#41
On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote:
On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www.ntsb.gov/_layouts/ntsb.a...A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... |
#42
On Sunday, June 3, 2018 at 4:37:52 PM UTC-7, 2G wrote:
On Sunday, June 3, 2018 at 3:55:32 PM UTC-7, jfitch wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed.. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www..ntsb.gov/_layouts/ntsb....A277 A&akey=1) even though they were not in controlled airspace at the time. Tom And yet, the regulation does not say that. The relevant section 91.215 (c) is quoted here in it's entirety: "(c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an air- craft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC." The airspace specified in paragraph (b) is controlled airspace. The AIM can say whatever it likes, the regulation is clearly worded and is the law.. I'd agree that keeping it on at all times is a good idea, and do myself. But it is not required outside of controlled airspace. The AIM clearly states that it must be on in no uncertain terms (did you not read that?), so there is no wiggle room as far as the FAA is concerned. There are times when ATC will direct pilots to turn off their transponders, such as the EAA fly-in at Oshkosh, but they must be on otherwise. 91.215 nowhere gives the pilot the discretion of turning off the transponder in uncontrolled airspace. And the glider pilot was, indeed, found liable in the Minden mid-air. Tom You seem confused about how regulatory law in the Unites States works. Stuff in the AIM might as well be in a children's coloring book as far as determining regulatory compliance. --- And what the hell does the Minden midair collision have to do with this? That was not uncontrolled airspace to start with, 16,000' over the Pine Nut range is Class E == *controlled* airspace. The NTSB report addresses *nothing* to do turning off transponders outside of uncontrolled airspace. NTSB LAX06FA277A final reports: "Probable cause: The failure of the glider pilot to utilize his transponder and the high closure rate of the two aircraft, which limited each pilot's opportunity to see and avoid the other aircraft." That's a statement of probable cause. I'd be careful not to call that a finding of "liability", and the glider pilot has stated reasons why they believed they should not operate the recently installed but not 14 CFR 43, Appendix E & F checked transponder. I hope I would have made a different decision. |
#43
On Sunday, June 3, 2018 at 4:56:55 PM UTC-7, Darryl Ramm wrote:
On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level.. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www.ntsb.gov/_layouts/ntsb.a...A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... The AIM is subtitled "Official Guide to Basic Flight Information and ATC Procedures." What part of "Official" don't you understand? The section I quoted is in no way qualified by other paragraphs - it stands on its own. The AIM is an excellent resource in regards to how the FAA interprets FARs - your interpretation and five bucks will buy you a cup of coffee at Starbucks. And, did you not read the NTSB findings on the Minden glider-jet mid-air? They ALSO agree with me. If you think you can legally turn off your transponder anytime you want in uncontrolled airspace, you are skating on thin ice. You can deviate from regs if it is a flight safety issue, however. And I believe I corrected your false claim that all ADS-B Out installations are a minor modification. Tom |
#44
On Sunday, June 3, 2018 at 5:15:50 PM UTC-7, Darryl Ramm wrote:
On Sunday, June 3, 2018 at 4:37:52 PM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 3:55:32 PM UTC-7, jfitch wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www.ntsb.gov/_layouts/ntsb.a...A277 A&akey=1) even though they were not in controlled airspace at the time. Tom And yet, the regulation does not say that. The relevant section 91.215 (c) is quoted here in it's entirety: "(c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an air- craft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC." The airspace specified in paragraph (b) is controlled airspace. The AIM can say whatever it likes, the regulation is clearly worded and is the law. I'd agree that keeping it on at all times is a good idea, and do myself.. But it is not required outside of controlled airspace. The AIM clearly states that it must be on in no uncertain terms (did you not read that?), so there is no wiggle room as far as the FAA is concerned. There are times when ATC will direct pilots to turn off their transponders, such as the EAA fly-in at Oshkosh, but they must be on otherwise. 