Can anyone give me some ideas for temporary, but securable weight
ballasts? The situation is we're preparing for FAA required test flights on our FIRST production aircraft. Weight will most likely need to be positioned in the right seat area, and/or in the limited baggage area behind the two seats. Wing bladders are not an option, nor is anything requiring a permanent mount. A non-U.S. built model of this aircraft has already been certified for U.S. flight. This is the first built here; but is not a prototype or "test model". This aircraft will be sold to a private buyer once it passes flight tests. This is the reason for the ballasts needing to be "non-invasive". I was thinking of something that could be bolted to the right seat mounts and/or strap secured in the baggage compartment. Any suggestions or sources? Thanks, DocS |
Any suggestions or sources? One, three, or five gallon water jugs filled with sand, lead shot, or water. You might even be able to borrow (buy or rent) lead shot bags from a scuba diving shop. They could be easily secured in a small duffel. - Carl - |
wrote in message ups.com... Any suggestions or sources? I assume that you need something less than 200# in the front seat. It would be nice if you could find a container about the diameter of a human torso (trash can?), fill it with heavy "stuff" and strap it in place right on the seat to avoid building something special. If necessary, remove the seat cushions to make more room and use just the seat frame. Borrow some scrap lead from a tire shop? It it possible to strap a suitcase in the luggage area? Use your imagination! I once made a glider seat ballast by sewing $20.00 worth of penny rolls into an old pillow case. Vaughn |
How about 1 to 3 sandbags depending on your requirement. They don't take
lunch breaks and no workers comp claims. If you are good with a sewing machine you can sew up a human shaped torso and limbs from 1000D Cordura and pour the sand into it. Make in the anatomically correct female form and call her (it) Sandy. wrote in message ups.com... Can anyone give me some ideas for temporary, but securable weight ballasts? The situation is we're preparing for FAA required test flights on our FIRST production aircraft. Weight will most likely need to be positioned in the right seat area, and/or in the limited baggage area behind the two seats. Wing bladders are not an option, nor is anything requiring a permanent mount. A non-U.S. built model of this aircraft has already been certified for U.S. flight. This is the first built here; but is not a prototype or "test model". This aircraft will be sold to a private buyer once it passes flight tests. This is the reason for the ballasts needing to be "non-invasive". I was thinking of something that could be bolted to the right seat mounts and/or strap secured in the baggage compartment. Any suggestions or sources? Thanks, DocS |
Fine lead shot can be bought - sometimes borrowed from a good gun suplier.
the bags are small, about the size of a standard red brick, well packaged/secured, and weigh 20 lbs each. Stuffed into a army issue canvass duffle bag, the type with the hook NOT the zipper, then lashed down, should be about as secure as you will get, and you don't have to move 200 lbs at one time. wrote in message ups.com... Can anyone give me some ideas for temporary, but securable weight ballasts? The situation is we're preparing for FAA required test flights on our FIRST production aircraft. Weight will most likely need to be positioned in the right seat area, and/or in the limited baggage area behind the two seats. Wing bladders are not an option, nor is anything requiring a permanent mount. A non-U.S. built model of this aircraft has already been certified for U.S. flight. This is the first built here; but is not a prototype or "test model". This aircraft will be sold to a private buyer once it passes flight tests. This is the reason for the ballasts needing to be "non-invasive". I was thinking of something that could be bolted to the right seat mounts and/or strap secured in the baggage compartment. Any suggestions or sources? Thanks, DocS |
On Jan 29, 7:08?pm, Ernest Christley wrote:
wrote: Can anyone give me some ideas for temporary, but securable weight ballasts? Ever heard of Tubesand? Nothing more than a 60lb. sandbag that's about 8" dia. and about 30" long. They're made by Quickcrete and sell for about $3 each at the local BOX store. Availability is regional though, since they're intended as ballast for us 2WD truck drivers. Harry |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| flying low...military video | gatt | Piloting | 60 | January 8th 07 02:43 AM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
