FYI: Dec 12 MythBusters: Airplane Hour
Old December 13th 07, 06:30 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Mxsmanic
Default FYI: Dec 12 MythBusters: Airplane Hour
Robert M. Gary writes:
I have no doubt that our buddy from France firmly believes he can land
a 747 if necessary. In fact he's done it hundreds of times.
If the airplane is normally airworthy and with the use of automation, I have
virtually no doubt of it. Flying by hand is much more uncertain, depending on
many things.
  #62
Old December 13th 07, 07:06 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Jim Macklin
They tried, in one previous show, to duplicate the old cartoon shotgun
barrel blow up with the barrel unwinding. They tried to use modern shotguns
which are made from solid tubular steel. Shotguns made before about 1920
were generally made by wrapping steel wire around a mandrel and using the
old blacksmith welding with a hammer and anvil.
Those barrels would have flaws and weak spots.
What they showed with landing the NASA simulator is that any person with
some level experience with a cockpit display can control an airliner. Most
FAA controllers would not have the experience to describe the cockpit and
give useful instruction in how to manually fly with the autopilot or where
the switches are located, or how to use the radio to even start the
"rescue."
Maybe they should have an in-flight movie before each take-off on how to fly
the airplane, do you think TSA would allow that?
"Robert M. Gary" wrote in message
| On Dec 8, 9:32 pm, Jim Logajan wrote:
| "Jamie and Adam take wing to test if a person with no flight training
can
| safely land an airplane and if a plane can take off from a conveyor belt
| speeding in the opposite direction. Tory, Grant, and Kari jump on some
| Hollywood-inspired skydiving myths."
| Quoted from the Discovery channel
schedule:http://dsc.discovery.com/tv-schedule...=1.13056.24704....
| (My local paper's weekly TV schedule has just the brief summary "Landing
a
| 747" so I presume the plane they attempt to land without training is a
747.
| Will be interesting to see if they try the real thing and are not
limited
| to a simulator.)
| -Robert
  #63
Old December 13th 07, 09:19 AM posted to rec.aviation.homebuilt, rec.aviation.piloting, rec.skydiving
James Sleeman
For those outside the US, you can find it with a search for
mythbusters on piratebay.org now, but you didn't hear that from me.
  #64
Old December 13th 07, 11:11 AM posted to rec.aviation.homebuilt, rec.aviation.piloting, rec.skydiving
James Sleeman
Argh, before anybody else does, don't bother if you're only wanting
plane ona treadmill, because, they dropped it from the episode.
Quoting from the MythBusters forum...
--- Begin Quote ---
I have just received an email from Dan Tapster, executive producer of
MythBusters.
Thanks to all the activity, he can't log in and asked me to post this
for him.
quote:
"Adam? Jamie? Dan? Someone step up and tell us what happened tonight."
Dear all,
As wbarnhill called out, I thought I should step in to what is rapidly
becoming a hornet's nest. I will try to calm things down but I don't
hold out much hope!
First up, for those concerned that this story has been cancelled,
don't worry, planes on a conveyer belt has been filmed, is
spectacular, and will be part of what us Mythbusters refer to as
'episode 97'. Currently that is due to air on January 30th.
Secondly, for those very aggrieved fans feeling "duped" into watching
tonight's show, I can only apologise. I'm not sure why the listings /
internet advertised that tonight's show contained POCB. I will
endeavour to find out an answer but for those conspiracy theorists
amongst you, I can assure you that it will have just been an honest
mistake. At one point
several months ago, POCB was going to be part of Airplane Hour.
Somewhere, someone has mistakenly posted the wrong listing. It will
have been a genuine mistake but nonetheless it was a mistake which is
unacceptable. As said I will try to find out what went wrong and hope
that you will see fit to forgive the team at Discovery.
Thanks in advance,
Dan
And with that, the entire board is going "READ ONLY" until I can clean
up the mess.
MythMod
--- End Quote ---
  #65
Old December 13th 07, 01:58 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Mark Hickey
"Casey Wilson" wrote:
"Newps" wrote in message
johnsonbomb wrote:
Dude, it's mythbusters. These guys are freaking brilliant and they
will cover this thing from all angles. I can assure you.
yeah, like when they shot frozen chickens thru a Cherokee windshield and
applied the results to airliners. Brilliant.
