Com Antenna
Old May 4th 09, 05:30 PM posted to rec.aviation.soaring
Tony Condon[_2_]
Default Com Antenna
I'm about ready to go shopping for the Cherokee. I've got a brand new
Microair 760 radio for the panel and I'd like to complement that with a
new antenna. There is plenty of room in the tail to mount a normal
airplane style com antenna. what are other people using? What would I
need to use for a ground plane? Piece of aluminum same radius as the
antenna length?
-Tony Condon
Cherokee II N373Y
Old May 5th 09, 01:55 AM posted to rec.aviation.soaring
Eric Greenwell
Default Com Antenna
antenna length?
Most non-metallic gliders use a dipole antenna. Look for that type, as
they are a lot easier to mount than one with a ground plane.
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old May 5th 09, 04:11 AM posted to rec.aviation.soaring
Paul Remde
Default Com Antenna
Hi Tony,
I have several options he
http://www.cumulus-soaring.com/antennas.htm
I'd probably go with the AAE or Sportcraft antennas because they don't need
a ground plane.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Tony Condon" wrote in message
antenna length?
-Tony Condon
Cherokee II N373Y
GPS Antenna 150flivver Owning 14 December 11th 05 06:38 AM
Best VHF Antenna Steve Home Built 6 January 25th 05 03:04 PM
ELT Antenna Gary Home Built 18 November 5th 04 03:17 AM
VHF Antenna David Wilson Home Built 1 June 14th 04 04:25 AM
ADF antenna Dan Luke Owning 3 August 14th 03 03:48 PM
