I can't seem to find a local dealer with 165R13 trailer tires. Can
anyone tell me where to get suitable tires or if you substituted something else e.g. 175/80R13 or similar and how that worked out. Thanks, IC |
On May 11, 10:32*pm, wrote:
I can't seem to find a local dealer with 165R13 trailer tires. *Can anyone tell me where to get suitable tires or if you substituted something else e.g. 175/80R13 or similar and how that worked out. Thanks, IC I use 185/70R-13 on 1985 Komet. No issues. -T8 |
On May 12, 6:51*am, wrote:
On May 11, 10:32*pm, wrote: I can't seem to find a local dealer with 165R13 trailer tires. *Can anyone tell me where to get suitable tires or if you substituted something else e.g. 175/80R13 or similar and how that worked out. Thanks, IC I use 185/70R-13 on 1985 Komet. *No issues. -T8 Check out the conversion chart here. Confirms that 185/70R-13 is a compatible configuration. It's been a long time, but I remember my local dealer being unable to find 165R13s... http://www.tirerack.com/tires/tirete...sionchart.html |
Trying to keep the overall diameter of the replacement tire the same
as for the orginal equipment tire isn't absolutely mandatory. Some pilots use taller tires to get the back end of the trailer up higher for more clearance when pulling out of a driveway, though that could complicate rigging the glider with the trailer still hitched to the tow vehicle. Other pilots swap the wheels for larger, wider ones and mount low aspect ratio tires for more sidewall stiffness and (hopefully) more stable towing, although this combination can give a harsher ride. One of the most fundamental factors if you're keeping the original wheels is wheel size, specifically width. Lower aspect ratio tires may require wider wheels. You'll have to check your current wheels against the allowable spec for the new size tires to be sure they're OK. Chip Bearden ASW 24 "JB" USA |
Komet Trailer gas struts | HL Falbaum[_2_] | Soaring | 13 | February 1st 09 01:05 PM |
Old Komet Trailer | thermalrider | Soaring | 7 | October 11th 08 04:13 PM |
Komet Trailer Rims | Tim Hanke | Soaring | 6 | February 28th 06 04:56 PM |
KOMET Trailer Cradle | [email protected] | Soaring | 3 | September 27th 04 04:33 AM |
Komet trailer strut | John Shelton | Soaring | 5 | November 15th 03 05:04 PM |
