Proping Question
Old May 15th 07, 02:59 PM posted to rec.aviation.piloting,rec.aviation.student
Doug Palmer
Default Proping Question
Several pilots found themselves in a debate at our field yesterday. The
issue is weather it is safer to move the propeller on a (parked) aircraft in
the direction of usual engine rotation, or opposite usual rotation. This is
assuming that the propeller needs to move for some reason.
The reasonings ranged from "you should not turn an engine backwards" to
"turning the engine backwards disarms the impulse coupling", to several
issues in between.
Any thoughts from the groups collective wisdom?
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 07:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
