Oudie with constant flarm warnings
Old June 22nd 20, 01:00 AM posted to rec.aviation.soaring
George Haeh
Default Oudie with constant flarm warnings
File from Flarm Configuration Tool
It looks like the Microair could be a Mode C transponder.
From the tool:
"Transponder type
Type of transponder that is installed in the aircraft. A correctly configured Mode-S transponder must be used in aircraft with pressure cabin, and in case there is a significant difference between cabin and external static pressure."
If you have a transponder, you have to say so in the Flarm configuration file.
# This configuration file must be text only and reside in the top directory of the
# USB stick, SD card or FLARM Tool.
# This configuration file must be named FLARMCFG.TXT
# If you wish to change the settings, you can revisit the online configuration tool
# at any time: https://www.flarm.com
$PFLAC,S,DEF
$PFLAC,S,ID,C01234
$PFLAC,S,ACFT,1
$PFLAC,S,NMEAOUT1,71
$PFLAC,S,BAUD1,2
$PFLAC,S,NMEAOUT2,71
$PFLAC,S,BAUD2,2
$PFLAC,S,RANGE,65535
$PFLAC,S,VRANGE,500
$PFLAC,S,XPDR,1
$PFLAC,S,MODESALT,1
$PFLAC,S,ADSBRANGE,65535
$PFLAC,S,ADSBVRANGE,65535
$PFLAC,S,ADSBWARNINGS,1
$PFLAC,S,PCASRANGE,7408
$PFLAC,S,PCASVRANGE,610
$PFLAC,S,MODEC,0
$PFLAC,S,OWNMODEC,0
$PFLAC,S,PCASCALIBRATION,30
$PFLAC,S,PCASBEEP,1
$PFLAC,S,PCASPFLAU1,0
$PFLAC,S,PCASPFLAU2,0
$PFLAC,S,AUDIOOUT,0
$PFLAC,S,AUDIOVOLUME,100
$PFLAC,S,LOGINT,4
$PFLAC,S,PRIV,0
$PFLAC,S,NOTRACK,0
Flarm / Oudie issues Nick Kennedy[_3_] Soaring 22 July 29th 19 03:48 PM
OUDIE FLARM [email protected] Soaring 5 July 12th 18 09:45 PM
flarm/oudie [email protected] Soaring 3 September 15th 17 02:51 PM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
