Hi Folks
I am a relatively low hour PP-ASEL(about 90 PIC, half in C-177 / 152, the rest in Challenger AUL and gliders, total time, including dual = 160 hours). I have not been flying for several years, but am in the process of regaining my certification. As the only way for me to be able to fly from where I am located means ownership, I am in the process of making a shortlist of airplanes I would like to consider. Part of the mission would be fairly regular flights from CTB - LWS and back. (2-3 souls and luggage). What straight-legged 4 seaters would be up to the task? (The actual route would be CYBU - CYXH - CTB - LWS ) Crossing those rocks would seem to exclude a C-172 and its friends. It would seem that something of the order of a C-182 or Piper Cherokee 235 would fit the bill. Does anyone here have experience of flying this kind of trip in, say a C-177, or PA Cherokee 180? Would I have trouble finding insurance if I went straight to a C-182 or PA-235? From what I have read, that should not be a big stretch for me, and would make crossing the ridge a lot easier.\ All VFR for now, although I intend to pursue a IFR rating later. Thank you for any and all replies. Steve |
You can't go wrong with a 182 - but it is a gas hog. As for complexity
- you adjust the prop RPM a couple of times, and close the cowl flaps when you level off, and that's about it. No more difficult to fly than a 150 (IMHO) - but quite a bit heavier. Faster too (120 - 130 knots). David Johnson |
On May 15, 2:52 pm, scronje wrote:
Crossing those rocks would seem to exclude a C-172 and its friends. It would seem that something of the order of a C-182 or Piper Cherokee 235 would fit the bill. Does anyone here have experience of flying this kind of trip in, say a C-177, or PA Cherokee 180? I usually fly my Cherokee 180 all around the Rockies (in the summer no less). I usually try to keep it a few hundred under gross, but with a usable load of over 1000 lbs., that's not hard. Two guys and a weeks worth of camping gear filling the back seat is no problem. It's right at home in the mountains. Sure, 235 hp on the same airframe would be better, but the 180 hp version will get the job done. I have flown a few Cardinals in mountains. Forget the straight C-177 (150 hp, fast wing). At minimum, you should use a C-177A, or even better would be the C-177B. The B model has the normal wing, 180 hp, and CS prop. All good things for high density altitudes. John Galban=====N4BQ (PA28-180) |
Hi John
Thank you for your response. On Wed, 16 May 2007 16:26:34 -0700, John Galban wrote: I usually fly my Cherokee 180 all around the Rockies (in the summer no less). I usually try to keep it a few hundred under gross, but with a usable load of over 1000 lbs., that's not hard. Two guys and a weeks worth of camping gear filling the back seat is no problem. It's right at home in the mountains. Sure, 235 hp on the same airframe would be better, but the 180 hp version will get the job done. What sort of climb rates are you seeing at altitude? You don't have any online flying travelogues do you ;-) I would love to know more about your flying experiences in the Rockies with the 180. Where you have flown, that sort of thing. Steve |
On Tue, 15 May 2007, scronje wrote:
Part of the mission would be fairly regular flights from CTB - LWS and back. (2-3 souls and luggage). What straight-legged 4 seaters would be up to the task? (The actual route would be CYBU - CYXH - CTB - LWS ) Crossing those rocks would seem to exclude a C-172 and its friends. I fly a club Tomahawk and 172N (160HP) based at S73, in the hills a ways east of LWS. I don't have a whole lot of experience flying over the really serious mountains, but I fly to Missoula occasionally. Doesn't look like there's anything a whole lot higher from there to Cut Bank, than there is from here to Missoula. So, based on my experience, I'd suggest you not completely write off a 172. Something bigger & more powerful would be nice, but a 172 is cheaper to buy and cheaper to feed. Of course, it might depend a lot on how big those 2-3 souls are, and how much luggage they want to take along. But I wouldn't be too concerned about loading the 172 to gross weight and flying from here to Cut Bank. Don't know how much mountain flying you've done, but whatever you get, make sure you know a little about it before you make the trip, and carry some basic survival gear. Also, whenever practical, I like to select routes that won't take 2 days to hike into, should rescuers find it necessary. -Dan |
VFR? No problem with a 172.