But they did do a mostly reasonable job with piercing the skin of a
pressurized fuselage with a 9mm. The shaped charge part was hokey.
And frightening. I think the results of the "experiment" caught
everyone off-guard. I know I for one have resolved to NEVER, EVER
place a shaped charge against the wall of an aircraft I'm flying on.
Mark" wouldn't be prudent" Hickey
  #66
Old December 13th 07, 02:41 PM posted to rec.aviation.homebuilt, rec.aviation.piloting, rec.skydiving
--- Begin Quote ---
MythBusters.
for him.
Dear all,
hold out much hope!
Thanks in advance,
Dan
up the mess.
MythMod
--- End Quote ---
I want the treadmill..... I want the treadmill.... :)).
Lil ben
  #67
Old December 13th 07, 02:48 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Matt W. Barrow
"Jim Macklin" wrote in message
shotguns
More like 1880 than 1920.
"Damascus" barrels were not really produced after the 1880's or so, long
before the introduction of smokeless powder around 1900. Smokeless powder
would easily destroy such a barrel.
  #68
Old December 13th 07, 03:44 PM posted to rec.aviation.homebuilt, rec.aviation.piloting, rec.skydiving
Harry K
--- Begin Quote ---
MythBusters.
for him.
Dear all,
hold out much hope!
Thanks in advance,
Dan
up the mess.
MythMod
--- End Quote ---
Aha! It is a conspiracy. If it weren't they wouldn't be trying to
deny it!
I wasted an evening waiting for 10 p.m., went through a 6 pack...oops
I guess it wasn't 'wasted' after all.
Harry K
Looking forward to Jan 30th.
  #69
Old December 13th 07, 04:37 PM posted to rec.aviation.homebuilt, rec.aviation.piloting, rec.skydiving
F. Baum
On Dec 13, 12:06 am, "Jim Macklin"
"rescue."
Jim, I caught just the parts of the show where J and A tried to land
the plane with some coaching from the sim instructor (Mainly to see
how the instructor would do this). These portions of the show were
amazingly brief (Possibly for security reasons ?) . The stuff they did
show was scary and I doubt they could have gotten awhay with some of
it in a real plane. I do watch the show for its "Infotaiment" value
but I remain unconvinced that someone could actually be talked down in
an airliner. I think it has been tried a time or two in GA after the
pilot became incapacitated.
FB
  #70
Old December 13th 07, 05:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Dudley Henriques[_2_]
"rescue."
FB
The big rub in the equation are of course the variables. They are HUGE
in this equation and any one of them could take out the airplane.
Just off the top of my head, one has to factor in the EXACT aircraft in
the scenario, as each airline has the option to customize their cockpits
to whatever the chief pilot wanted installed at the time of the contract
signing with the manufacturer. This aspect alone might well require a
company pilot completely familiar with the cockpit of THAT specific
airplane, as even in type, changes are made to the cockpit
configurations during a manufacturing run as requested by the front
office, so that you might have one airplane with a switch or lever
"here" and another with it "there".
Then you have the issue of getting this company guy familiar with THIS
cockpit on the radio and in touch with the guy trying to land the airplane.
THEN you need a guy in the cockpit who can not only follow directions
NOW, but follow them CORRECTLY and in real time.
Notice we're talking here about a manually controlled landing. If the
aircraft AND the landing facility are BOTH equipped accordingly,
autoland might be a possibility and negate the manual landing.
All things considered, my vote goes to doing it in the simulator with
the help of the sim instructor but a high risk factor for losing a real
aircraft in the manual mode.
Could be done of course, but I wouldn't want to be a passenger on that
one for sure :-)
Dudley Henriques
FYI: Dec 12 MythBusters: Airplane Hour Jim Logajan Piloting 217 December 21st 07 11:33 AM
Mythbusters Episode and FMS Marco Leon Piloting 19 February 13th 07 05:45 AM
Mythbusters and explosive decompression Casey Wilson Piloting 49 July 15th 04 05:56 PM
MythBusters Hilton Piloting 7 February 4th 04 03:30 AM
Mythbusters Explosive Decompression Experiment C J Campbell Piloting 49 January 16th 04 07:12 AM
