Comm antenna distance from pilot? Becker flex antenna?
Old January 15th 13, 12:41 AM posted to rec.aviation.soaring
Default Comm antenna distance from pilot? Becker flex antenna?
Help,
Anyone have any good info on how far a comm antenna should be from the pilot?
My current antenna in mounted in the rudder, and the coaxial is cracked inside the rudder.
Trying to find another place to mount an antenna without going external and without cutting into the rudder.
This is in a Silent-IN, and there is carbon in the tail from about the back third of the wing all the way back.
The area around the pilot is glass, and also there is a possibility of mounting behind my seat back.
Considering using the Becker flexible antenna that appears to be made from coaxial. Anyone have any experience with this antenna?
Thanks
Kevin
92
Comm Antenna in Winglet SoaringXCellence Soaring 3 November 22nd 10 03:56 AM
Com Antenna Tony Condon[_2_] Soaring 2 May 5th 09 04:11 AM
antenna et Home Built 7 June 29th 08 05:00 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
VHF Antenna David Wilson Home Built 1 June 14th 04 04:25 AM
