			 "Sylvain" wrote in message ... snip In the case you describe, you have a US PPL, you were flying a whatever registered aircraft, I imagine a single engine land for which you are rated on your US certificate, and were (I presume) the sole manipulator of the controls: as far as the FAA is concerned, you log this flight as PIC, whether there was an instructor on board or not and regardless of the registration of the aircraft; The proper authority for flight operations in Canada is the CARs, which are the Canadian equivalent of the US FARs. The CARs are available on line http://www.tc.gc.ca/civilaviation/re.../cars/menu.htm but are hard to navigate and it is often difficult to find the proper section. IIRC and AFAIK, You must have a Canadian licence or permit in order to ACT as PIC of a C-registered aircraft, and similarly you must have a US certificate or ??? to ACT as PIC of an N registered aircraft. see CARs 401.03(1) http://www.tc.gc.ca/CivilAviation/Re...401.htm#401_03 see also CARs 401.07(1) on the same page. The holder of (only) a Canadian licence or permit is NOT permitted to act as PIC of any non C-registered aircraft, see CARs 401.04 The validation of foreign licences is covered in CARs 421.07 http://www.tc.gc.ca/CivilAviation/Re...ndards/421.htm and see also CARs Division VI 421.26 (6) (b) Transport Canada (TC) does not use the 'sole manipulator of the controls' terminology, so while you MAY be able to log this flight as PIC for FAA purposes, you would not be able to ACT as PIC (or fly solo) or claim the time as PIC for Transport Canada purposes. If the person ACTING as PIC is a TC certified instructor then you could log the time as dual instruction received but if the person ACTING as PIC is not a CFI then you could not claim dual and would be considered to be acting as a passenger even if you were the sole manipulator. Strictly speaking, an instructors certificate is not required to give instruction for a float endorsement (IIRC, Some ATPL or CPL with the proper type and class ratings may give instruction for type and class to properly (Canadian) licenced pilots, who may claim flight as either PIC and/or dual instruction received) see CARs Division III 425.21 (6) & (7) http://www.tc.gc.ca/CivilAviation/Re...425.htm#425_21 Many (most?) float plane instruction is not given by CFI instructors. There is a requirement for some solo time (Canadian Licence or permit required) and TO/landing cycles, see CARs Division X 421.38 (1) http://www.tc.gc.ca/CivilAviation/Re...s/421.htmAFAIK it is not difficult or expensive ($25?) to obtain a Canadianvalidation of a US airman's certificate and does not require a Canadianmedical (there are some conditions). I have been told that this validationprocess is much easier for USCanadian than for CanadianUS (since 911) andthat today it is almost impossible to obtain a US validation for a CanadianCPL, at one time these validations were permanent (subject to validity oforiginal licence) but now are issued for a 5? year term. YMMVGood luck & Happy landings,  |
On Mar 16, 8:01 am, "Ol Shy & Bashful"  wrote:
	Different kind of situation perhaps because I needed to get the Canada Commercial pilot rating some 10 years ago. I had to take a Canada medical, pass the Commercial pilot written (which was not nearly as easy as the tests in the USA) and do some required dual instruction prior to the check ride. The flying part was relatively easy. fyi, a very recent bilateral agreement has made getting a Canadian Commercial based on an FAA one (or vice versa) much easier. Although the agreement took effect in Nov, I understand that details on how it is done are just filtering through the FSDOs and their Canadian equivalents now. Under the new rules, all that is required to get an unrestricted Commercial in the other country is a medical for the other country, passing a written Regs test for the other country and showing them your license, etc. (This bilateral agreement also applies to instrument ratings.) I'm thinking of getting an FAA Commercial, since it is now easy for me to do. It has always been pretty easy to get a restricted PPL for the other country (restricted means that it is only valid when your other PPL is valid). For that, I believe Transport Canada wants to see your foreign license, a valid medical (can be an FAA one), proof of citizenship and then you need to pass a little written test called the PSTAR (the student pre-solo regs test here in Can). Enjoy flying around Montreal. The French on the radio can sometimes be confusing, but it's not too bad, rick ps: As for logging, Transport Canada only recognizes PIC time logged when you are Acting PIC, but I don't see why that would affect how the FAA interprets it. I also believe that somewhere in the FARs there is info about receiving instruction from an instructor in other ICAO states. It cannot be counted towards the time required for an FAA certificate from a CFI, but can be counted towards total flight time, I believe.  |
Canada is a signatory so your USA medical should be valid.
