Lowrance 600C question
Old October 4th 07, 02:59 PM posted to rec.aviation.piloting
Edwin Johnson
Default Lowrance 600C question
On 2007-10-04, Jackal24 wrote:
john wrote in
ups.com:
150 miles everything looks normal. At 100 miles, the top half of the
screen shows no terrain. As I zoom in, it looks like it is missing
the same area of land. The terrain stops at N 60deg 00'03.3"
I'd like to know if they have a problem with the software.
John
Exactly. There are large areas in Alaska with this problem. I know that
where I fly (around SXP, AUK, PAEM), this problem is widespread. I have
found that the zoom level at which terrain disappears depends on which view
you are using and what setting you have for "earth detail". If I set it on
low, it will allow me to go to a closer zoom level than if on high.
OK, I've looked again at my unit. At 150 miles range on earth detail=high,
all looks normal. At 100 miles about the latitude given above is a green band
separating detail topo information from less detailed. Above this green band
is detail but of very low detail, such as lakes, a MOA, rivers, etc., but
not in great detail. If you scan to the east and west, you will see that
this effect continues. I'm convinced this is a database, hence file, problem
and nothing is wrong with any of our units. It appears they simply don't
have the detailed topo info in the database for close work above that
latitude.
Incidentally, on earth detail=medium, this changes on mine at 60 miles, and
on 'low' at 30 miles. If I turn off the earth detail, all above that green
band goes white, other than the MOA and airports, etc.
Still, I believe this is a database problem. Lowrance tech support has been
helpful to me in the past, but don't know their policies now. Still could be
a simple download of the new data might work. If you call, tweak them to
tell you the dates of the database on the unit at which they are looking and
have them set up the unit as you have yours set up. I would be interested in
the results.
....Edwin
__________________________________________________ __________
"Once you have flown, you will walk the earth with your eyes
turned skyward, for there you have been, there you long to
return."-da Vinci http://bellsouthpwp2.net/e/d/edwinljohnson
Old October 5th 07, 05:43 AM posted to rec.aviation.piloting
Jackal24
I emailed them again and will see what they say.
Old October 5th 07, 08:02 AM posted to rec.aviation.piloting
Thomas Borchert
Jackal24,
If
you have one, can you try zooming in to the airport 5NN and seeing if your
unit shows the problem. At a close zoom level on mine, you can see the
terrain disappears on part of the screen.
I'm afraid I only have access to International units (see www.aeroversand.eu)
Thomas Borchert (EDDH)
Old October 6th 07, 08:39 AM posted to rec.aviation.piloting
Jackal24
I emailed them again and got this response:
Thanks for the email inquiry,
I have been able to verify the problem that you are emailing about with
this recent email and have forwarded the information to the appropriate
department for review. My expectations are that a firmware update will
resolve the problem as you indicate. You can sign up for email notification
at www.lowrance.com under "product updates" when an update is available for
your unit. We appreciate your patience in the mean time.
Please advise if you need further assistance.
Thank you for choosing Lowrance Products.
Lowrance Electronics
12000 E. Skelly Dr.
Tulsa, OK 74128
800-324-1356
Old October 6th 07, 03:08 PM posted to rec.aviation.piloting
Edwin Johnson
Thanks for posting their response. I upgraded my firmware once, but will
look for a new update on their site.
....Edwin
Old October 8th 07, 04:32 AM posted to rec.aviation.piloting
Jackal24
Edwin Johnson wrote in
news
will look for a new update on their site.
...Edwin
No problem. I hope they fix it soon.
PIREP Lowrance 600c xxx Piloting 3 May 29th 07 04:36 AM
Lowrance 600c Display Question Ebby Piloting 3 April 2nd 07 01:17 PM
Lowrance Airmap 600c GPS CareBear Piloting 12 October 26th 06 06:19 AM
Lowrance 600c: Preliminary Pirep xxx Piloting 2 October 21st 06 03:43 PM
Lowrance Airmap 600c GPS? Dan Youngquist Piloting 6 July 10th 06 05:19 PM
