JJ Sinclair wrote:
	Brad, I wouldn't brush on the primer, half your sanding will be to just remove the brush marks. You can get a cheap gun and compressor for this. It is usually best to use the primer that is recommended by the paint you are using, but most are gray in color and this will start to show through if (when) you get a little to heavy handed with the wet sanding during the finishing process. That is why I use PCL Polyprimer, because it is pure white and believe me white is the way to go. You do need good ventilation any time your spraying anything, not only to prevent trapping unwanted by-products in the paint, but you don't want to be trapping any of this stuff in your lungs, either! That is REALLY true when using uretahne, we had a mechanic here who recovered a Cub in the dead of winter with propane heaters running inside the shop. He didn't want to ventilate because he would lose all his heat. Then he sprayed urethane in the same environment (probably with just a dust mask)........................anyway, he is no longer with us! From personal experience, I was spraying uerthane one evening and started to lose my peripheral vision, then I tightened up the mask and got it back! Scary stuff, I could have passed out, alone inside a paint booth full of stuff that can kill you. I use a resporator now, not too expensive, $300'ish from Spruce and Specialty. Oh, my how I have carried on and we haven't even touched on the biggest proplem you will face. Pumping water droplets out of your spray gun. Got to go wet sand yesterdays paint............. JJ JJ, you mean supplied air system, right? The box w/ a fan that sits where the clean air is and the fan pumps the clean air through a hose to your mask.  |
On Aug 25, 10:09*am, Nyal Williams  wrote:
	I have a very lightly used Graco HVLP spray system that I'd be willing to sell. *It eliminates oils and moisture introduced by a compressor. *It is complete with mask to deliver fresh, outside air under positive *pressure to the wearer. *Write privately for details. At 15:13 25 August 2008, PMSC Member wrote: On Aug 25, 10:24 am, JJ Sinclair *wrote: Brad, I wouldn't brush on the primer, half your sanding will be to just remove the brush marks. You can get a cheap gun and compressor for this. It is usually best to use the primer that is recommended by the paint you are using, but most *are gray in color and this will start to show through if (when) you get a little to heavy handed with the wet sanding during the finishing process. That is why I use PCL Polyprimer, because it is pure white and believe me white is the way to go. You do need good ventilation any time your spraying anything, not only to prevent trapping unwanted by-products in the paint, but you don't want to be trapping any of this stuff in your lungs, either! That is REALLY true when using uretahne, we had a mechanic here who recovered a Cub in the dead of winter with propane heaters running inside the shop. He didn't want to ventilate because he would lose all his heat. Then he sprayed urethane in the same environment (probably with just a dust mask)........................anyway, he is no longer with us! From personal experience, I was spraying uerthane one evening and started to lose my peripheral vision, then I tightened up the mask and got it back! Scary stuff, I could have passed out, alone inside a paint booth full of stuff that can kill you. I use a resporator now, not too expensive, $300'ish from Spruce and Specialty. Oh, my how I have carried on and we haven't even touched on the biggest proplem you will face. Pumping water droplets out of your spray gun. Got to go wet sand yesterdays paint............. JJ My $0.02 on iso-cyanates and urethane paint: Back around 1990 I painted a ship with Deltron Acrylic Urethane (PPG). The results were great... However, I will not be doing that again. Urethanes are simply too toxic for this amateur. *Iso-cyanates are incredibly bad news. *How bad? *To give an idea: I walked back into my "booth" without protection about an hour after spraying the fill coat (K-201 iirc) on one wing and almost instantly had bronchial constriction and a really nasty head buzz. No more than 60 seconds exposure an hour after spraying.... *Scared the hell out of me. *If you must do this... at least be aware of who is down wind and how far. *If you decide to cheap out and forge ahead with a carbon filter mask instead of a proper air-supply system, change the filters frequently and don't wait for odor to become noticeable through the mask, cause you'll be sorry. *Furthermore, wear the mask any -- I mean *any* -- time the paint is open including mixing. Take the warnings seriously. Today's mad hatter is more likely to be an auto body guy. *Doubt me? Go hang at the local body shop and see what you see. *There's no way to do this stuff with zero exposure. I've sprayed Imron and Deltron with just a chemical filter mask, but wouldn't do it again. Interestingly enough methyl isocynate is what was released in the Bhopal disaster. Nasty stuff. http://www.ncbi.nlm.nih.gov/pubmed/8277516 Craig  |