	INSTRUCTION RECEIVED from a licensed instructor in a signatory nation applies and any time you fly counts as experience, See Part 61. CANADIAN FLIGHT Rules are quite different as to required flight plans, altitudes and emergency equipment. Be sure to follow their rules when north of the border. "Austin Gosling" wrote in message ... | Hi all. I've been reading this group for a while, but this is my first | post here. | | I have a US PPL, and I travel to Montreal frequently on business. I went | over to the Montreal Flying Club at St. Hubert last week to see about | flying in Canada. Evidently, under reciprocal agreements, I can easily | get a Canadian license. Basically all I need are a Canadian medical and | a short written test. | | While I was there, I made a short flight up the St. Lawrence with one of | their instructors. I did all the flying, but I have logged it as dual, | but of course the tail number is a "C-....". The question is, what are | the rules regarding the time logged under a foreign license? Can it be | applied for requirements for advanced ratings on the US side? Or does | time in a "C-...." only apply for Canadian ratings? | | Also, if I were to get a Canadian license, then a seaplane rating on it, | for example, would the seaplane rating apply for my US license? Can I | get both upgraded at the same time? | | By the way, if you are ever in Montreal, I can highly recommend a stop | by the Montreal Flying Club at St. Hubert airport on the south shore. | Very nice folks and very well maintained aircraft. Also a very nice | little airport. | | Regards, | Austin  |
			 "Private" wrote in message news:4hAKh.25107$DN.14161@pd7urf2no... "Sylvain" wrote in message ... snip In the case you describe, you have a US PPL, you were flying a whatever registered aircraft, I imagine a single engine land for which you are rated on your US certificate, and were (I presume) the sole manipulator of the controls: as far as the FAA is concerned, you log this flight as PIC, whether there was an instructor on board or not and regardless of the registration of the aircraft; The proper authority for flight operations in Canada is the CARs, which are the Canadian equivalent of the US FARs. The CARs are available on line http://www.tc.gc.ca/civilaviation/re.../cars/menu.htm but are hard to navigate and it is often difficult to find the proper section. IIRC and AFAIK, You must have a Canadian licence or permit in order to ACT as PIC of a C-registered aircraft, and similarly you must have a US certificate or ??? to ACT as PIC of an N registered aircraft. see CARs 401.03(1) http://www.tc.gc.ca/CivilAviation/Re...401.htm#401_03 see also CARs 401.07(1) on the same page. The holder of (only) a Canadian licence or permit is NOT permitted to act as PIC of any non C-registered aircraft, see CARs 401.04 The validation of foreign licences is covered in CARs 421.07 http://www.tc.gc.ca/CivilAviation/Re...ndards/421.htm and see also CARs Division VI 421.26 (6) (b) Transport Canada (TC) does not use the 'sole manipulator of the controls' terminology, so while you MAY be able to log this flight as PIC for FAA purposes, you would not be able to ACT as PIC (or fly solo) or claim the time as PIC for Transport Canada purposes. If the person ACTING as PIC is a TC certified instructor then you could log the time as dual instruction received but if the person ACTING as PIC is not a CFI then you could not claim dual and would be considered to be acting as a passenger even if you were the sole manipulator. Strictly speaking, an instructors certificate is not required to give instruction for a float endorsement (IIRC, Some ATPL or CPL with the proper type and class ratings may give instruction for type and class to properly (Canadian) licenced pilots, who may claim flight as either PIC and/or dual instruction received) see CARs Division III 425.21 (6) & (7) http://www.tc.gc.ca/CivilAviation/Re...425.htm#425_21 Many (most?) float plane instruction is not given by CFI instructors. There is a requirement for some solo time (Canadian Licence or permit required) and TO/landing cycles, see CARs Division X 421.38 (1) http://www.tc.gc.ca/CivilAviation/Re...ndards/421.htm opps AFAIK it is not difficult or expensive ($25?) to obtain a Canadianvalidation of a US airman's certificate and does not require a Canadian medical (there are some conditions). I have been told that this validationprocess is much easier for USCanadian than for CanadianUS (since 911) and that today it is almost impossible to obtain a US validation for a CanadianCPL, at one time these validations were permanent (subject to validity oforiginal licence) but now are issued for a 5? year term. YMMV Good luck & Happy landings, I note that Macklem has more current information below in this thread. Is there a link to an announcement and application information? TIA  |
"TheSmokingGnu"  wrote in message
