IFR flight plan cancellation time
Old May 29th 07, 09:42 AM posted to rec.aviation.ifr
Gerald S.
Default IFR flight plan cancellation time
I had filed a flight plan for 8pm local the other night. I tried
amending the departure time as I was leaving 1.5 hours later than the
proposed time. I called the FSS and was told the IFR flight plan gets
deleted by the system 2 hours after the proposed departure time. I
thought it was 45 minutes or an hour. My friend who thought it was 2
hours. The only reference I can find says it varies from center to
center. Is this correct? Any real world experience?
And if this is in the Pilot-Controller handbook, it's time for me to buy
it and I apologize in advance.
thanks
Gerald
Old May 29th 07, 12:58 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Gerald S." wrote in message
news
I had filed a flight plan for 8pm local the other night. I tried amending
the departure time as I was leaving 1.5 hours later than the proposed
time. I called the FSS and was told the IFR flight plan gets deleted by
the system 2 hours after the proposed departure time. I thought it was 45
minutes or an hour. My friend who thought it was 2 hours. The only
reference I can find says it varies from center to center. Is this
The national standard is two hours. That can be extended by individual
ARTCCs and is often done during periods of weather delays. It's not in the
Pilot/Controller Glossary.
Old May 29th 07, 05:09 PM posted to rec.aviation.ifr
Peter R.
My real world experience in the northeast US over the last four years
concurs. The IFR flight plan typically will be available to the ATC facility
handling your clearance from 30 minutes prior to your planned departure time
to two hours after.
If you know you are not going to depart until after the two hour window, you
can use FSS to adjust the departure time during that period, or you can use
the ATC facility that will handle your outbound clearance (for example, you
are flying IFR into an airport and know that your departure out of that
airport will exceed your scheduled departure time by the two hours - ask that
controller handling your approach to hold the flight plan for your new
departure time).
Peter
Old May 29th 07, 07:47 PM posted to rec.aviation.ifr
Dave Butler
can use FSS to adjust the departure time during that period, ...
.... but the flight plan goes out of FSS's hands about an hour before the
scheduled departure, and then is accessible only by center. FSS will
tell you they can't change it any more.
DB
Old May 29th 07, 07:53 PM posted to rec.aviation.ifr
Peter R.
Yep, my mistake...
Peter
Old May 29th 07, 09:58 PM posted to rec.aviation.ifr
Newps
window, you
Then FSS has their head up their ass. All they have to do is call the
facility where the flight plan is and have them change the time. The
pilot can do the same thing, by the way.
OSH flight plan Dan Luke Piloting 3 July 23rd 05 04:33 AM
Flight plan hell, Tales of filing an ADIZ flight plan Michelle P Piloting 30 July 15th 05 07:28 AM
IFR Flight plan Hankal Instrument Flight Rules 9 September 16th 04 06:39 AM
Flight Plan and Flight Log excel spreadsheet. Marco Rispoli Piloting 2 January 14th 04 10:12 PM
Flight plan Hankal Instrument Flight Rules 15 October 11th 03 09:03 AM
