Compass Questions ?
Old July 14th 15, 12:36 AM posted to rec.aviation.piloting
Bob
Default Compass Questions ?
Hello,
Not a Pilot, but always interested in the engineering aspects.
This question came up, and I realize that I am not sure of a correct answer.
Regarding the compass heading that shows in the glass displays:
How is it derived ?
GPS ?
If not GPS, what ?
Is it then Magnetic or True ?
Does the Pilot have to correct for variation/declination changes during
a flight ?
Does aviation use True or Magnetic when discussing or flying ?
etc. ?
Thanks,
Bob
Old July 14th 15, 01:20 AM posted to rec.aviation.piloting
Larry Dighera
Hello Bob,
I'm unable to provide the answer as to the technology employed by
computer-generated displays to display magnetic information, but I would expect
something like a Hall device might be employed. As you implied, it could as
easily be derived from GPS data corrected for magnetic variation at the
particular location.
Magnetic/compass headings are not true, but magnetic. Navigation Sectional
charts http://skyvector.com/ are depicted in True coordinates, and the
pilot/navigator must correct for magnetic variation in drafting his flight
plan. ATC expects all course/heading numbers to be magnetic.
You'll find more information he
http://www.faa.gov/regulations_policies/handbooks_manuals/, and he
http://www.faa.gov/regulations_policies/handbooks_manuals/aviation/pilot_handbook/media/PHAK%20-%20Chapter%2015.pdf.
Hope that helps.
Best regards,
Larry Dighera
On Mon, 13 Jul 2015 18:36:54 -0400, Bob wrote:
Hello,
How is it derived ?
GPS ?
If not GPS, what ?
a flight ?
etc. ?
Thanks,
Bob
Old July 14th 15, 12:47 PM posted to rec.aviation.piloting
Bob
Hi,
Thanks for replies and help.
What I was referring to are the new, modern, "glass" displays where most
everything shown is derived
from transducers located elsewhere.
e.g. when a display shows a Heading of, e.g., 075, it is of course
getting this info. from some kind of transducer, located elsewhere.
Is it derived directly from GPS ?
A Hall effect compass ?
or,... ?
Thanks again; interesting subject.
Bob
On 7/13/2015 6:36 PM, Bob wrote:
Hello,
answer.
How is it derived ?
GPS ?
If not GPS, what ?
a flight ?
etc. ?
Thanks,
Bob
Old July 14th 15, 07:01 PM posted to rec.aviation.piloting
Don Poitras
Dave Doe wrote:
, Dave Doe says...
lid, Bob
says...
Hi,
or,... ?
Well I'm not sure on that - perhaps others will reply. However,
cellphones usually use one or more magnetometers (hope I spelt that
right ). A GPS can't get a magnetic heading, only True.
I play with Arduino's a bit - and Googling 'arduino magentometer' gives
a few results, eg...
http://bildr.org/2011/01/hmc6352/
http://bildr.org/2012/02/hmc5883l_arduino/
http://eclecti.cc/hardware/hmc5843-m...ry-for-arduino
I *assume* that the compass in a glass display uses the same sort of
technology.
Apologies to the apostrophe police - that's terrible!
Duncan.
The display in a glass panel is GPS course. You need a magnetic compass to know
your heading. The difference between the two is wind correction, magnetic
variation and compass deviation.
While I don't doubt that someone could create a device that would send
magnetic heading info to a glass panel, it would have to be some obvious
secondary display. You want to be looking at your true course if you want
to get from A to B.
Don Poitras
Old July 15th 15, 12:36 PM posted to rec.aviation.piloting
Dave Doe
In article , , Don
Poitras says...
Dave Doe wrote:
, Dave Doe says...
lid, Bob
says...
Hi,
or,... ?
technology.
Duncan.
to get from A to B.
The OP is asking about just about such a device. And it's clear they do
exist in a glass display (a compass that is).
Take for example, the Cessna website. If you navigate to say the Cessna
TTx - and check out the glass Avionics section, and look at Equipment
Details (rather than Standard Features), it specifies a Magnetometer ...
"GMU-44 Magnetometer (dual)"
Albiet a compass is almost obsolete and uncessary with todays navigation
equipment, but let's not forget runways - still lined up and named
magnetic. Makes me wonder when that will change.
Duncan.
Old July 15th 15, 12:56 PM posted to rec.aviation.piloting
Don Poitras
Dave Doe wrote:
In article , , Don
Poitras says...
Dave Doe wrote:
, Dave Doe says...
lid, Bob
says...
Hi,
or,... ?
technology.
Duncan.
to get from A to B.
Duncan.
You're right. I was wrong. It makes sense that the glass HSI would need
to work like the mechanical one and that gets set manually to the
current compass setting.
Don Poitras
Old July 15th 15, 04:39 PM posted to rec.aviation.piloting
Dallas
The heading information from the PFD comes from a directional gyro. The
directional gyro's drift is constantly corrected (slaved) by a magnetic
compass located in the tailcone on the airplane. The output of this compass
is electrically "enhanced" and amplified through a "flux gate".
Bottom line: A very accurate, stable, compass reading that never needs
adjustment.
Dallas
WTB: PZL KI-13 Compass Romeo Delta Soaring 1 October 30th 17 08:47 AM
Still have a compass? [email protected] Soaring 19 November 22nd 13 11:33 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 08:39 AM
Looking for a PZL compass Kirk Stant Soaring 8 February 12th 04 10:27 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 07:06 AM