	... However, I believe FAR 91.75 (c) states that ratings earned on a foreign license may be placed on your US license (while not specifying if testing is necessary; only in reference "additional ratings"). So, if you earn a rating on a Canadian PPL, it should be applicable over here as well. Going the other way, Brits and others regularly take their edumacation and ratings in the US.  |
On 2007-03-16 00:27:03 -0700, Austin Gosling  said:
	Hi all. I've been reading this group for a while, but this is my first post here. I have a US PPL, and I travel to Montreal frequently on business. I went over to the Montreal Flying Club at St. Hubert last week to see about flying in Canada. Evidently, under reciprocal agreements, I can easily get a Canadian license. Basically all I need are a Canadian medical and a short written test. While I was there, I made a short flight up the St. Lawrence with one of their instructors. I did all the flying, but I have logged it as dual, but of course the tail number is a "C-....". The question is, what are the rules regarding the time logged under a foreign license? Can it be applied for requirements for advanced ratings on the US side? Or does time in a "C-...." only apply for Canadian ratings? Also, if I were to get a Canadian license, then a seaplane rating on it, for example, would the seaplane rating apply for my US license? Can I get both upgraded at the same time? By the way, if you are ever in Montreal, I can highly recommend a stop by the Montreal Flying Club at St. Hubert airport on the south shore. Very nice folks and very well maintained aircraft. Also a very nice little airport. Regards, Austin You need to arise about two in the morning and get your gear set up so that you can begin at first light. Be sure that you knock off by noon or the forest will be too dry and present a fire hazard. Oh, you meant a different kind of logging... If you get the seaplane rating on your Canadian license, you just go to an American FSDO and apply for a new certificate. The reciprocal agreements apply both ways. The time you fly in a Candadian aircraft applies for advanced ratings in the US. Further questions probably should be directed to the FSDO as to the actual mechanics of it. -- Waddling Eagle World Famous Flight Instructor  |
C J Campbell wrote:
	On 2007-03-16 00:27:03 -0700, Austin Gosling said: Hi all. I've been reading this group for a while, but this is my first post here. I have a US PPL, and I travel to Montreal frequently on business. I went over to the Montreal Flying Club at St. Hubert last week to see about flying in Canada. Evidently, under reciprocal agreements, I can easily get a Canadian license. Basically all I need are a Canadian medical and a short written test. While I was there, I made a short flight up the St. Lawrence with one of their instructors. I did all the flying, but I have logged it as dual, but of course the tail number is a "C-....". The question is, what are the rules regarding the time logged under a foreign license? Can it be applied for requirements for advanced ratings on the US side? Or does time in a "C-...." only apply for Canadian ratings? Also, if I were to get a Canadian license, then a seaplane rating on it, for example, would the seaplane rating apply for my US license? Can I get both upgraded at the same time? By the way, if you are ever in Montreal, I can highly recommend a stop by the Montreal Flying Club at St. Hubert airport on the south shore. Very nice folks and very well maintained aircraft. Also a very nice little airport. Regards, Austin You need to arise about two in the morning and get your gear set up so that you can begin at first light. Be sure that you knock off by noon or the forest will be too dry and present a fire hazard. Oh, you meant a different kind of logging... If you get the seaplane rating on your Canadian license, you just go to an American FSDO and apply for a new certificate. The reciprocal agreements apply both ways. The time you fly in a Candadian aircraft applies for advanced ratings in the US. Further questions probably should be directed to the FSDO as to the actual mechanics of it. I'm a lumberjack, and I'm OK, I work all night and I sleep all day ... Oh, not that kind of logging ![]() Thanks for the info.  |
A certificate [license] issued on the basis of a US
	certificate in Canada would have the same ratings that are on the certificate you hold. It cannot be amended. It will probably be limited to non-commercial operations [if based on a commercial]. You can get a full license in the USA or Canada, using experience from one or both countries and that license can be amended only by a Form 8710, instructor sign off and flight test. But the hours and such can be counted. For example, if you have a US CP ASEL and go to Canada, they can issue a license based on the commercial you hold with those same rating and it will probably have the limitation --Private privileges only--. If you want a seaplane rating, you need to get a complete issue of a Canadian license or take your flight test from a USA CFI [who