Wing Drop, Aerotow vs Winch, Grass vs Pavement.
Old March 20th 21, 03:40 PM posted to rec.aviation.soaring
Bob W.
Default Wing Drop, Aerotow vs Winch, Grass vs Pavement.
On 3/20/21 7:52 AM, Hartley Falbaum wrote:
"What else did I miss?"---the other side of the equation in risk
analysis. What is the worst that can happen if I don't release? vs
What is the worst that can happen if I do? There may be a 1-2 second
"startle factor" in some cases. So, the decision must be
pre-loaded. There is very little cost (usually) to a release.
Kudos to BFC for attempting to take this particular
incident/accident/discussion beyond "mere panacea declamations" to which
the RAS medium seems (to me, dry chuckle) prone.
On the off chance there're some lurkers "somewhat earlier along" the
soaring learning curve - as opposed to long-time RAS regulars (which
includes me, and who seem to in recent years be hogging the forum ) -
this thread-to-date contains potentially-personally-useful,
seriously-good, food for thought.
Hartley's "reduction-ad-absurdem" post above is but one example. In my
view, "panacea fixes" (should they in fact be viewed within one's mind
as such) are too-often a blind alley when it comes to such things as
future learning and "properly preparing one's mind" to commit soaring in
as personally-healthy a manner as possible.
A common example of "panacea thinking" - at least in my part of the
Rocky Mountain Front Range west - is close-minded variations of: "I'll
be OK height-wise so long as I have X-thousand feet msl at location Y
back in the hills". Well, yeah, most of the time, maybe...but how to
reconcile that thinking with the thinking inherent within H. Falbaum's
hypothetical line of thought? One size "generally" can't *possibly* fit
every situation, and it's up to Joe Glider Pilot to decide how best to
approach this conundrum.
Given the inherent imperfections in humanity - imperfect
judgment/skills, lack of omniscience, etc. - while perfection isn't an
option, Joe Glider Pilot can still do a whole lot, and go a long way, to
avoid known (to those with greater experience & skills)
situations/physical-harm/death that *should* be avoidable, given their
existing skills/knowledge.
Switching here from "Sermon from the Mount" mode to (so I hope)
illustrative examples from experience, O'beer thirty, tale-telling mode...
Early in my post-1-26, 15-meter glass, "somewhat-nose-hooked", aerotow
state, while attempting to take off from a grass strip in the mountains
north of Sun Valley, ID, several things made me pre-launch nervous:
slight crosswind, new-to-me tug/pilot of unknown provenances, knee-high
grass to either side of runway. I and my wing-runner/partner discussed
the situation and pre-planned things best we could (both "local
strangers" and prolly 200 hours total time each) and off I went. Pulled
the plug after an upwind wing drop followed by progressive swerving
into-wind along w. failure of the wing to lift. No harm, no foul was the
result outside the cockpit; inside the cockpit...not so much. Serious
dismay, as I felt that "somehow" I could've done better under existing
circumstances.
And so it proved on the 2nd launch attempt following further discussion
w. my partner *and* the tow-pilot, and some refining of my mental launch
go/no-go plan as well as techniques and "overall awarenesses".
Zooming ahead mightily through time, in that and two other ships (HP-14
w. "50% nose/CG hook, 15-meter span, no negative flaps, V-tail, tail
skid; and 15-meter Zuni *with* negative flaps, "somewhat nose-hooked",
heavily-weighted tailwheel) I aborted 1-each aerotow, both times
followed by successful launches behind the same tug/pilot. Both were
5,300'msl, summertime, concerning-but-far-less-so than the C-70
experience...because of successfully pre-planned/decided "mental
scenario-ing". In both ships, I also made more-than-one (several? many?)
no-wing-runner takeoffs entirely w/o incident.
Bragging? Not intended as such. Rather trying to illustrate how
"preparing one's mind 'properly'" can be, likely *will* be, a good thing
for Joe Glider Pilot, if avoiding adrenaline, negative-excitement, and -
potentially - accidents, is deemed personally desirable.
Other than what I've read on RAS, I know zip about the situation and the
pilot in this particular unfortunate - seemingly, avoidable - accident.
I wish him a speedy and full recovery and continued good soaring, if he
so chooses. And part of this *particular* Joe Glider Pilot would
genuinely appreciate hearing from the horse's mouth at some point in the
future, by way of refining my mental picture.
YMMV,
Bob W.
Old March 21st 21, 02:56 AM posted to rec.aviation.soaring
2G
illustrative examples from experience, O'beer thirty, tale-telling mode....
circumstances.
YMMV,
Bob W.
Another factor not mentioned is what do you have on the wing tip: a skid or a wheel. If it is a wheel and you are towing on a hard surfaced runway a wing drop will be a non-event. If fact, when I self launch (with a wing tip wheel) I want the wing down even if offered a wing runner. A wing that starts down can't drop.
If, however, you are launching off of turf there will be more resistance than a hard surface. I don't ever fly off of turf so I can't say if it would make a difference. Probably depends upon how long the grass is.
A nose hook does provide some self-correcting force, but how much? the nose hook is, at most, one meter ahead of the main; an 18m glider gives forces on the wing tip a 9:1 lever arm to the nose hook. While that is better than nothing, what are the restorative forces? Say the towplane is exerting 200lb on the glider and the nose is 10 degrees off centerline; the restorative force is 35lb. This would only offset about a 5lb force on the wing tip - not very much.
Tom
Old March 21st 21, 05:51 PM posted to rec.aviation.soaring
Frank Whiteley
circumstances.
YMMV,
Bob W.
Tom
Lush turf is pretty grabby and if a pilot tries to roll the glider with ailerons, the down wing aileron only grabs more turf and makes the situation worse. Only opposite rudder should be used until the wing starts to rise.
Old March 21st 21, 07:52 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Frank Whiteley wrote on 3/21/2021 10:51 AM:
YMMV,
Bob W.
Tom
Flapped ships can start in a negative setting, and avoid the turf grabbing by the ailerons.
Vought F4U Corsair pics [05/11] - A United States Navy F4U-5NL Corsair equipped with the air intercept radar (right wing) and a 154-gallon drop tank in the Geneseo Airshow, in July 9, 2006.jpg (1/1) Miloch Aviation Photos 0 March 3rd 18 03:04 PM
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
landing on pavement Mark IV Piloting 15 December 3rd 10 08:11 PM
Aerotow Fuel Costs & Winch Launching Derek Copeland[_2_] Soaring 2 May 26th 08 03:14 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