91.215 nowhere gives the pilot the discretion of turning off the transponder in uncontrolled airspace. And the glider pilot was, indeed, found liable in the Minden mid-air. Tom You seem confused about how regulatory law in the Unites States works. Stuff in the AIM might as well be in a children's coloring book as far as determining regulatory compliance. --- And what the hell does the Minden midair collision have to do with this? That was not uncontrolled airspace to start with, 16,000' over the Pine Nut range is Class E == *controlled* airspace. The NTSB report addresses *nothing* to do turning off transponders outside of uncontrolled airspace. NTSB LAX06FA277A final reports: "Probable cause: The failure of the glider pilot to utilize his transponder and the high closure rate of the two aircraft, which limited each pilot's opportunity to see and avoid the other aircraft." That's a statement of probable cause. I'd be careful not to call that a finding of "liability", and the glider pilot has stated reasons why they believed they should not operate the recently installed but not 14 CFR 43, Appendix E & F checked transponder. I hope I would have made a different decision. Fault was determined by the NTSB - liability was determined by the insurance companies. Tom |
#45
On Sunday, June 3, 2018 at 4:37:52 PM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 3:55:32 PM UTC-7, jfitch wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www.ntsb.gov/_layouts/ntsb.a...A277 A&akey=1) even though they were not in controlled airspace at the time. Tom And yet, the regulation does not say that. The relevant section 91.215 (c) is quoted here in it's entirety: "(c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an air- craft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC." The airspace specified in paragraph (b) is controlled airspace. The AIM can say whatever it likes, the regulation is clearly worded and is the law. I'd agree that keeping it on at all times is a good idea, and do myself.. But it is not required outside of controlled airspace. The AIM clearly states that it must be on in no uncertain terms (did you not read that?), so there is no wiggle room as far as the FAA is concerned. There are times when ATC will direct pilots to turn off their transponders, such as the EAA fly-in at Oshkosh, but they must be on otherwise. 91.215 nowhere gives the pilot the discretion of turning off the transponder in uncontrolled airspace. And the glider pilot was, indeed, found liable in the Minden mid-air. Tom You seem confused about how regulatory law in the Unites States works. Stuff in the AIM might as well be in a children's coloring book as far as determining regulatory compliance. --- And what the hell does the Minden midair collision have to do with this? That was not uncontrolled airspace to start with, 16,000' over the Pine Nut range is Class E == *controlled* airspace. The NTSB report addresses *nothing* to do turning off transponders outside of uncontrolled airspace. NTSB LAX06FA277A final reports: "Probable cause: The failure of the glider pilot to utilize his transponder and the high closure rate of the two aircraft, which limited each pilot's opportunity to see and avoid the other aircraft." That's a statement of probable cause. I'd be careful not to call that a finding of "liability", and the glider pilot has stated reasons why they believed they should not operate the recently installed but not 14 CFR 43, Appendix E & F checked transponder. I hope I would have made a different decision. "Stuff in the AIM might as well be in a children's coloring book as far as determining regulatory compliance." I view that statement as being a dangerous, elitist disregard of how us pilots should operate in a safety-centric, collaborative setting with the FAA. You have sunk to a new low for bloviating. Tom |
#46
On Sunday, June 3, 2018 at 5:23:34 PM UTC-7, 2G wrote:
