PowerFlarm for ADSB source?
Old February 24th 15, 01:50 PM posted to rec.aviation.soaring
Default PowerFlarm for ADSB source?
Couple questions, maybe Darryl you could take a shot at these.
Would there be a perceptible position error if one compared the reported position from a PowerFlarm Core with a fully approved ADSB source. Compare it to say the Trig TN70 unit. http://www.trig-avionics.com/tn70.html
If the reported position error is suitably small, what would be required to show that the PowerFlarm Core meets the "performance requirements" to be used as a NMEA source for ADSB out?
With many of us in the US installing PowerFlarm, there is some sense to seeing if this device could get to the point, legally, of being used as a source for a Trig transponder that is capable of ADSB out.
Mark
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 10:34 AM
Powerflarm Brick/Core ADSB Range Sean F (F2) Soaring 3 September 5th 13 04:10 PM
PowerFLARM Brick ADS-B antenna source? Paul Remde Soaring 14 October 16th 12 06:35 PM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 02:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 08:42 PM