could be in Canada]. Once your base license is amended, you can get a new --based on-- license with the new ratings. Canada can't amend a USA certificate and the USA can't amend a Canadian certificate. "Austin Gosling" wrote in message ... |C J Campbell wrote: | On 2007-03-16 00:27:03 -0700, Austin Gosling | said: | | Hi all. I've been reading this group for a while, but this is my first | post here. | | I have a US PPL, and I travel to Montreal frequently on business. I | went over to the Montreal Flying Club at St. Hubert last week to see | about flying in Canada. Evidently, under reciprocal agreements, I can | easily get a Canadian license. Basically all I need are a Canadian | medical and a short written test. | | While I was there, I made a short flight up the St. Lawrence with one | of their instructors. I did all the flying, but I have logged it as | dual, but of course the tail number is a "C-....". The question is, | what are the rules regarding the time logged under a foreign license? | Can it be applied for requirements for advanced ratings on the US | side? Or does time in a "C-...." only apply for Canadian ratings? | | Also, if I were to get a Canadian license, then a seaplane rating on | it, for example, would the seaplane rating apply for my US license? | Can I get both upgraded at the same time? | | By the way, if you are ever in Montreal, I can highly recommend a stop | by the Montreal Flying Club at St. Hubert airport on the south shore. | Very nice folks and very well maintained aircraft. Also a very nice | little airport. | | Regards, | Austin | | You need to arise about two in the morning and get your gear set up so | that you can begin at first light. Be sure that you knock off by noon or | the forest will be too dry and present a fire hazard. | | Oh, you meant a different kind of logging... | | If you get the seaplane rating on your Canadian license, you just go to | an American FSDO and apply for a new certificate. The reciprocal | agreements apply both ways. The time you fly in a Candadian aircraft | applies for advanced ratings in the US. | | Further questions probably should be directed to the FSDO as to the | actual mechanics of it. | | I'm a lumberjack, and I'm OK, I work all night and I sleep all day ... | Oh, not that kind of logging ![]() | | Thanks for the info.  |
On Mar 16, 2:22 pm, "
	wrote: On Mar 16, 8:01 am, "Ol Shy & Bashful" wrote: Different kind of situation perhaps because I needed to get the Canada Commercial pilot rating some 10 years ago. I had to take a Canada medical, pass the Commercial pilot written (which was not nearly as easy as the tests in the USA) and do some required dual instruction prior to the check ride. The flying part was relatively easy. fyi, a very recent bilateral agreement has made getting a Canadian Commercial based on an FAA one (or vice versa) much easier. Although the agreement took effect in Nov, I understand that details on how it is done are just filtering through the FSDOs and their Canadian equivalents now. Under the new rules, all that is required to get an unrestricted Commercial in the other country is a medical for the other country, passing a written Regs test for the other country and showing them your license, etc. (This bilateral agreement also applies to instrument ratings.) I'm thinking of getting an FAA Commercial, since it is now easy for me to do. It has always been pretty easy to get a restricted PPL for the other country (restricted means that it is only valid when your other PPL is valid). For that, I believe Transport Canada wants to see your foreign license, a valid medical (can be an FAA one), proof of citizenship and then you need to pass a little written test called the PSTAR (the student pre-solo regs test here in Can). Enjoy flying around Montreal. The French on the radio can sometimes be confusing, but it's not too bad, rick ps: As for logging, Transport Canada only recognizes PIC time logged when you are Acting PIC, but I don't see why that would affect how the FAA interprets it. I also believe that somewhere in the FARs there is info about receiving instruction from an instructor in other ICAO states. It cannot be counted towards the time required for an FAA certificate from a CFI, but can be counted towards total flight time, I believe. Is the same true for rotorcraft? In '94 when I got my TC Commercial #408XXX the law was the rotorcraft was a completely different seperate license. I wonder if that is still the same? Cheers Ehh OS&B  |
| PIC logging question | Roger Worden | Soaring | 1 | January 8th 07 07:48 AM |
| IFR logging question - is this legal? | Brad | General Aviation | 46 | July 10th 06 11:47 PM |
| IFR logging question - is this legal? | Brad | Instrument Flight Rules | 51 | July 10th 06 11:47 PM |
| Logging Approach Question | Gerald Sylvester | Instrument Flight Rules | 41 | September 23rd 05 01:31 PM |
| Time logging question... | hellothere.adelphia.net | Rotorcraft | 1 | September 3rd 04 01:04 AM |