On Sunday, June 3, 2018 at 4:56:55 PM UTC-7, Darryl Ramm wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed.. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www..ntsb.gov/_layouts/ntsb....A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215.. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... The AIM is subtitled "Official Guide to Basic Flight Information and ATC Procedures." What part of "Official" don't you understand? The section I quoted is in no way qualified by other paragraphs - it stands on its own. The AIM is an excellent resource in regards to how the FAA interprets FARs - your interpretation and five bucks will buy you a cup of coffee at Starbucks.. And, did you not read the NTSB findings on the Minden glider-jet mid-air? They ALSO agree with me. If you think you can legally turn off your transponder anytime you want in uncontrolled airspace, you are skating on thin ice. You can deviate from regs if it is a flight safety issue, however. And I believe I corrected your false claim that all ADS-B Out installations are a minor modification. Tom You certainly did no such thing. Regarding ADS-B out being a major or minor, Darryl said 'it depends' but often is a minor change. You confirmed EXACTLY THAT with your FSDO. Go back and read the thread, this time for comprehension. The AIM is a low level bureaucrat's interpretation of the regulations. It cannot be enforced unless a judge agrees with that interpretation. There are literally millions of court cases where the judge has not agreed. In this particular case the wording is completely clear and unambiguous. |
#47
On Sunday, June 3, 2018 at 4:56:55 PM UTC-7, Darryl Ramm wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed.. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www..ntsb.gov/_layouts/ntsb....A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215.. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... The AIM is subtitled "Official Guide to Basic Flight Information and ATC Procedures." What part of "Official" don't you understand? The section I quoted is in no way qualified by other paragraphs - it stands on its own. The AIM is an excellent resource in regards to how the FAA interprets FARs - your interpretation and five bucks will buy you a cup of coffee at Starbucks.. And, did you not read the NTSB findings on the Minden glider-jet mid-air? They ALSO agree with me. If you think you can legally turn off your transponder anytime you want in uncontrolled airspace, you are skating on thin ice. You can deviate from regs if it is a flight safety issue, however. And I believe I corrected your false claim that all ADS-B Out installations are a minor modification. I never said that. I was correcting you claim that all ADS-B Out installs (in type certified aircraft) are major modifications. You seemed to made the common mistake that because FAA policy asks for a 337 they are therefore major changes. I said they do require a "notification only" 337s but are not necessarily a major modifications, only if they are for the usual reasons.. You then went and got an FAA FSDO person who agreed with what I had been trying to tell you. You seem to have really confounding problems following simple logic/reasoning and keep inverting stuff, or finding contradictions where they don't exist. I'd already made the comment in this thread about what is allowed by regulations and you commented later saying something different. I don't care what you personally think about anything, but when you keep stating stuff on r.a.s. again and again that is simply just wrong I am going to correct you. |
#48
On Sunday, June 3, 2018 at 5:50:49 PM UTC-7, Darryl Ramm wrote:
On Sunday, June 3, 2018 at 5:23:34 PM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 4:56:55 PM UTC-7, Darryl Ramm wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www.ntsb.gov/_layouts/ntsb.a...A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... The AIM is subtitled "Official Guide to Basic Flight Information and ATC Procedures." What part of "Official" don't you understand? The section I quoted is in no way qualified by other paragraphs - it stands on its own. The AIM is an excellent resource in regards to how the FAA interprets FARs - your interpretation and five bucks will buy you a cup of coffee at Starbucks. And, did you not read the NTSB findings on the Minden glider-jet mid-air? They ALSO agree with me. If you think you can legally turn off your transponder anytime you want in uncontrolled airspace, you are skating on thin ice. You can deviate from regs if it is a flight safety issue, however. And I believe I corrected your false claim that all ADS-B Out installations are a minor modification. I never said that. I was correcting you claim that all ADS-B Out installs (in type certified aircraft) are major modifications. You seemed to made the common mistake that because FAA policy asks for a 337 they are therefore major changes. I said they do require a "notification only" 337s but are not necessarily a major modifications, only if they are for the usual reasons. You then went and got an FAA FSDO person who agreed with what I had been trying to tell you. You seem to have really confounding problems following simple logic/reasoning and keep inverting stuff, or finding contradictions where they don't exist. I'd already made the comment in this thread about what is allowed by regulations and you commented later saying something different. I don't care what you personally think about anything, but when you keep stating stuff on r.a.s. again and again that is simply just wrong I am going to correct you.. Wonder if Las Vegas bookies have odds on this? Jim |
