Locating Transponder Antenna on top of the fuselage instead of under it.
Old December 30th 19, 06:36 AM posted to rec.aviation.soaring
GliderCZ
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
On Saturday, December 28, 2019 at 10:27:43 PM UTC-8, Darryl Ramm wrote:
On Saturday, December 28, 2019 at 9:23:02 PM UTC-8, wrote:
Well here is a link to a picture of a Ventus with the transponder antenna located as per Schempp Hirth.
Seems to work well only is straight flight. In any banking flight, the antenna is shadowed by the fuselage and/or wings.
Maybe a location on the turtledeck is better ?
https://www.airliners.net/photo/-/Sc...HgcaJ1/QJ2lC9A
Dan
Thanks for the photo, ouch yep that looks like a dopey position, if above is the only other practical option I'd do that.
I've got a Ventus 2c with a flexible antenna positioned exactly like that, per SH recommendations, and have passed a dozen ADS-B checks in the last year, with lots of low altitude yanking and banking.
Old December 30th 19, 06:47 AM posted to rec.aviation.soaring
Do you have the Blade type antenna or the cylinder/ball one ?
Thanks, Dan
Old December 30th 19, 07:06 AM posted to rec.aviation.soaring
GliderCZ
Thanks, Dan
Flexible, similar to the one linked (not HpH branded, as far as I know).
https://wingsandwheels.com/hph-trans...r-antenna.html
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 09:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 04:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 06:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 20th 15 12:00 AM
Transponder and antenna Paolo Soaring 1 March 6th 04 04:32 AM
