM posted to rec.aviation.ifr
Mxsmanic
Newps writes:
What was its purpose?
Old January 3rd 07, 02:35 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
Never happens. Like the other gentleman says, the spoilers (actually
speed brakes when used in flight) are the "ace in the hole."
I've tried spoilers, but they aren't always sufficient to please the
FMC. Now I go through every leg of the route checking for
unreasonable-looking descents (or, theoretically, climbs, although the
FMC seems to calculate those more reliably).
In the 727 we didn't have any FMC to keep happy. We actually had to
figure it all out by ourselves.
Old January 3rd 07, 02:37 AM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Newps writes:
It was eons ago. Primarly to keep the noise in near the airport. It
was when the majority of airline jets made much more noise then the
Stage III birds today.
Old January 3rd 07, 02:38 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Newps wrote:
Scott Skylane wrote:
Never say never I have asked for, and received a turn in the hold
to lose altitude, after arriving at the final fix about 10,000 feet
high. This was due to descent restrictions from center because of
other approaches in progress. The flight spoilers on a 727 are *very*
effective, but they can't perform miracles!
You also must also factor in pilot incompetence. I can't begin to tell
you how many times these jet pilots, almost always from the majors like
NWA and UAL as well as from the regionals like Skywest, report on the
freq 35 miles out at FL230 or higher. This is not centers fault as the
descent clearance was given about 200 miles out. Center usually gives a
PD descent and these guys continually foul it up. So to illuminate your
mistake I will drive you right at the airport and make you beg for mercy.
But, for every "incompetent" pilot from NWA and UAL how many do it so
smoothly you actually think they might know what they are doing?
Old January 3rd 07, 03:14 AM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Tuesday, January 02, 2007 7:37 PM
Posted To: rec.aviation.ifr
Conversation: Requesting a hold from ATC for descents
Subject: Requesting a hold from ATC for descents
It was eons ago...
Hey! I resemble that remark!
Old January 3rd 07, 03:21 AM posted to rec.aviation.ifr
Newps
The primary purpose was fuel efficiency.
Old January 3rd 07, 03:22 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
10% of the crews have this problem.
Requesting a hold from ATC for descents Mxsmanic Piloting 10 January 3rd 07 03:31 AM
Different categories of ILS hold short lines at large airports Peter R. Piloting 3 March 6th 06 09:08 PM
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 05:47 AM
S-TEC 60-2 requires re-trim after altitude hold? Peter R. Owning 7 March 2nd 04 04:46 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 04:19 PM