#49
On Sunday, June 3, 2018 at 6:56:55 PM UTC-5, Darryl Ramm wrote:
On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level.. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www.ntsb.gov/_layouts/ntsb.a...A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... For all practical purposes, if you have a transponder equipped aircraft you need to leave it on at all times. While technically you can turn it off in Class G airspace (unless that also disables your ADS-B OUT installation), in the continental US, we are almost always flying in or transitioning thru Class E airspace, so this distinction is really moot. |
#50
On Sunday, June 3, 2018 at 6:45:26 PM UTC-7, Mike Schumann wrote:
On Sunday, June 3, 2018 at 6:56:55 PM UTC-5, Darryl Ramm wrote: On Sunday, June 3, 2018 at 11:15:00 AM UTC-7, 2G wrote: On Sunday, June 3, 2018 at 1:10:46 AM UTC-7, Darryl Ramm wrote: On Saturday, June 2, 2018 at 10:38:50 PM UTC-7, 2G wrote: On Friday, June 1, 2018 at 10:31:39 PM UTC-7, Darryl Ramm wrote: On Friday, June 1, 2018 at 6:01:43 PM UTC-7, Charles Longley wrote: One of our Pawnees has an ADSB out transponder now. (Evergreen Soaring) We’ve had glider pilots we’re towing that have FLARM ask us to turn off our transponder. We’ve told the glider pilots to turn their FLARM down or off. My recommendation is to either have a switch for your FLARM or know you can turn the volume down to a suitable level. The question I have is does FLARM show up on ADSB in? As discussed here before the solution to spurious PowerFLARM alerts in the glider to the towplane ADS-B Out may be to put a PowerFLARM in the towplane so the PowerFLARM in the glider knows it's a towplane and more tolerant of it being close to the glider. There is unfortunately no way for an ADS-B out signal to contain any information to tell PowerFLARM it's a towplane. The FLARM signal does carry that information. it would be great if somebody could experiment with a PowerFLARM portable in the towplane to see if it indeed does solve the issue. Be careful turning those transponders off, they provide visibility to other aircraft with ADS-B In, TCAS, ATC, all gliders with PowerFLARM with 1090ES In option etc. And if in controlled airspace its a violation of 14 CFR 91.215... and since the towplane is transmitting ADS-B data for all to see and the signal starts going of in flight that may well get noticed.. The likely better option if necessary here is for the glider to turn off or turn down the volume on their PowerFLARM while on tow. If you have a transponder installed, you are required to operate it at all times unless otherwise directed by ATC (i.e. Oshkosh). Tom That's not quite accurate, you are required to operate an installed transponder at all times in *controlled airspace*. 14 CFR § 91.215 (c). So they can be turned off in Class G airspace. Maybe a good aviation quiz night question, or BFR question. But to the point, yes turning them off is a bad idea. Wrong: 91.215 states where you MUST operate your transponder - it says nothing about allowing a pilot to turn it off. The matter is addressed in section 4−1−20 of the AIM (https://www.faa.gov/air_traffic/publ..._10-12-17.pdf), "Transponder Operation:" 4. Transponder and ADS-B Operations in the Air. EACH PILOT OPERATING AN AIRCRAFT EQUIPPED WITH AN OPERABLE ATC TRANSPONDER, MAINTAINED IN ACCORDANCE WITH 14 CFR SECTION 91.413 OR ADS-B TRANSMITTER, MUST OPERATE THE TRANSPONDER/TRANSMITTER, INCLUDING MODE C/S IF INSTALLED, ON THE APPROPRIATE MODE 3/A CODE OR AS ASSIGNED BY ATC. EACH PERSON OPERATING AN AIRCRAFT EQUIPPED WITH ADS-B OUT MUST OPERATE THIS EQUIPMENT IN HE TRANSMIT MODE AT ALL TIMES WHILE AIRBORNE UNLESS OTHERWISE REQUESTED BY ATC. Notice the use of ALL CAPS: the FAA is shouting this requirement out at us. Furthermore, the glider involved in the Minden mid-air collision with the Hawker jet was faulted for not operating his transponder (https://www..ntsb.gov/_layouts/ntsb....A277 A&akey=1) even