PIREP Lowrance 600c
The trip up the central valley (see PIREP SCK, posted earlier today) was the first time I had occasion to make use of the Lowrance 600c I bought a few months back. It works. That's the good news. With the external antenna sitting on the glare shield, it pretty much instantaneously locked onto some satellites and never lost lock. It's much faster than the Garmin handheld hiker's model (no aviation database) I also have used. I don't think I got all that close to the advertised six hours from the batteries. The first pair died after not much more than an hour into the flight, though I don't have an accurate figure on how long I used them before takeoff. However, after I replaced them on the ground at SCK and used them for another three hours, the unit reports it still has half charge left, so maybe it does get an honest six hours per pair of AAs. The screens are generally too cluttered and there are too many menus with too small type to effectively make use of all the power it has. Maybe if I had a dedicated electronics officer in the right seat it would have worked better. As is, it seems to me that the only practical way to use it is to set it on the ground and stick with whatever destination and display is chosen there. The display is all but invisible without the backlight on. Using the backlight, of course, chews up the battery at a great rate. I left it at the default setting of turning the light off after 30 seconds use. It is usable that way, but not ideal. And that's my general feeling about the unit. It's usable, but not ideal. It's a lot of processing power and features for the buck. It is, however, something of a compromise in cockpit utility. |
backlight, of course, chews up the battery at a great rate. I left it at the default setting of turning the light off after 30 seconds use. It is usable that way, but not ideal. That's true with most GPS's, Lowrance especially. Our 2000c is the same way -- without the backlight on, it's almost useless. Which is why we have it plugged into ship's power at all times, and regard the batteries as "emergency back-up" only. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"xxx" wrote in message oups.com... PIREP Lowrance 600c The screens are generally too cluttered and there are too many menus with too small type to effectively make use of all the power it has. Maybe if I had a dedicated electronics officer in the right seat it would have worked better. As is, it seems to me that the only practical way to use it is to set it on the ground and stick with whatever destination and display is chosen there. In the case of a sudden in-flight change of plans, you can always just use is as a moving-map display and fly in the correct general direction towards any destination you can see on the screen. It ain't perfect, but it still beats trying to figure out a course from the sectional while you are trying to fly the airplane. The display is all but invisible without the backlight on. Using the backlight, of course, chews up the battery at a great rate. I left it at the default setting of turning the light off after 30 seconds use. It is usable that way, but not ideal. Wow! Is this true of all color displays? I fly behind the original non-color Lowrance 500 and it has no such problem. The only time you might want the backlight is at night. Perhaps I should cherish that old 500? And that's my general feeling about the unit. It's usable, but not ideal. It's a lot of processing power and features for the buck. It is, however, something of a compromise in cockpit utility. That is how I have always felt about my 500, but it is head and shoulders better than anything I have ever had before. As for battery life, use several sets of batteries from several different lots before you make up your mind. I have learned the hard way, even a name brand battery manufacturer will occasionally ship a bad lot. I have also found that the "best by" dates printed on the batteries are often a fiction. The best batteries are fresh batteries. Vaughn |
That's true with most GPS's, Lowrance especially. Our 2000c is the same way -- without the backlight on, it's almost useless. Which is why we have it plugged into ship's power at all times, and regard the batteries as "emergency back-up" only. Lowrance actually states that the battery is for emergency backup and that it is not recommended as the primary power source. Tony Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
| Thread Tools | |
| Display Modes | |
| Lowrance 600c Display Question | Ebby | Piloting | 3 | April 2nd 07 02:17 PM |
| Lowrance Airmap 600c GPS | CareBear | Piloting | 12 | October 26th 06 07:19 AM |
| Lowrance 600c: Preliminary Pirep | xxx | Piloting | 2 | October 21st 06 04:43 PM |
| Lowrance Airmap 600c GPS? | Dan Youngquist | Piloting | 6 | July 10th 06 06:19 PM |
| PIREP : Lowrance AirMap 500 | Ardna | Piloting | 11 | July 14th 04 03:47 AM |