"Brad"  wrote in message
	... thanks for the comments and suggestions guys. as to the amount of gas we burned that night, Bob K might know, it was in his shop where we layed up the skins............. I am leaning now towards JJ's suggestion and not go with the Prestec. I have pretty crude painting facilities at my shop (read none) so I hope the PPG products can tolerate a less than ideal spraying environment. FWIW I sprayed a 26' boat a few years ago with AwlGrip under rather primitive conditions - came out great. I had a "tent" with a tarp for the floor, another tarp for the roof and sheet plastic walls out in the middle of a gravel boat yard. I did it in the spring when the days were warm enough, but I ran a propane heater overnight to keep the temperature up to allow the paint to cure (lots of moisture). It turned out to be real easy to spray (I last painted cars back in the '70s) - went on nice, flowed out nice. I ended up with one sag in the finish coat (my face shield was so fogged up with overspray at the end I really couldn't see good enough). No problems with adhesion and the boat has been outside in the weather ever since. Do yourself a favor and use outside air. Per the data sheets the iso-cyanawhatever has "poor warning properties" - by the time you realize it is coming through your mask, it is too late... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate.  |
			 JJ, you mean supplied air system, right? Yes, I have a spray booth with florescent lights, but find I need a drop cord light also (old eyes), so I'm dragging 2 air hoses and a drop cord. This can end up in a gigantic tangeled mess, so I have taken to taping them all together every 3 feet or so. Works well. Right now, I'm doing a little repair to a 26 rudder which involves color matching old gelcoat. Gelcoat ages (oxidizes) and turnes yellow, but when I sand out the edges of my repair I sand out the yellow and therefor must do a color match in this 'sanded' area. I find it works best to extend the 220 sanding a good 4 inches beyond the repair area and then scrub down another 4 inches with abrasive cloth beyond this area before masking off the rest of the rudder. I then spray on 3 coats, extending the paint edge an inch each pass, so that the final paint line is at the end of the 220 sanding. The overspray is on the scrubbed area and my masked line isn't covered with paint. 18 hours later the overspray area can be knocked down with a few passes of 600w up to, but not over the mask line. Then I go over the mask line with the 800w and blend in (remove yellow) on down the rudder so as to show a gradual blending of sanded white into non-sanded yellowish white. If you bury the mask line with paint, it is too easy to go through the old paint and show primer...........ugh! I hate painting, JJ  |
JJ,
	You may hate painting, but I am very glad an artist like you is repairing my ASH26E rudder . . . thanks! bumper "JJ Sinclair" wrote in message ... JJ, you mean supplied air system, right? Yes, I have a spray booth with florescent lights, but find I need a drop cord light also (old eyes), so I'm dragging 2 air hoses and a drop cord. This can end up in a gigantic tangeled mess, so I have taken to taping them all together every 3 feet or so. Works well. Right now, I'm doing a little repair to a 26 rudder which involves color matching old gelcoat. Gelcoat ages (oxidizes) and turnes yellow, but when I sand out the edges of my repair I sand out the yellow and therefor must do a color match in this 'sanded' area. I find it works best to extend the 220 sanding a good 4 inches beyond the repair area and then scrub down another 4 inches with abrasive cloth beyond this area before masking off the rest of the rudder. I then spray on 3 coats, extending the paint edge an inch each pass, so that the final paint line is at the end of the 220 sanding. The overspray is on the scrubbed area and my masked line isn't covered with paint. 18 hours later the overspray area can be knocked down with a few passes of 600w up to, but not over the mask line. Then I go over the mask line with the 800w and blend in (remove yellow) on down the rudder so as to show a gradual blending of sanded white into non-sanded yellowish white. If you bury the mask line with paint, it is too easy to go through the old paint and show primer...........ugh! I hate painting, JJ  |
