Mythbusters Explosive Decompression Experiment
Old January 12th 04, 06:13 AM
C J Campbell
Default Mythbusters Explosive Decompression Experiment
Now, that was cool!
Mythbusters pressurized an old DC-9 and fired a bullet through the wall to
see if it would cause an explosive decompression. It didn't. Then they fired
a bullet through the window to see if the window would shatter and cause an
explosive decompression. The bullet only made a small hole in the window
because the windows are made of shatter-proof plastic. No explosive
decompression.
Then Mythbusters put explosive all around the window to blow it out and
deliberately cause an explosive decompression. The crash test dummy,
"Buster," was damaged but was not sucked out the window. If he had been a
real person he would have been injured but probably lived. His arm was badly
damaged enough that a human arm might have been lost. So Mythbusters patched
everything up and used a shaped charge to blow out the whole wall. The
explosive decompression ripped the entire top off the fuselage and much of
the wall out, but the seats and the crash test dummy remained in the
airplane. I would guess that if the "Buster" had been a live human he would
have been seriously injured and possibly killed.
Mythbusters then talked about how strong these airplanes really are and
closed with photos of the Hawaiian Airlines plane that suffered an explosive
decompression similar to the one that the show created with a shaped charge.
The only person killed was a flight attendant who was pulled from the plane
by the airstream, but the passengers all survived.
I thought the show was fascinating. It really demonstrated the engineering
that goes into an airliner. Besides, I like watching things blow up. It must
appeal to my inner 12 year old.
Christopher J. Campbell
World Famous Flight Instructor
Port Orchard, WA
If you go around beating the Bush, don't complain if you rile the animals.
Old January 12th 04, 07:02 AM
David Brooks
"C J Campbell" wrote in message
explosive
charge.
plane
However, at one of the passengers soon after gave birth to a little girl who
died a day later. There was no particular pathology. Milagro they called
her. She was my sister-in-law's niece.
I'm not blaming anyone - if anything I just wanted to honor her memory.
-- David Brooks
Old January 12th 04, 01:35 PM
Jay Honeck
Now, that was cool!
Agreed. The ten minutes I caught at the end were very well done, and should
go a long way toward dispelling the myth.
Now if only they had a more significant viewership...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 12th 04, 02:26 PM
Dennis O'Connor
Neonates do die, fortunately not with great frequency... As a working doc I
immediately wondered about Caisson Disease from the rapid decompression,
when I read your posting... The fetus is normally well protected and
buffered by the body of the mother for trauma like that... And, the total
psi/bar drop in that form of decompression is minor compared to divers, et.
al., however the rate of change of the decompression is far more
instantaneous than for caisson workers and divers, so if it was Caisson
Disease the rate of change had to be the key..
Denny
"David Brooks"
who
Old January 12th 04, 04:21 PM
Dennis O'Connor
There is no problem so vexing as cannot be solved by application of
sufficient explosives...
Now, that was cool!
Old January 12th 04, 05:22 PM
Mark
"C J Campbell" wrote in message ...
Now, that was cool!
decompression.
I also watched the show and one factor they did not take into account
was the speed of an airliner at altitude. Also, what would happen to
the forces on the damnaged airframe during the descent/emergancy
landing? As in most tests, this was a controlled experiment. I'm sure
if they placed the shaped charge closer to the wing root, more
damnaged would occure.
Still a good show, I especially like the part where they used a 22
bullet for a fuse replacement.
Old January 12th 04, 07:47 PM
John Harper
Shame I missed it, maybe I'll see it on the 394th rerun.
But anyway I DID see Goldfinger the other night so I know
this is all wrong. If you shoot a bullet through the window of
an airplane, first the whole window explodes. Then everything
is sucked through the window, including people who are
considerably larger than the window aperture (except James
Bond of course). This continues indefinitely. Also the plane
goes into an uncontrollable dive and ends up spiralling into
the ground, despite the combined efforts of two people on
the flight deck.
I think I prefer the James Bond version.
John
( :-), for the irony challenged)
Now, that was cool!
fired
an
decompression.
badly
patched
would
explosive
charge.
plane
must
Port Orchard, WA
Old January 12th 04, 08:54 PM
C J Campbell
"John Harper" wrote in message
news:1073933174.414447@sj-nntpcache-5...
| the flight deck.
| John
Mythbusters seemed to prefer the "U.S. Marshals" version, complete with
shackled prisoners and guards being sucked out the airplane. The James Bond
"Die Another Day" version is just not as good as the "Goldfinger" scene.
I think I know the origin of all of this -- it is none other than Dr.
Wernher von Braun and Walt Disney. Disney made a film about the Dyna Soar
space project ("Man and Space" -1957) that was narrated by Braun. That film
shows a cartoon of the occupants being sucked out of the spacecraft after a
meteor pierces a tiny hole in the structure.
Old January 13th 04, 01:55 AM
Bob Gardner
The speed of the airplane at altitude has nothing to do with it. The
pressure differential between the cabin and the great outdoors is the only
factor...airspeed does not exert any pressure on the sides of the fuselage.
Bob Gardner
"Mark" wrote in message
om...
Now, that was cool!
to
fired
an
decompression.
a
badly
patched
of
would
explosive
charge.
plane
engineering
must
Old January 13th 04, 03:29 AM
David Dyer-Bennet
"Bob Gardner" writes:
In the case of a bullet hole, it's probably not significant (although
I'd think the exit hole would would be somewhat ragged, and would
stick out into the airstream, so even that might). In the more
extreme cases, where they used shaped charges to blow out many square
feet of fuselage, I'd have thought the airstream would be a *very*
important factor in what happened next.
David Dyer-Bennet, , http://www.dd-b.net/dd-b/
RKBA: http://noguns-nomoney.com http://www.dd-b.net/carry/
Photos: dd-b.lighthunters.net Snapshots: www.dd-b.net/dd-b/SnapshotAlbum/
Dragaera/Steven Brust: http://dragaera.info/
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. B2431 Military Aviation 17 January 21st 04 12:13 AM
Can you say: Payne Stewart ? - Explosive Decompression? Try ityourself, numbnuts. G.R. Patterson III Military Aviation 0 January 15th 04 12:36 AM
Can you say: Payne Stewart ? - Explosive Decompression? Try ityourself, numbnuts. G.R. Patterson III General Aviation 0 January 15th 04 12:36 AM
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. S Narayan General Aviation 2 January 14th 04 11:22 PM
Explosive decompression by the book Bob Gardner Piloting 4 January 3rd 04 06:13 AM
