Gelcoat sag?
Old December 15th 07, 06:42 PM posted to rec.aviation.soaring
Default Gelcoat sag?
Hey guys. I've got a question regarding wing "waviness". I've got an
LS1f with very good gelcoat condition. However, if I look down the
wing long-ways, just above the leading edge I can see what looks like
a series of 4"-6" diameter lumps (for lack of a better term). They're
somewhat regularly spaced along the full length of both wings and are
parallel to the leading edge. They are very, very subtle, and you
can't really see them without looking from the correct angle to use
the glossy reflection. They're very similar on both wings and are in
the 4"-8" range up from the leading edge. I've done some "tap tests"
to see if I could detect delamination, but the wing surface is
consistently solid all over. I'm thinking this might be gelcoat "sag"
and/or just improper sanding during the last refinish. Do refinishers
have rigs to "rotate" the wings (on the spar) as they're spraying? It
almost seems like after spraying the top of the wings, they were
rotated to a position where this point of the wing was the lowest
allowing sag there. Anyone have any thoughts or comments as to what
this might be? Besides these defects, the rest of the wing surfaces
are consistently smooth and uniform.
The description of the wing refinish in the log indicates the
following:
- acrylic enamel (from previous refinish) and factory gel coat removed
via sanding
- primed with Simtec primer
- sanded with 100 grit
- primed again with Simtec primer
- sanded with 120 grit
- series of coats of Simtec white to thickness of 6-8 mils
- sanded with 180 grit
- series of coats of Simtec white to thickness of 8 mils
- wet sanded with 1000 grit
- wet sanded with 1200 grit
- wet sanded with 1500 grit
- power buffer with 3M finesse #1
- power buffer with 3M finesse #2
There's nothing in the log that refers to profiling or shaping. Only
"sanding" and "polishing". If any attempts were done to shape and/or
profile, do you think that would have been logged along with the rest
of the description? There's two and a half pages devoted to this
refinish job, so it's not like he left much out.
The ship flies beautifully, and sure seems to have good legs relative
to it's published performance numbers. I don't think these surface
defects are pronounced enough to be having any large effect on
performance, but I haven't tried any serious attempts at performance
testing either. At this time I guess I'm more interested in knowing
what they are. Although there will probably come a time when I'd like
to remedy it for the performance improvements if there are any to be
had.
Dave
Old December 15th 07, 09:19 PM posted to rec.aviation.soaring
following:
via sanding
had.
Dave
Experienced racers have long known about the dreaded sag.
We store our wings trailing edge down over the winter and they
revert back to correct shape for the next season.
See ya, Dave
PS: RAS = Rabid Aviation Speculation ;-)
Old December 15th 07, 09:57 PM posted to rec.aviation.soaring
Papa3
following:
via sanding
had.
Dave
Dave,
Just speculating here, but either something's missing from the logs,
your transcription of the logs is off, or ... well... something
doesn't quite make sense.
After spraying with the Simtec sandable primer, it sounds like the
refinisher sanded with 120 grit. Sounds a bit coarse to me, but
okay. Assuming it was sanded with a machined-flat bar, the wing was
probably pretty smooth at that point. Next was a coat of the white
Simtec followed by a 180 grit sanding. Okey doke. Still pretty
smooth. Next is multiple build coats of white but no sanding below
1,000 grit? Unless this guy (gal) was the best spray artist known to
man (or at least known to glider refinishing), there are bound to be
some waves introduced with multiple coats. I've never heard of
anyone NOT doing another pass with 200 grit or at least 400 grit
(followed by 600, 800) to smooth stuff out. Assuming the wing was
resting trailing edge down, I can easily see where you would get
exactly the kind of sag/ build-up you describe.
Maybe JJ or someone who did/does this for a living can chime in, but
I've never seen it done the way you describe.
BTW, if you really wanna see how bad the bumps are try this: Thin
some colored dope down to a fairly runny consistency and wipe it over
the suspect area with a paper towel. Take a piece of thin plastic
sheet and form it to the curve of the wing. Run it spanwise trying to
hold firm but consistent pressure (like you're screeding grout across
a tile). You'll be able to see the high spot/ low spot due to the
contrast.
That's my non-professional assessment.
