On Thursday, April 8, 2021 at 1:47:10 PM UTC-7, wrote:
I bought my second Std. Libelle, s/n 593 so it is a balasted ship ex-factory. A 201B. It has waterbags, the dumplever but no valve in the wheel well and no holes in the bulkhead behind the seat and the wheel well. Not a trace of it... It has seen extensive damage the two years after it was delivered new. The first repair consisted of the complete new cockpit section, it might explain things but I cannot imagine it hasn't flown ballasted the last 46 years. What do I miss? The ships I know are in the 100, 200 and 300 build number range. I never saw other late serial ships. You said the ship had extensive damage, I would recommend reviewing the current weight and balance to make sure you can add more ballast, if you haven't already done so. Sean |
On Thu, 08 Apr 2021 14:01:19 -0700, Sean E wrote:
On Thursday, April 8, 2021 at 1:47:10 PM UTC-7, wrote: I bought my second Std. Libelle, s/n 593 so it is a balasted ship ex-factory. A 201B. It has waterbags, the dumplever but no valve in the wheel well and no holes in the bulkhead behind the seat and the wheel well. Not a trace of it... It has seen extensive damage the two years after it was delivered new. The first repair consisted of the complete new cockpit section, it might explain things but I cannot imagine it hasn't flown ballasted the last 46 years. What do I miss? The ships I know are in the 100, 200 and 300 build number range. I never saw other late serial ships. You said the ship had extensive damage, I would recommend reviewing the current weight and balance to make sure you can add more ballast, if you haven't already done so. After you've sorted out the W&B, contact Glasfaser, if you haven't already done so. I've found them to be easy to deal with and helpful. They probably have the drawings you need and may be able to supply the missing water dump parts too. Web: http://www.streifly.de/ E-mail: -- Martin | martin at Gregorie | gregorie dot org |
| Thread Tools | |
| Display Modes | |
| Looking for water ballast system for DG 200 complete and or parts of. | Chris Stratton | Soaring | 4 | February 11th 20 09:31 PM |
| ASW 17 water ballast system | OregonGliderPilot | Soaring | 2 | August 18th 19 05:55 PM |
| Wanted: Libelle water ballast fittings | JS | Soaring | 0 | April 6th 13 06:42 PM |
| Libelle 301 water ballast | [email protected] | Soaring | 3 | January 15th 08 03:40 PM |
| Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 10:36 AM |
