USB Serial Converters - Reliable one for SN10 and Volkslogger
Old June 21st 12, 02:19 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
Default Flarm Display Mount
Walt, interesting mount for the display. Looks like the standard
Butterfly backplate and Ram ball, but with a custom mount from the Ram
ball to the siderail.
Can share some information about your display mount installation?
Bob
On Wed, 20 Jun 2012 10:25:31 -0700 (PDT), WaltWX
Follow up on PF Brick install:
Photos of Discus 2A PowerFlarm antenna install on panel cover. ADS-B is forward antenna; FLARM is rear most one.
The hook forward on panel cover is where I locate my SPOT tracker. GPS antennas are under cover between two PF
top antennas (Volkslogger and PF GPS). ADS-B and FLARM antennas are taped to a piece of "L" shaped plexiglass
(2x2x3 inches) all velcroed to panel top. Got the plexiglas from Staples Office and "hacked" it from the original purpose
of displaying 81/2x11inch announcements.
No compass to worry about. Interestingly enough, Discus 2A ops manual didn't require one nor did the FAA when
I got my experimental certificate.
RAM mounted Butterfly is also visible.
https://dl.dropbox.com/u/463771/MyGl...a_SideView.JPG
https://dl.dropbox.com/u/463771/MyGl...aButterfly.JPG
Walt Rogers, WX
Old June 21st 12, 02:26 AM posted to rec.aviation.soaring
Brad[_2_]
Bob
top antennas (Volkslogger and PF GPS). ADS-B and FLARM antennas are taped to a piece of *"L" shaped plexiglass
https://dl.dropbox.com/u/463771/MyGl...d/PFlarm_Discu...
Walt Rogers, WX
Pardon the dumb question.............but does Power Flarm have a
logger function at all right now? if so, is the mini SD the way to
access the file?
I bought the stand-alone unit and it is installed in my glider right
now...........I have a cable on order to replace the Garmin puck that
I am using to feed GPS to my Ipaq310.......the interface will be via a
Goddard PS-5a, hope to just remove and replace the puck with the PF
and make a change to LK8000 baud rate.
Brad
Old June 21st 12, 03:00 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Wed, 20 Jun 2012 18:26:07 -0700 (PDT), Brad
The IGC logger function is currently listed as a future upgrade (via
software upload) for both brick and portable.
For the portable, yes, the miniSD will be the access point.
Bob
.... text deleted.
access the file?
Brad
Old June 21st 12, 01:22 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I believe Walt make his own RAM mount for the FLARM remote display.
I sell a very nice one from Butterfly he
http://www.cumulus-soaring.com/butte...-Disp-Rect-RAM
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_____________________________________
"Bob Gibbons" wrote in message
Bob
Walt Rogers, WX
Old June 21st 12, 03:42 PM posted to rec.aviation.soaring
Darryl Ramm
I would also expect PowerFLARM to support standard FLARM style downloading
of the IGC file via its serial port to PDAs/computers etc. Widely supported
in existing 3rd party applications (SeeYou, ConnectMe, XCSoar, etc.) and in
FlarmTool.
Darryl
Bob
... text deleted.
access the file?
Brad
Old June 22nd 12, 07:32 AM posted to rec.aviation.soaring
WaltWX[_2_]
Here a picture of the attach point for the RAM mount (9/16inch ball).
https://dl.dropbox.com/u/463771/MyGl..._PNA_Mount.JPG
Volkslogger downloads with high-speed serial port & OLC submission Bill Daniels Soaring 4 April 18th 06 06:11 AM
USB-to-serial converters that work (especially with ILEC SN10) ? [email protected] Soaring 35 May 27th 05 09:58 AM
FS - ILEC SN10 and Volkslogger Dave Springford Soaring 0 March 7th 05 12:43 AM
5 volt DC power converters John Ferguson Soaring 6 February 28th 04 07:15 AM