P3
Old December 15th 07, 11:22 PM posted to rec.aviation.soaring
following:
via sanding
had.
Dave
See ya, Dave
PS: RAS = Rabid Aviation Speculation ;-)- Hide quoted text -
- Show quoted text -
You mean "cured" gelcoat can sag from sitting in the trailer over the
winter? That wouldn't have occurred to me. That's interesting. The
only thing that doesn't add up is that this is only in the one area on
top of the wings just behind the leading edge. Bottom of the wings are
fine. Leading edge is fine, which is the lowest point when stored.
Old December 15th 07, 11:32 PM posted to rec.aviation.soaring
following:
via sanding
had.
Dave
Dave,
contrast.
P3- Hide quoted text -
Yeah, the log is fairly explicit with the sequence of work done,
although I did summarize it. However, I looked over it again and
haven't missed anything. There definately is no mention of machined
sanding bars or such. Only the grit used for each sanding step in the
process. It's certainly possible that some details were not recorded
in the log. I may try to contact the person that did the work, but
this was in 1993. Just so happens that he was the owner at that time
and also an A&P. That might make for better memory retention since it
was his ship. We'll see.
What kind of "dope" are you referring to? The only thing that comes to
my mind is "aerogloss dope" I used to use on model planes when I was a
kid. I'm sure that's not what you're talking about
Old December 15th 07, 11:42 PM posted to rec.aviation.soaring
Papa3
following:
via sanding
had.
Dave
Dave,
contrast.
kid. I'm sure that's not what you're talking about- Hide quoted text -
Quick follow ups:
1. Dave Nadler was joking.
2. The sanding bar is pretty standard. Everything about the job as
described sounds first rate, so I would pretty much assume the
refinisher did it right. The only curious bit is the lack of any
further smoothing after the last round of build coats. At minimum
you usually end up with some orange peel and a few runs here and
there, and those won't come out with 1,000 grit unless there's some
magic that I don't know about.
3. Yup, aerogloss dope thinned with dope thinner.
See this great article that Ken Kochanski put together. It gives you
some context (and appreciation) of what goes into a wing refinish.
http://sailplane-racing.org/Articles...asw20_wing.htm
Old December 16th 07, 04:55 AM posted to rec.aviation.soaring
Bob Kuykendall
In the right light, a shiny surface will show you contour disruptions
down to a handful of ten-thousandths of an inch.
If you run a waviness gage over it and get .004" or less, you've got a
lot more pressing things to worry about.
Thanks, Bob K.
Old December 16th 07, 04:01 PM posted to rec.aviation.soaring
user
Dave,
I stand mine up on end, tip down. I find this works a little better than
trailing edge down, though I think most don't have the facilities. Main
thing is that you don't let the gelcoat set in any particular position over
the winter as the low temperatures will tend to make the waves permanent.
Best of all would be a warm room (above 60F) where you have the sapce to
turn them - almost like a giant, low heat rotisserie.
Missed you at R4N. Hope you can make it in 08.
following:
via sanding
had.
Dave
See ya, Dave
Old December 17th 07, 01:52 AM posted to rec.aviation.soaring
On Dec 16, 9:01 am, "user" wrote:
Dave,
following:
via sanding
had.
Dave
See ya, Dave
That's just mean! LOL!
Old December 17th 07, 02:42 PM posted to rec.aviation.soaring
Andy[_1_]
I know this reply was in jest but at Hobbs years ago I got into
conversation with a DG owner. I forget who it was or what the glider
type was. He told me that the gell coat on his wings had sagged. He
also told me the factory had told him it was due to being stored in
the trailer above a maximum temperature approved by the factory. He
seemed upset enough about the problem that I assumed it was true. I
have never heard of this happening to anyone else and don't pretend
to understand the physics that could allow it to happen.
Andy
First Glider - No Gelcoat Waduino Soaring 30 February 12th 06 07:58 AM
First Glider no gelcoat Doug Reeve Soaring 0 February 10th 06 11:05 AM
Gelcoat and solvents Nolaminar Soaring 7 May 17th 04 12:15 AM
Ferro gelcoat Basil Fairston Soaring 0 December 16th 03 09:34 AM
Refinishing gelcoat tango4 Soaring 21 November 3rd 03 08:29 AM
