Radiation Exposure in Sailplanes
Old February 14th 11, 12:28 AM posted to rec.aviation.soaring
bildan
Default Radiation Exposure in Sailplanes
On Feb 13, 9:41*am, Bob Whelan wrote:
On 2/13/2011 8:41 AM, db_sonic wrote:
I got an amazing sun tan under that old ASW19 canopy. *But nothing of
the sort with my DG800.
Anecdotal evidence may be indicating the canopy material of the 80's
and earlier simply let this radiation through?
Anecdotal evidence can be the best kind sometimes...it's from the real world!
I remember in 1972 or 1973 Wil Schuemann coming into the office one Monday
looking like a negative raccoon: pale around the eyes with thin pale stripes
from eyeball corners to his ears, and considerably redder everywhere else on
his face. He'd gotten that way soaring his ASW-12 (in MD, but I don't remember
whether in wave) wearing glass sunglasses and the usual goofy hat.
My subsequent under-canopy experience mostly in the intermountain west has
never replicated his. If it happens it must be possible...
Regards,
Bob W.
I saw that on a guy who tried arc welding using gas welding goggles.
Old February 14th 11, 03:06 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 2/13/2011 11:29 AM, brianDG303 wrote:
I've posted this before and hope I'm not boring everyone.
Using an excellent and expensive Crawford UV meter and testing a whole
line-up of gliders one day there was a distinct pattern of older
gliders passing UV and newer gliders not. Eric, one of these days
I'll be out at EPH the same time as you are and we can do some
research on the line-up out there, but we won't get wavelength charts
My sense of this issue is that higher quality plastics have more
chemicals in them to protect the plastic itself from UV damage and
that it is protecting us as an unintended consequence. Most plastics
used in the lighting industry are very good UV filters, for example
the lenses on under cabinet fluorescent fixtures usually are very good
even on the cheapest fixtures. On the other hand there is a very
nice, small German under cabinet fluorescent (Hera) that I used to
light part of a rare book collection and ended up having to add UV
film. UV film is cheap so it was no big deal.
Now we're talking evidence instead of anecdote! Can the meter quantify
the difference in transmission?
email me)
Old February 14th 11, 04:29 AM posted to rec.aviation.soaring
brianDG303[_2_]
gliders passing UV and newer gliders not. *Eric, one of these days
email me)
Well, the meter reads out total UV/sq.meter and UV as a % of total
light energy measured in microwatts per lumen ( –µW/ l) so if the
source of UV remains constant you could get a sense of the comparable
values, yes. Usually the source is daylight and it's changing from
moment to moment so an exact measurement would be tricky. In reality
what happens is that you stand next to a glider with the meter reading
huge amounts of UV and when you put the meter under the canopy of a
newer glider there is a radical drop in the reading. Because this is
indicating UV as a % of available light the tinting is not a factor at
all unless the tinting is reducing visible light but not blocking UV,
which I have seen in some residential glazing products. Anyway, DG
gliders for example have UV reduction to the point that I don't think
it's a factor at all. I still get sunburned but it's while I'm
rigging and not while I'm flying and I think that is going to be true
for many (most) other gliders and their owners. In museums there is
this blue fabric that they scatter around that fades at a given rate
in the presence of UV and works as a warning, it would be nice if
there was something like that for this application.
Brian
Brian
Old February 20th 11, 06:06 AM posted to rec.aviation.soaring
2G
email me)
values, yes. *Usually the source is daylight and it's changing from
moment to moment so an exact measurement would be tricky. *In reality
newer glider there is a radical drop in the reading. *Because this is
which I have seen in some residential glazing products. *Anyway, DG
it's a factor at all. *I still get sunburned but it's while I'm
for many (most) other gliders and their owners. *In museums there is
Brian
Brian
The entire document below is available at http://www.plexiglas.com/literature/pdf/81.pdf
Plexiglas sheet absorbs the shorter wavelengths of
ultraviolet (UV) energy, but transmits most of the
longer wavelengths (those near the visible region),
Figure 5.The UV transmittance, unlike the visible
and infrared transmittance, of colorless Plexiglas sheet
varies from one formulation to another.Therefore,
Plexiglas MC sheet does transmit slightly more of the
longer UV wavelengths than does Plexiglas G sheet.
Even after prolonged outdoor or artificial light
exposure, the spectrophotometric characteristics of
Plexiglas sheet in the UV and visible ranges do not
change significantly. Most of the drop in UV transmittance
of Plexiglas sheet takes place in the first two
years after exposure to sunlight. No measurable change
occurred in the spectrophotometric curves of these
exposed samples between 5 and 10 years outdoors.
