2-32 landing Michigan
Old June 1st 20, 06:21 PM posted to rec.aviation.soaring
Default 2-32 landing Michigan
https://www.youtube.com/watch?v=M4bFq5QAt8Y
Old June 1st 20, 06:28 PM posted to rec.aviation.soaring
set up for mid field landing , last flight of the day
I think that was my 5th or 6th training flight..
Carl
Old June 1st 20, 07:15 PM posted to rec.aviation.soaring
Joel Flamenbaum[_2_]
This video is marked "Private" and cannot be viewed
Old June 1st 20, 07:17 PM posted to rec.aviation.soaring
shoot..ok I'll see what I can do..
Old June 1st 20, 07:42 PM posted to rec.aviation.soaring
try this one
https://youtu.be/M4bFq5QAt8Y
There, think I fixed it.
Mid field landing
Carl
Old June 2nd 20, 01:20 AM posted to rec.aviation.soaring
Stephen Szikora
Someone tell the pilot to bank more in the circuit. Watch the yaw string. The pilot is using the rudder to turn ... something that can result in an unrecoverable spin.
Old June 2nd 20, 12:40 PM posted to rec.aviation.soaring
Thanks Stephen, My CFI made that exact point. I struggled with to much rudder, he would say either "Increase the bank or get off the pedal." it is a challenge to co-ordinate the two at first. I have about 17 flights now but COVID has put a stop to it here for now.
Carl
Old June 2nd 20, 01:22 PM posted to rec.aviation.soaring
Carl
Old June 2nd 20, 01:55 PM posted to rec.aviation.soaring
The camera mount point makes it interesting to see what you are looking at. You might tilt it down just a bit so you can see the airspeed and control operations as well.
The yaw string was also offset on the roll out on the runway. Guess you were getting your crosswind training early.
Practicing turn coordination near something hard is gutsy. How's the airspeed and turn coordination at altitude?
Thanks for sharing. Hope you get back in the air. One of the schools around here put in a plexiglass shield between the front and back. Seems like a reasonable way forward.
Old June 2nd 20, 05:29 PM posted to rec.aviation.soaring
kirk.stant
Carl
Hi Carl,
The 2-32 is a wonderful glider (best Schweizer IMO) but is really unforgiving if you stall in a skid! I'm sure your CFI has covered this, but it's really illuminating to take a high tow and practice stalls with a bit of rudder in - then be ready for spin recovery practice. Best to experience this at altitude, then fly fast, steep patterns down low.
Cheers and fly safe,
Kirk
66
FLORIDA to MICHIGAN [email protected] Soaring 1 April 22nd 20 05:55 PM
Thunder over michigan DougS Piloting 3 July 9th 07 02:22 PM
Michigan Rental? Arnold Sten Piloting 2 April 5th 05 12:36 PM
Winter in Michigan Roger Owning 8 January 28th 05 06:24 PM
Winter in Michigan. Denny Owning 2 January 28th 05 04:47 AM
