#11
At 21:40 06 December 2010, shkdriver wrote:
Anyone have any experience/thoughts to share about winch launching a shempp-hirth SHK? My example has CG tost hook on gear leg. Thanks, Scott W. Scott, I had a 17m SHK many years ago. The difference between minimum and maximum all up weight was about 20 lbs which made one very careful about spinning. I never had problems launching behind a car, but a very experienced pilot at Lasham spun his in from a wire launch. Are you fully experienced on winch launching? A modern high power winch is rather different to the F100 trucks we used to use for launching, and I would say that the SHK could bite a little more than some gliders if you are too sudden with your pull up or if you pull too hard. A V tail is not the same as a normal T tail, and I imagine that turbulent air off the wing at a high angle of attack could possibly cause issues. I enjoyed the glider very much, but you need to be very careful rigging the main pin (if you are not aware of this then please do research the issue, it is on the internet - we had a fatality in the UK this year I believe because of mis-rigging with this system which is very easy to do) and watch the CofG and spin characteristics. It will bite if you deviate too far from best practice on winch launching. The BGA has published very good notes on winching. If you already have experience with the SHK and / or you are a higher hours pilot, then it is fine so long as you treat it with a little more respect than, for example, a K6e. Mike |
On Dec 6, 2:40*pm, shkdriver
wrote: Anyone have any experience/thoughts to share about winch launching a shempp-hirth SHK? My example has CG tost hook on gear leg. Thanks, Scott W. -- shkdriver A caution not specific to the SHK but it may apply. For the first winch launch in any new glider type pay particular attention to seat back and rudder pedal adjustment. There should be no possibility that you will slip backward during the launch. I learned this one the hard way. I had quite a few hours in the Std Jantar, all aero tow. On my first winch launch I slid backward so my feet were not in contact with the pedals. I continued the launch with my elbows frantically clawing for grip on the cockpit side walls but was able to remain in control. Every other glider I had winched had a more upright seating position so I had never seen this problem before. Andy |
On Wed, 08 Dec 2010 06:20:37 -0800, Andy wrote:
A caution not specific to the SHK but it may apply. For the first winch launch in any new glider type pay particular attention to seat back and rudder pedal adjustment. There should be no possibility that you will slip backward during the launch. I've heard this said about the Discus 1 as well, but though I've winched them quite a bit I've not experienced it myself so it must only apply to pilots who prefer a seating position that's different from mine. I can imagine that with the seat fairly well forward the straps would be pretty much horizontal behind your shoulders and so won't to a lot to stop you sliding up the back of the seat. Bottom line: Making quite sure your straps are tight is even more important for winch than aero-tow due to the higher initial acceleration and much steeper climb-out. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Dec 8, 3:57*am, Michael Clarke
wrote: At 21:40 06 December 2010, shkdriver wrote: Anyone have any experience/thoughts to share about winch launching a shempp-hirth SHK? My example has CG tost hook on gear leg. Thanks, Scott W. Scott, I had a 17m SHK many years ago. The difference between minimum and maximum all up weight was about 20 lbs which made one very careful about spinning.. I never had problems launching behind a car, but a very experienced pilot at Lasham spun his in from a wire launch. Are you fully experienced on winch launching? A modern high power winch is rather different to the F100 trucks we used to use for launching, and I would say that the SHK could bite a little more than some gliders if you are too sudden with your pull up or if you pull too hard. A V tail is not the same as a normal T tail, and I imagine that turbulent air off the wing at a high angle of attack could possibly cause issues. I enjoyed the glider very much, but you need to be very careful rigging the main pin (if you are not aware of this then please do research the issue, it is on the internet - we had a fatality in the UK this year I believe because of mis-rigging with this system which is very easy to do) and watch the CofG and spin characteristics. It will bite if you deviate too far from best practice on winch launching. The BGA has published very good notes on winching. If you already have experience with the SHK and / or you are a higher hours pilot, then it is fine so long as you treat it with a little more respect than, for example, a K6e. Mike Good advice. There was an SHK winch fatal many years ago (Scotland?), where the pins were not fully home. The winch at Scott's club is not overly powerful, nor is it wimpy for a small block V-8. I've driven it. We had a phone chat a couple of evenings ago. Although it's been 29 years since I last winched in SHK S/N 1, I think I was able to provide the normal cautions and caveats. Sure was fun to soar 5 hours from a 50p ($1) launch;^) Scott's done his homework and actually did quite a few winch launches during his training in both the trainer and a light single seater, which is atypical for most US pilots. He's also driven the winch a fair amount. He doesn't have many hours in the SHK yet and is not in a big rush to jump on the winch with it. The club didn't use the winch much during the past year, but has committed to using it much more in the next, so he's looking forward to winching the Sh*t Hot Kite (Schempp-Hirth Kirchheim manager's description, not mine). Frank Whiteley |
On Dec 8, 2:20*pm, Andy wrote:
On Dec 6, 2:40*pm, shkdriver wrote: Anyone have any experience/thoughts to share about winch launching a shempp-hirth SHK? My example has CG tost hook on gear leg. Thanks, Scott W. -- shkdriver A caution not specific to the SHK but it may apply. * *For the first winch launch in any new glider type pay particular attention to seat back and rudder pedal adjustment. *There should be no possibility that you will slip backward during the launch. I learned this one the hard way. *I had quite a few hours in the Std Jantar, all aero tow. *On my first winch launch I slid backward so my feet were not in contact with the pedals. *I continued the launch with my elbows frantically clawing for grip on the cockpit side walls but was able to remain in control. *Every other glider I had winched had a more upright seating position so I had never seen this problem before. Andy Same thing happened to me in a DG101 a few years ago. Did a whole winch launch keeping the stick just off the backstop with my fingertips and with my feet nowhere near the rudder pedals. Always do your straps up really tight for a winch launch, and if possible set the rudder pedals a bit closer than normal. Only use firm cushions behind you. Derek C |
welding technique for clusters | wright1902glider | Home Built | 26 | March 27th 09 12:49 AM |
Question technique | Patrick R7 | Aviation Photos | 4 | September 30th 08 01:50 PM |
spinner trimming technique | Dick | Home Built | 0 | January 25th 05 11:57 PM |
instructor technique | Mike Stramba | Soaring | 8 | October 3rd 03 09:45 PM |
Flying Technique Question of the Day | Jim Vincent | Soaring | 24 | October 3rd 03 03:29 PM |
