Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Old February 16th 08, 04:41 AM posted to rec.aviation.ifr
Terence Wilson
Default Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
One annoyance of the 430 is that activating an approach will
immediately set a course for the selected IAF (assuming RV not
selected). What I would like to do is append the approach to my
current flightplan so that I can transition en route to the approach
without further programming. But I'm concerned that a loaded,
unactivated approach will cause the 430 not to switch to approach
senstivity. I tried this in the simulator and found that it seems to
work fine, the sensitivity changes 2nm from the FAF and all is well;
but I'm hesistant to start using the method in the A/C.
Can someone else verify that it is ok? What method do you use?
Old February 16th 08, 05:04 AM posted to rec.aviation.ifr
Stan Prevost
So you are f lying along, direct KABC. You have loaded an approach and
selected an IAF. How do you expect the box to know when to switch from
having the TO Waypoint being the airport to having it be the IAF?
Activating a loaded approach is really a trivial action. PROC, ENTER. Not
exactly programming.
"Terence Wilson" wrote in message
Old February 16th 08, 02:38 PM posted to rec.aviation.ifr
Sam Spade
Default Garmin 430 rquestion- does the approach always have to be activatedvia "activate approach"?
You don't quite understand the activate approach function. It should
seldom be used. It's primary purpose is for a "pop up" VFR operation to
go from VFR directly to an IAF and begin a full approach.
The normal procedure is to load the approach. It will always activate
on its own two miles prior to the FAF.
Old February 16th 08, 04:27 PM posted to rec.aviation.ifr
SimGuy
On Fri, 15 Feb 2008 23:04:53 -0600, "Stan Prevost"
The point is this- loading the approach makes the IAF the active
waypoint, which I may or may not want.
Old February 16th 08, 04:29 PM posted to rec.aviation.ifr
Terence Wilson
On Sat, 16 Feb 2008 06:38:42 -0800, Sam Spade
OK thanks. That was the source of my confusion. I wasn't sure whether
there was something magic about activation. It sounds like the only
purpose of activation is to set the IAF as the active waypoint.
Thanks.
Old February 16th 08, 04:47 PM posted to rec.aviation.ifr
Mitty
On 2/16/2008 10:27 AM, SimGuy wrote the following:
No, it doesn't.
Old February 16th 08, 05:49 PM posted to rec.aviation.ifr
Thomas Borchert
Terence,
Hmm. You have me very confused now. What's wrong with the IAF, if
that's where the full approach starts (you mentioned no RV)?
Thomas Borchert (EDDH)
Old February 16th 08, 06:10 PM posted to rec.aviation.ifr
Terence Wilson
No, it doesn't.
Sorry, I meant to say "activating".
Old February 16th 08, 06:14 PM posted to rec.aviation.ifr
Terence Wilson
On Sat, 16 Feb 2008 18:49:42 +0100, Thomas Borchert
Terence,
Well suppose I am enroute and approaching the SGD VOR. At this point I
am getting close to my destination and want to setup the KCCR VOR
approach which starts at the CCR IAF. If I load and activate the
approach a megenta line will immediately be drawn from my present
position to CCR. Want I want is the route SGD, CCR ... KCCR.
Old February 16th 08, 06:46 PM posted to rec.aviation.ifr
Thomas Borchert
Terence,
I see. In that case, what's wrong with loading the procedure and then
waiting with activation until passing SGD.
Also, upon rereading the 430 manual I noticed that activating
vectors-to-final will always get you to the FAF. I could find no mention
of the automatic activation mentioned by someone. However, automatic CDI
switching (to VLOC) will only happen on an activated procedure, it
seems.
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 12:54 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:36 AM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 03:28 PM
"End of an era: USN's Tomcats make their final approach before decommissioning" Mike Naval Aviation 15 April 5th 06 03:45 AM
