On Saturday, October 9, 2010 at 7:21:53 AM UTC-4, wladkummer76 wrote:
Hi all, Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone I had my first actuator leak at the wing root of my Discus CS just last week. I've already designed, built, and tested a fix that can be made external of the wing. Very simple, but very effective. If you would like a description and a picture, just contact me. If you have a lathe, you can make it yourself; if not, any local machine shop can do the job with a few parts from McMaster Carr. |
C85 Oil Leak | Dick[_1_] | Owning | 2 | May 2nd 07 11:00 PM |
water ballast leak | Robert Harvey | Soaring | 2 | May 27th 05 03:49 PM |
water ballast leak | Robert Harvey | Soaring | 0 | May 26th 05 10:33 PM |
Oil leak | Gene Seibel | Owning | 10 | January 4th 05 02:57 PM |
Oil leak | mike regish | Piloting | 9 | June 22nd 04 03:46 AM |