Dan Youngquist wrote: On Tue, 15 May 2007, scronje wrote: Part of the mission would be fairly regular flights from CTB - LWS and back. (2-3 souls and luggage). What straight-legged 4 seaters would be up to the task? (The actual route would be CYBU - CYXH - CTB - LWS ) Crossing those rocks would seem to exclude a C-172 and its friends. I fly a club Tomahawk and 172N (160HP) based at S73, in the hills a ways east of LWS. I don't have a whole lot of experience flying over the really serious mountains, but I fly to Missoula occasionally. Doesn't look like there's anything a whole lot higher from there to Cut Bank, than there is from here to Missoula. So, based on my experience, I'd suggest you not completely write off a 172. Something bigger & more powerful would be nice, but a 172 is cheaper to buy and cheaper to feed. Of course, it might depend a lot on how big those 2-3 souls are, and how much luggage they want to take along. But I wouldn't be too concerned about loading the 172 to gross weight and flying from here to Cut Bank. Don't know how much mountain flying you've done, but whatever you get, make sure you know a little about it before you make the trip, and carry some basic survival gear. Also, whenever practical, I like to select routes that won't take 2 days to hike into, should rescuers find it necessary. -Dan |
Hi Dan
On Thu, 17 May 2007 15:23:03 -0700, Dan Youngquist wrote: but I fly to Missoula occasionally. What altitudes do you typically fly at? Don't know how much mountain flying you've done, but whatever you get, make sure you know a little about it before you make the trip, Good point, and already on my "to-do" list. I don't have any mountain experience. I understand there is an operation out of Calgary that offers training. Thank you for your response! Steve |
On May 16, 9:00 pm, scronje wrote:
What sort of climb rates are you seeing at altitude? You don't have any online flying travelogues do you ;-) I would love to know more about your flying experiences in the Rockies with the 180. Where you have flown, that sort of thing. At 200 lbs. under gross and 10,000 ft. density altitude, I still see 400-500 fpm in the climb. The caveat here is that it used to be closer to 300 before I put gap seals all around and added Hoerner style wingtips. Travelogue? I think I have just the thing. You can check out my website. It's mostly backcountry airstrips and camping locations. It's at : http://www.johngalban.com/ John Galban=====N4BQ (PA28-180) |
Hi again, John!!
On Fri, 18 May 2007 17:57:51 -0700, John Galban wrote: At 200 lbs. under gross and 10,000 ft. density altitude, I still see 400-500 fpm in the climb. That sounds pretty impressive. You can check out my website. It's mostly backcountry airstrips and camping locations. It's at : http://www.johngalban.com/ Very neat site! Thank you. I have spent some time looking at it, and taken a look at some of the strips you mention. Many of them are rather close to the route I was discussing How did you "get into" mountain flying? How much dual did you do before you went at it alone? Some of those strips look pretty challenging, at least in the photos. Regards Steve |
On May 19, 11:59 am, scronje wrote:
How did you "get into" mountain flying? How much dual did you do before you went at it alone? Some of those strips look pretty challenging, at least in the photos. I used to throw a load of camping gear on my motorcycle and head up to the norther Rockies on my summer vacations. When I got a plane, I just kept doing the same, only faster (and more fun). I started flying to easy, unobstructed fields in mountainous areas, then slowly worked my way up to the more challenging strips. Along the way I got a lot of good advice from experienced mountain pilots, and read as much as I could on the subject. I never really had any dual instruction specifically for mountain flying. Coming from AZ, you learn a lot about flying around mountains at high density altitude as part of your private pilot training. Nowadays, there are specialized mountain flying programs for those interested in flying the backcountry, like http://www.mountaincanyonflying.com/ . They will get you up to speed much faster than my "baby steps" approach :-) John Galban=====N4BQ (PA28-180) |
| Pilot dies midflight; co-pilot lands plane | A Guy Called Tyketto | Piloting | 0 | January 21st 07 08:56 PM |
| BD-6 article, 9/73 Plane & Pilot | [email protected] | Home Built | 2 | March 24th 06 12:15 PM |
| jan 2003 plane & pilot | [email protected] | Owning | 1 | June 16th 05 03:49 PM |
| Best Single Pilot IFR Plane | Charles Talleyrand | Owning | 57 | January 3rd 04 02:02 PM |
| Best Single Pilot IFR Plane | Charles Talleyrand | Instrument Flight Rules | 64 | December 9th 03 08:20 PM |