though they were not in controlled airspace at the time. Tom (With apologies to John Adams) We are a nation of laws not Aeronautical Information Manuals. AIM is not a regulation. The 14 CFR § 91.215 regulation is *very* clear. And those regulations, and case law, is what determines what is legally required. And being told where you are required to do something, also implies where you are not required to. The regulation does not need to discuss the transition between those states that are bleeding obvious. Nobody should be confused that the meaning here is going from required to be on to not required to be on might mean the pilot might... wait for it... ta.. da.. turn it off. And specially since the regulation does not say you cant' turn it off in that transition then you bloody well can. And secondarily the section of the AIM you are referring to is discussing the provision of ATC services, which relies on transponders and ADS-B out, and if you are receiving those service than what you are quoting above is kind obvious, and fully consistent with 14 CFR § 91.215. Even if it was inconsistent with a regulation FAR/AIM cannot change that regulation or how you are required to comply with it. I think this is the second time on r.a.s. recently where you quoted stuff claiming it proves some point of yours and instead had you dug a bit deeper you would have seen it was consistent with what others are saying. ---- And for those playing along at home... Of course, in practice turning off transponders and ADS-B Out systems is a bad idea. Turning off a transponder (unless directed by ATC) in controlled airspace ((everything except Class G) is also a violation of 14 CFR § 91.215.. Turning off an ADS-B Out system (unless directed by ATC) in *any* airspace is a violation of 14 CFR § 91.225(f) "Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times." Well that's great given the goals of ADS-B and how it differs from ATC surveillance radar and meaning of controlled airspace. So if your transponder is also doing 2020 Complaint 1090ES Out then now you can't turn it off in any airspace because doing so would turn off the ADS-B Out. Ah but now what about TABS ADS-B Out systems? Does 14 CFR 91.225(f) cover that as well? I would say no as 14 CFR § 91.225 is all about regulations applying to "2020 Compliant" ADS-B out systems specified in 14 CFR § 91.227. And if 14 CFR § 91.225 and/or § 92.227 applied to TABS then we have all sorts if other issues. An illogical rat hole that nobody including the FAA likely would want to go down. Not that any of this actually matters (just leave stuff tuned on) but if it did then a letter to the FAA Office of the Chief Counsel would help clarify this question about TABS. And they tend to take a pretty clear and supportive view of stuff that if it's not really explicit then its allowed (transponder carriage exemptions for gliders come to mind, glider pilots (including me in the past) assumed they might imply more restrictive regulations than they do, the Office of the Chief Counsel on multiple occasions clarified they don't). See now, hopefully we are pretty well armed for a boozy Aviation quiz night questions about turning off transponders and ADS-B Out. ... For all practical purposes, if you have a transponder equipped aircraft you need to leave it on at all times. While technically you can turn it off in Class G airspace (unless that also disables your ADS-B OUT installation), in the continental US, we are almost always flying in or transitioning thru Class E airspace, so this distinction is really moot. Yes absolutely, leave the damn thing on (and it there is a reason you think you can't then fix it). I was hoping to make that clear. It is also great that this regulatory weirdness about controlled airspace applies to Transponders but not ADS-B Out. And folks need to remember how easy for anybody watching to notice an ADS-B targets just going off the air. The original question here came from glider pilots asking a tow pilot to turn off the towplanes' ADS-B Out. We got sidetracked calling that a "transponder". If I was the tow pilot I know what my response would have been.... :-) |
Flarm reporting my own ADSB Out | [email protected] | Soaring | 14 | March 22nd 18 03:31 AM |
PowerFlarm for ADSB source? | [email protected] | Soaring | 7 | February 24th 15 05:01 PM |
Stratus / Foreflight ADSB | 6X | Soaring | 5 | December 17th 13 09:34 AM |
ADSB is only the start... | Martin Gregorie[_5_] | Soaring | 0 | October 1st 09 01:27 PM |
Santa and ADSB | Mal | Soaring | 0 | December 15th 06 07:42 PM |
