IFR logging question - is this legal?
Old June 30th 06, 04:00 PM posted to rec.aviation.ifr,rec.aviation.misc
Default IFR logging question - is this legal?
Peter wrote:
Hi All,
This is for an N-reg aircraft.
Aircraft: a standard piston single.
P1 seat: a pilot legal to be PIC under VFR.
P2 seat: a pilot legal to be PIC under IFR (but no CFI/CFII rating).
No money changes hands.
Irrelevant to logging time
Let's say one does an IFR flight.
Obviously the one in the P2 seat has to be PIC, to keep it legal.
Can the P1 pilot log anything at all and, if so, what can he log?
I presume P1 is sole manipulator of the controls
Now, is the situation any different if the aircraft is owned by the P2
person and rented to the P1 person?
I know about the 100-hr check stuff; 91.409: "...no person may operate
an aircraft carrying any person (other than a crewmember) for hire,
and no person may give flight instruction for hire in an aircraft
which that person provides, unless within the preceding 100 hours of
time in service the aircraft has received an annual or 100-hour
inspection...
and this suggests that a 100hr check is NOT required (nobody being
carried for hire, and nobody doing instructing).
correct
Thank you for any comments.
Can the P1 also log it? I'd hope so!
Only if P1 is sole manipulator of the controls, rated for the category
and class of airplane, and using a view limiting device (91.109) that
would require a second crew member. That second crew member of course
would need to act as PIC. Without a view limiting device, two pilots
are not necessary. P1 would be acting as an organic autopilot. The
regs make no distinction between VMC versus IMC or IFR versus VFR for
the purposes of logging time.
Old June 30th 06, 05:26 PM posted to rec.aviation.ifr,rec.aviation.misc
Brad[_1_]
Correct.
This isn't necessary for *P1* to log it. He's sole
manipulator.
are not necessary.
Irrelevant as to P1's right to log.
Except that he's asking if they can both log it. Quote: "Can the P1
also log it? I'd hope so!"
They can't BOTH log PIC time.
Old June 30th 06, 09:17 PM posted to rec.aviation.ifr,rec.aviation.misc
Robert M. Gary
Actually they can if P1 is under the hood and flying and P2 is acting
as PIC.
-Robert, CFII
Old June 30th 06, 09:18 PM posted to rec.aviation.ifr,rec.aviation.misc
Robert M. Gary
Brad wrote:
The
The safety pilot cannot log time in IMC.
-Robert, CFII
Old June 30th 06, 09:30 PM posted to rec.aviation.ifr,rec.aviation.misc
Dane Spearing
In article .com,
Robert M. Gary wrote:
Brad wrote:
The
Unless the pilot who is manipulating the controls is not instrument rated,
in which case the "safety pilot" must be PIC (and had better be
instrument rated and on an active IFR flight plan).
-- Dane
Old June 30th 06, 10:30 PM posted to rec.aviation.ifr,rec.aviation.misc
Michael Ware
"Peter" wrote in message
The only way to do this under G without P2 being an instructor, would
be in VMC, as a VFR flight, in which case P1 can wear an IFR hood, P2
is a safety pilot (and can't log anything) while P1 can log it all as
instrument time.
Simulated instrument time, not actual.
Old June 30th 06, 11:30 PM posted to rec.aviation.ifr,rec.aviation.misc
Michael[_1_]
Peter wrote:
The Q is whether the flight is legal.
That's a bad question. It implies that FAR's are absolute, like the
laws of physics, or at least interpreted by some reasonably objective
and independent agency, like criminal law. However, that's not how it
is. The FAA interprets its own rules as it sees fit, and the courts
are required to defer to it. There is not even a requirement for
consistency. That's the legal precedent. Thus the only reasonable
question is - if I admit this (such as by logging it) will I get in
trouble. I would say probably not - though there are no guarantees.
Having said that, the flight should be legal because there is no rule
that says it is not. That's how Part 91 ops work. The rules are by
nature permissive - anyhting that is not forbidden is permitted.
P2 would be acting as PIC. P1 would be sole manipulator of the
controls.
Note that logging PIC and being PIC are not the same thing at all.
P1 logs PIC because he is sole manipulator of the controls in an
aircraft for which he is rated. He can't act as PIC.
P2 logs nothing. He is not sole manipulator, and he is not PIC in an
operation where more than one crew member is required.
There is a twist to this that may allow P2 to also log PIC. It won't
work if the weather is solid IMC, but if only a relativelyt small
portion of the flight is spent in IMC and P1 wears a hood, then we can
consider this flight to exist for the purpose of gaining instrument
experience via simulated instrument flight. Now the flight requires
two crew members, and P2 has to be PIC, so he can log it. It is not
true that he can only log the time that P1 is under the hood. He logs
PIC for the flight. That is how the FAA has trditionally seen it.
