When using a GPS in leg mode going to the IAF for a procedure turn, when you
switch it to OBS mode, don't you loose your navigation (except for the moving map)? You don't want to wait too long to switch to OBS, or else it may sequence to the next waypoint when you get to the IAF, but the sooner you do it, the sooner your navigating with just the moving map, aren't you? |
On Jun 11, 5:28 pm, "kevmor" wrote:
When using a GPS in leg mode going to the IAF for a procedure turn, when you switch it to OBS mode, don't you loose your navigation (except for the moving map)? You don't want to wait too long to switch to OBS, or else it may sequence to the next waypoint when you get to the IAF, but the sooner you do it, the sooner your navigating with just the moving map, aren't you? Depends on which GPS you are talking about. On the GNS430, if you select the correct IAF it should sequence you to the PT instead of inbound. |
I'm using the King KLN-94, it won't sequence to the PT...
"Andrew Sarangan" wrote in message oups.com... On Jun 11, 5:28 pm, "kevmor" wrote: When using a GPS in leg mode going to the IAF for a procedure turn, when you switch it to OBS mode, don't you loose your navigation (except for the moving map)? You don't want to wait too long to switch to OBS, or else it may sequence to the next waypoint when you get to the IAF, but the sooner you do it, the sooner your navigating with just the moving map, aren't you? Depends on which GPS you are talking about. On the GNS430, if you select the correct IAF it should sequence you to the PT instead of inbound. |
If you select the OBS mode prior to reaching your intersection, it wont
sequence to the next waypoint. (you know this..) Fly your procedure turn/Hold (whichever entry, or the 180 turn to outbound).. when you turn inbound, the device should still give you navigation back to the selected waypoint (no worse than doing a PT or hold with a VOR/Nav) You should be flying by reference to the NAV/HSI indicator, not the moving map. The HSI/Nav needles still work even when waypoint sequencing is suspended during (OBS) PT/Hold maneuvers. Have you ever done a hold or PT with a VOR type instrument? (no GPS involved whatsoever) That might be beneficial for wrapping yourself around this conceptually... Dave kevmor wrote: I'm using the King KLN-94, it won't sequence to the PT... "Andrew Sarangan" wrote in message oups.com... On Jun 11, 5:28 pm, "kevmor" wrote: When using a GPS in leg mode going to the IAF for a procedure turn, when you switch it to OBS mode, don't you loose your navigation (except for the moving map)? You don't want to wait too long to switch to OBS, or else it may sequence to the next waypoint when you get to the IAF, but the sooner you do it, the sooner your navigating with just the moving map, aren't you? Depends on which GPS you are talking about. On the GNS430, if you select the correct IAF it should sequence you to the PT instead of inbound. |
kevmor wrote:
When using a GPS in leg mode going to the IAF for a procedure turn, when you switch it to OBS mode, don't you loose your navigation (except for the moving map)? You don't want to wait too long to switch to OBS, or else it may sequence to the next waypoint when you get to the IAF, but the sooner you do it, the sooner your navigating with just the moving map, aren't you? If you have a C146a navigator you don't have to do any of this switching nonsense. |
Ok, I think I've got it... As I'm approaching the fix, I hit OBS, and since
I had the correct OBS setting, I'm navigating to it still just as if it were a VOR. (Before I was thinking of pressing OBS and setting the inbound course immediately, where the CDI goes to the side and your still trying to go to the fix). "Dave S" wrote in message ink.net... If you select the OBS mode prior to reaching your intersection, it wont sequence to the next waypoint. (you know this..) Fly your procedure turn/Hold (whichever entry, or the 180 turn to outbound).. when you turn inbound, the device should still give you navigation back to the selected waypoint (no worse than doing a PT or hold with a VOR/Nav) You should be flying by reference to the NAV/HSI indicator, not the moving map. The HSI/Nav needles still work even when waypoint sequencing is suspended during (OBS) PT/Hold maneuvers. Have you ever done a hold or PT with a VOR type instrument? (no GPS involved whatsoever) That might be beneficial for wrapping yourself around this conceptually... Dave kevmor wrote: I'm using the King KLN-94, it won't sequence to the PT... "Andrew Sarangan" wrote in message oups.com... On Jun 11, 5:28 pm, "kevmor" wrote: When using a GPS in leg mode going to the IAF for a procedure turn, when you switch it to OBS mode, don't you loose your navigation (except for the moving map)? You don't want to wait too long to switch to OBS, or else it may sequence to the next waypoint when you get to the IAF, but the sooner you do it, the sooner your navigating with just the moving map, aren't you? Depends on which GPS you are talking about. On the GNS430, if you select the correct IAF it should sequence you to the PT instead of inbound. |
kevmor wrote:
Ok, I think I've got it... As I'm approaching the fix, I hit OBS, and since I had the correct OBS setting, I'm navigating to it still just as if it were a VOR. (Before I was thinking of pressing OBS and setting the inbound course immediately, where the CDI goes to the side and your still trying to go to the fix). Sounds about right. You should get the waypoint light flashing as you fly over/fly by. When you get that waypoint passage indication, fly your PT or Hold. If you have a to/from indication on your CDI that should flip/change as well when you pass the station/waypoint When you turn inbound, make whatever adjustments you need to, with your plane and with the Obs (usually only a degree or two if you nail the pt/hold) to fly TO the waypoint. If you are ready to continue the approach, un-select OBS and when you fly over, you sequence to the next point as expected. This particular issue is addressed in the KLN-94 Pilot's Guide section 5.5, or page 145 - 150 if you have it in PDF. Hope its clearing up a bit Dave |
| Change in AIM wording concerning procedure turn | Kris Kortokrax | Instrument Flight Rules | 208 | October 14th 05 01:58 AM |
| Procedure turn required? | Yossarian | Piloting | 85 | July 6th 05 09:12 PM |
| Procedure turn required? | Peter Duniho | Instrument Flight Rules | 80 | July 6th 05 09:12 PM |
| Procedure turn in Strong X-wind | smackey | Instrument Flight Rules | 26 | November 30th 04 11:05 PM |
| Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 04:27 AM |
