So, to see a UAT equipped aircraft with a 1090 receiver you need to be close to an aircraft with 1090 in/out. Most reliable way to do this is to put adsb 1090 in/out on your glider.
To be seen by that UAT equipped aircraft, same answer. With adsb out on the glider and the flarm core 1090 rx, the only issue I'm seeing is latency in the ground relay system. It will be really neat if a flarm core s/w upgrade adds UAT rx, or turns on all of the h/w in the box, especially the second flarm transmitter. Lacking that, instead of switching to a new flarm box, would it be better to put the money into adsb out? That said, if I was adding flarm, the new one looks nice. |
Xian JH-7 pics 2 [5/7] - JH-7B is an advanced version of JH-7A. It has stealthier features compared to JH-7A..jpg (1/1) | Miloch | Aviation Photos | 0 | August 16th 18 02:41 PM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM protocol version 6 | kirk.stant | Soaring | 17 | September 8th 12 10:03 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
Any news on the "brick" version of PowerFlarm from the SSA convention? | Andrzej Kobus | Soaring | 7 | February 8th 12 04:29 PM |