However, you need to be sensible about it. If the flight is 2 hours of
which 1.5 hours is hood time, .3 is IMC time, and .2 is
taxi/takeoff/landing time, then your argument that this is primarily a
simulated instrument flight and the IMC time is incidental (forced on
you by conditions) is reasonable, and P2 can legitimately log 2 hours
of flight time since he served as PIC for the entire flight.
If it's more like .3 hours hood time and 1.5 hours IMC time, then
you're going to have a tough time convincing someone that the flight
was primarily an instrument training flight.
I'm not saying this is gospel, but based on the converations I've had
with the FAA inspectors I've met, I think this is probably how an FAA
inspector would look at it - assuming he wasn't out to get you for
something, in which case there's no point in worrying because he will
get you anyway.
Michael
Old June 30th 06, 11:44 PM posted to rec.aviation.ifr,rec.aviation.misc
Jose[_1_]
Perhaps I am not sufficiently clarifying the objective he it is to
enable P1 to fly the (N-reg) plane and log it, under actual IFR,
without P2 being an instructor.
If it is legal, what could P1 log it as? Surely he can't log
instrument time unless P2 is a CFII?
In the United States, it is legal.
P1 (non instrument rated but otherwise current)
P2 (instrument rated and current)
To BE PIC, one must be current and rated for the aircraft and the
conditions. To LOG PIC it is not necessary to BE PIC. One can BE PIC
without being able to LOG PIC.
Under the conditions noted (IMC, IFR), P1 cannot BE PIC. P2 can be PIC.
Therefore, P2 must be PIC to make the flight legal. This (by itself)
does not allow him to log PIC time.
P2, as sole manipulator, can log PIC time, even though he is not PIC.
Now change the conditions slightly. VMC, IFR. P1 still cannot BE PIC.
P2 is required to be PIC. If P1 (sole manipulator) is not wearing a
hood, then no safety pilot is required, so P2 is not a required crew
member. If P1 is under the hood, then a safety pilot is required. I am
not clear on whether this is sufficient (as in VMC, VFR) to allow both
to log PIC, since the flight COULD NOT TAKE PLACE (legally) without P2's
instrument rating, whereas the VMC, VFR flight COULD take place without
P2's instrument rating. I'm inclined to think that both pilots could
log PIC time in this case, and only P2 could BE PIC.
VMC, VFR, with nobody under the hood - No safety pilot is required. The
sole manipulator gets to log PIC time. Either pilot may BE PIC, but
being PIC does not (by itself) allow one to log PIC time.
VMC, VFR, with P1 under the hood. P2, the safety pilot, is a required
crewmember. P1 (rated for the aircraft and conditions) MAY be PIC, but
P2 may also be PIC. Treating these conditions separately:
....if P2 is PIC, he can also LOG PIC time as "pilot in command where
more than one pilot is required". (this is specifically allowed in the
regs and the "letters of clarification"). P1 (sole manipulator) may
also log PIC time, so two pilots get to log PIC time even though only
one is actually the PIC.
....if P2 is NOT PIC, then P1 MUST be PIC. He may log PIC time as sole
manipulator, and also as "pilot in command where more than one pilot is
required". (he doesn't get double hours though. In this case, P2
may choose to log SIC time, as a required crewmember. This is what I do
(it's my only SIC time; although I have no interest in flying commercial
jets, I have heard that those hiring like to see SIC time as it shows
crew management experience).
IMC, VFR. This is an illegal flight, and nobody should log anything.
Jose
The monkey turns the crank and thinks he's making the music.
Old June 30th 06, 11:46 PM posted to rec.aviation.ifr,rec.aviation.misc
Dave S
portion of the flight is spent in IMC and P1 wears a hood, ....
Why would you need to wear a hood if you were in IMC? IMC by its
definition precludes navigation by reference outside the plane. A hood
or view limiting device is used to SIMULATE IMC when it does not, in
fact, exist.
Dave
Old June 30th 06, 11:48 PM posted to rec.aviation.ifr,rec.aviation.misc
Dave S
Brad wrote:
The
-Robert, CFII
IF the safety pilot is the one who has the instrument rating, he most
certainly can.. because he IS the PIC.
In the scenario listed above, the pilot flying (P1) is described as
legal for VFR flight.. and P2 is listed for legal for IFR flight.. so
for this IFR flight, only P2 can BE the pilot in command.
Both can log, however.
P1 logs PIC by virtue of being sole manipulator. P2 logs PIC by virtue
of BEING the PIC on the IFR flight plan, because only P2 can BE the PIC
under an IFR clearance under the conditions specified by the original
poster.
Dave
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
Could the Press Grow a Spine? WalterM140 Military Aviation 259 July 11th 04 08:35 PM