Colorless Plexiglas sheet exhibits the same excellent
resistance to discoloration when exposed for 20 years
or more to constantly lit fluorescent lamps, even when
the Plexiglas sheet is only two inches from the lamp.
This unsurpassed UV stability gives Plexiglas sheet
superb weatherability and makes it the logical choice
among plastic materials for outdoor and artificial
lighting applications. Other transparent plastic materials
tend to yellow or develop appreciable haze levels
when exposed to UV energy.
The spectrophotometric curves in Figure 5 show the
light transmission of colorless Plexiglas sheet formulations
in the UV bands of the electromagnetic spectrum.
Note that regular Plexiglas G and MC sheets block
some portions of the UV spectrum, but special grades
are needed when virtually all (UF-3/UF-5) or most
(UF-4) of the UV wavelengths must be excluded.
PLEXIGLAS ULTRAVIOLET–
FILTERING FORMULATIONS
Some special formulations of Plexiglas acrylic plastic
have spectrophotometric characteristics that enable
them to filter out almost all of the UV energy.These
formulations are available in both sheet and molding
resins. Plexiglas UV-filtering materials offer protection
from structural damage caused by exposure to UV
wavelengths shorter than 400 nanometers. However,
since these materials do not appreciably filter visible
light in the critical lower violet range from 400 to
500 nanometers, they will not completely prevent
colors from fading or darkening.
Limiting exposure to light is only one of the steps that
can be taken to slow the deterioration of materials.
Factors such as temperature, humidity and atmospheric
contamination will also affect this process.
Three Plexiglas sheet formulations that can filter
UV light are available. Plexiglas UF-4 sheet absorbs
most ultraviolet radiation. Plexiglas UF-3 sheet
absorbs virtually all ultraviolet radiation and some
of the visible light in the violet wavelength region.
Plexiglas UF-5 sheet, a new, special formulation in
the MC grade for framing applications, filters the
maximum of harmful UV radiation. Figure 5 compares
the spectrophotometric curves of these three grades
with those of standard colorless Plexiglas G and
Plexiglas MC sheets. Note that the spectrophotometric
characteristics of the three Plexiglas UF sheet
formulations are the same, regardless of the thickness
of the sheet. Comparatively, the spectrophotometric
characteristics of Plexiglas G and Plexiglas MC sheets
change with thickness.
Plexiglas UF-3 and MC UF-5 sheets are the most
effective of the ultraviolet-filtering formulations of
Plexiglas acrylic. Not only do these materials absorb all
ultraviolet radiation (390 nanometers and below), but
they also absorb part of the relatively harmful visible
light in the critical violet (400-450 nanometers)
region. Plexiglas UF-3 sheet does absorb some visible
light, therefore it has a very faint yellow edge tint.
This tint is not objectionable in most applications.
Plexiglas UF-4 sheet may be used for those applications
in which the slight yellow tint of the other
materials is objectionable, such as unframed display
cases. Plexiglas UF-4 does transmit slightly more UV
energy than its counterpart, and, as a result, it is
somewhat less effective in retarding fading or darkening
of colors caused by visible light in the 400 to 500
nanometer range.
Old February 20th 11, 03:20 PM posted to rec.aviation.soaring
Steve Rathbun
whol=
e
gliders passing UV and newer gliders not. =A0Eric, one of these
days
charts
quantify
to
email me)
“Plexiglas sheet absorbs the shorter wavelengths of
years after exposure to sunlight. No measurable change”
“Three Plexiglas sheet formulations that can filter
maximum of harmful UV radiation.”
From reading this material we are led to believe that most acrylic
Plexiglas does not transmit most UV light and does not degrade much itself
when exposed to sunlight.
Why then the high rate of UV transmission in older canopies? Was there a
different formula for the acrylic that was used to make canopies in the
70s and 80s? If so, when did the formula change?
Have these older canopies degraded over time due to exposure or were they
always unable to filter UV?
R5
Transponder antenna radiation [email protected] Home Built 7 March 12th 07 02:39 PM
Transponder antenna radiation [email protected] Home Built 0 March 4th 07 03:13 PM
Transponder andtenna radiation [email protected] Home Built 0 March 4th 07 03:08 PM
UV exposure [email protected] Soaring 3 October 27th 06 06:35 AM
Radiation hazard? Allen Thomson Military Aviation 10 September 18th 04 12:44 AM
