#21
On May 15, 2:08 pm, "Peter Dohm" wrote:
"Robert M. Gary" wrote in glegroups.com... On May 15, 8:20 am, wrote: We also check the mag grounding at idle just before mixture cutoff. Dan What type of plane are you handpropping that has mixture cutoff? Must not be the traditional Stromburg carb. -Robert This could be just a nomenclature issue. I was taught to call the lean position of the mixture control "idle cut off" even though it really doesn't cut anything off. However, it is too lean to keep the engine running at 1000 rpm. I'm curious about what others think Peter In the C140, the Aeronca, and the J-3 the carbs (probably all Stromburg), pulling the mixture all the way out at idle had no effect at all on the engine. The mixture control only affected the engine at power. -Robert |
Robert M. Gary wrote:
In the C140, the Aeronca, and the J-3 the carbs (probably all Stromburg), pulling the mixture all the way out at idle had no effect at all on the engine. The mixture control only affected the engine at power. With the Marvel-Schebler carbs found on the average (post 1950s) light singles, pulling the mixture all the way back will cut off fuel to the idle circuit as well as the main jet. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200705/1 |
"Robert M. Gary" wrote BTW: I would never hand prop a nosewheel plane. I think I know the reason for this opinion, but I would still be interested in hearing your reasoning. Why no hand propping a nose dragger for you? -- Jim in NC |
#24
On May 15, 10:21 am, "Robert M. Gary" wrote:
On May 15, 8:20 am, wrote: We also check the mag grounding at idle just before mixture cutoff. Dan What type of plane are you handpropping that has mixture cutoff? Must not be the traditional Stromburg carb. -Robert We were talking about turning the prop backward to reposition it, not handpropping to start it. All our training airplanes have starters and idle cutoff mixture controls. My own old Jodel with its A-65 has to be handpropped, and has the old Stromberg with cruise mixture control that has no effect on idle mixture. I shut the fuel off and wait a bit for the bowl to run dry when I shut it down. Dan |
#25
On May 15, 10:02 am, Newps wrote:
The engine is not designed to turn in a specific direction. Some accessories are, such as mags, vacuum pumps, starter, alternator. The engine itself will happily run in the other direction, several twins do just that. That backward-running engine has a different camshaft, mags and oil pump to allow it to run that way. Engines won't run backwards just because we try to start them backwards. The intake/compression/power/ exhaust strokes MUST happen in that order, and a backward-turned engine has them all messed up. Dan |
#26
On May 15, 10:18 am, Andrew Sarangan wrote:
Although I agree with the dangers of accidental engine starts, what I would like to know if there really have been any cases of inadvertant engines starts when the prop is turned half a rotation with the mixture in cut-off even if the magnetos were on. All the cases I am aware of are related to hand-propping, which is not the same as turning the prop to reposition the blades.- Hide quoted text - - Show quoted text - Yes, engines have hurt people. You can kill it with the idle mixture cutoff, but if someone has fooled with the primer (or boost pump on an injected system), fuel will be present and any spark could set it off. An example is a failed start attempt, due either to a flooded engine or cold weather. That prop will be dangerous with the mags on. Turning it forward is insane. Dan |
#27
On May 15, 4:11 pm, wrote:
On May 15, 10:02 am, Newps wrote: The engine is not designed to turn in a specific direction. Some accessories are, such as mags, vacuum pumps, starter, alternator. The engine itself will happily run in the other direction, several twins do just that. That backward-running engine has a different camshaft, mags and oil pump to allow it to run that way. Engines won't run backwards just because we try to start them backwards. The intake/compression/power/ exhaust strokes MUST happen in that order, and a backward-turned engine has them all messed up. Dan Forgot to mention: an alternator generates just fine when run backwards. I did it on an inboard boat I built, because there was no room in that tight compartment for the alternator to sit alonside the engine in its usual spot and had to be mounted backwards in front. An alternator generates alternating curent that is internally rectified, and the direction of rotor rotation is irrelevant. The only consideration is the cooling fan blade angle; installing an older fan with straight radial blades solves the problem. The DC generator must be turned in one direction only. Dan |
#28
Although I agree with the dangers of accidental engine starts, what I would like to know if there really have been any cases of inadvertant engines starts when the prop is turned half a rotation with the mixture in cut-off even if the magnetos were on. All the cases I am aware of are related to hand-propping, which is not the same as turning the prop to reposition the blades. Start no, kick over a turn or two, yes. Even with the engine cut off with the mixture, there can end up with just enough fuel in the system to fire the thing over a turn. I've had it happen on a 172N we had in the club. |
#29
Interesting topic, interesting discussion... but if I may expand on
the original question a bit? The Original piper POH that came with my bird ('67 PA-28-140) actually recommends that that prop be pulled through two complete rotations backwards any time the engine is started after sitting for a long time (it actually says its a good idea for every flight, but should be mandatory any time the engine's been sitting for a while). I've NEVER heard or seen this advice anywhere else... I've never practiced it... It seems almost insane to me... but the book says what the book says. Anyone have any clue why? I can get the exact wording tpmogjt ... its in the 'preflight and takeoff' section of the book. |
#30
Although I agree with the dangers of accidental engine starts, what I would like to know if there really have been any cases of inadvertant engines starts when the prop is turned half a rotation with the mixture in cut-off even if the magnetos were on. Early in my piloting career, while my instructor deftly distracted me with questions about the cruising speed of an unladen swallow, I managed to turn the mags off before pulling the engine to cutoff, so that it stopped because the ignition died. Spotting my mistake, my instructor asked me to run the starter over, and the engine gleefully spat to life on the very first blade, and ran for another 5-10 seconds. Then he asked me if I wouldn't mind terribly putting the plane away myself. Take any aircraft X and put renter A before you who does something similar but doesn't catch the mistake, and you too can become another statistic by trusting that the prop is dead, that the p-lead works, and that the cylinders are dry. TheSmokingGnu |
| I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 07:39 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
