Factory installed com antenna in the fin.
Old February 2nd 16, 03:42 PM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Default Factory installed com antenna in the fin.
Hey Group,
I've got a 1975 Std, Cirrus new to me. I am replacing the com radio and in the process I deleted a poorly done splice in the coax cable with a rg-58 solder end.
After the bnc end was installed, I measured the resistance between the center and shield leads, I measured 0.9 ohms, thinking I had a stray shield wire or other problem, I removed the new bnc end and measured the bare end of the coax, still 0.9 ohms. Then I reinstalled the bnc end, same 0.9 ohms.
Does the special type of antenna in the tail has some weird ohm value?
Using a handheld I wouldn't miss if it fried, I measured swr and output watts, (using a MJF model 812B swr/watt meter)
watt output is 3-4, swr is 1.6-1.8 (in my garage, not ideal), Output watts are probably what the icom a-2 is putting out.
So, I'm not confident that the coax and antenna is safe for my radio, every other coax and antenna combination I ever measured was infinity between the ground shielding and the center lead.
I'm using a decent blue point digital multimeter.
Any Thoughts?
Thanks
Scott W
Old February 2nd 16, 05:41 PM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
At 14:42 02 February 2016, shkdriver wrote:
Hey Group,
in
s=
older end.
cent=
wir=
of
value?
wa=
watts
every=
th=
Any Thoughts?
Thanks
Scott W
You said 'splice', did you really mean a taped join? Surely not!
Such joints are suspect at best and rarely moisture-proof. Moisture can
capillary up the Co-Ax and give very poor performance. A quality BNC or TNC
connector will give a moisture-proof seal, but any moisture already there
will be trapped.
Can’t say specifically about the Std. Cirrus, but in some fins there is
not sufficient height, and the aerial needs to be electrically longer. This
may give a surprising DC resistance.
Using a DC metre to judge an antenna is always risky.
The results from the SWR test don’t look too unreasonable, considering
there is a length of co-ax in the way. True SWR needs to be measured at the
antenna, but this is not always possible!
Old February 2nd 16, 07:46 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Your SWR isn't very good, but it's not quite terrible either. Some
antennas are designed with a DC short, so (in itself) that .9 ohm
reading doesn't necessarily indicate any problem. Bottom line: Judging
from that SWR, your antenna is less than ideal. That said, if you get
good performance out of your system, I wouldn't worry too much about it.
Old February 2nd 16, 09:04 PM posted to rec.aviation.soaring
Heinz Gehlhaar
On Tuesday, February 2, 2016 at 6:43:02 AM UTC-8, shkdriver wrote:
Hey Group,
Snip snip
Not too surprising. Look up Gamma matched antenna; the antenna is a dc short circuit.
Heinz
Old February 4th 16, 12:21 AM posted to rec.aviation.soaring
Most 'loaded' antennas will show little to no resistance. I just checked one and got .2 to .9 ohms. Recommend you get the BNC properly attached, then hook up your radio and give it a range check
JJ
Scenes From The Factory Floor, Concluded - Wirraway factory Australia 1940 b.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 January 29th 15 02:22 PM
Scenes From The Factory Floor, Concluded - Wirraway factory Australia 1940 a.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 January 29th 15 02:22 PM
Scenes From The Factory Floor 15 - Spirit St Louis Ryan Factory.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 5 January 29th 15 05:50 AM
Comm antenna distance from pilot? Becker flex antenna? [email protected] Soaring 3 January 16th 13 11:16 AM
406 ELT Aircraft Installed - Anyone find one? - Internal carbonfuselage antenna WaltWX[_2_] Soaring 5 March 17th 12 06:44 AM