On Aug 26, 11:43*am, "bumper"  wrote:
	JJ, You may hate painting, but I am very glad an artist like you is repairing my ASH26E rudder . . . thanks! bumper "JJ Sinclair" wrote in message ... JJ, you mean supplied air system, right? Yes, I have a spray booth with florescent lights, but find I need a drop cord light also (old eyes), so I'm dragging 2 air hoses and a drop cord. This can end up in a gigantic tangeled mess, so I have taken to taping them all together every 3 feet or so. Works well. Right now, I'm doing a little repair to a 26 rudder which involves color matching old gelcoat. Gelcoat ages (oxidizes) and turnes yellow, but when I sand out the edges of my repair I sand out the yellow and therefor must do a color match in this 'sanded' area. I find it works best to extend the 220 sanding a good 4 inches beyond the repair area and then scrub down another 4 inches with abrasive cloth beyond this area before masking off the rest of the rudder. I then spray on 3 coats, extending the paint edge an inch each pass, so that the final paint line is at the end of the 220 sanding. The overspray is on the scrubbed area and my masked line isn't covered with paint. 18 hours later the overspray area can be knocked down with a few passes of 600w up to, but not over the mask line. Then I go over the mask line with the 800w and blend in (remove yellow) on down the rudder so as to show a gradual blending of sanded white into non-sanded yellowish white. If you bury the mask line with paint, it is too easy to go through the old paint and show primer...........ugh! I hate painting, JJ- Hide quoted text - - Show quoted text - AMEN.... JJ's the man! Dan Rihn WO  |
On Aug 24, 9:28*am, Brad  wrote:
	Propane releases moisture during combustion... Correct me if I'm wrong, but I'd expect that oxidizing propane would only release moisture into the exhaust gasses. My heater setup vents all of the combustion exhaust gasses outside the building. I figure it'd have to, or else we'd all have died from CO poisioning by now. Thanks, Bob K.  |
On Aug 26, 2:09*pm, Bob Kuykendall  wrote:
	On Aug 24, 9:28*am, Brad wrote: Propane releases moisture during combustion... Correct me if I'm wrong, but I'd expect that oxidizing propane would only release moisture into the exhaust gasses. My heater setup vents all of the combustion exhaust gasses outside the building. I figure it'd have to, or else we'd all have died from CO poisioning by now. Thanks, Bob K. Was Brad using a Space Heater, or a forced air gas furnace like you have? I wouldn't think your heater would be a problem.  |
On Aug 26, 4:18*pm, Uncle Fuzzy  wrote:
	Was Brad using a Space Heater, or a forced air gas furnace like you have? I wouldn't think your heater would be a problem. Brad laid up his fuselage shells at my shop, using my shop heater, not a space heater. It's a Modine Hot Dawg 75 kbtu unit I put up several years ago. In the past I've used kerosene and propane space heaters, but mostly just with quickie polyester/glass layups. Those things give me the willies, I'm always worried about carbon monoxide poisoning. Thanks, Bob K.  |
On Aug 26, 5:07*pm, Bob Kuykendall  wrote:
	On Aug 26, 4:18*pm, Uncle Fuzzy wrote: Was Brad using a Space Heater, or a forced air gas furnace like you have? I wouldn't think your heater would be a problem. Brad laid up his fuselage shells at my shop, using my shop heater, not a space heater. It's a Modine Hot Dawg 75 kbtu unit I put up several years ago. In the past I've used kerosene and propane space heaters, but mostly just with quickie polyester/glass layups. Those things give me the willies, I'm always worried about carbon monoxide poisoning. Thanks, Bob K. That's what I thought. Unfortunately, that kinda' decreases the chances that excess moisture in the air caused the epoxy not to bond to the gelcoat.  |
| Grob gelcoat | Gary Emerson | Soaring | 1 | December 19th 07 06:55 AM |
| Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 09:07 PM |
| First Glider no gelcoat | Doug Reeve | Soaring | 0 | February 10th 06 11:05 AM |
| Ferro gelcoat | Basil Fairston | Soaring | 0 | December 16th 03 09:34 AM |
| Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 08:29 AM |
