X-change Dittel for Becker
Old June 10th 21, 04:31 PM posted to rec.aviation.soaring
Phoenix
Default X-change Dittel for Becker
I currently have a Dittel mounted at the bottom of the stack. I would like to replace it with a Becker. Is there an "adaptor" to change the mounting hole from the square Dittel to the round Becker?
Old June 10th 21, 07:19 PM posted to rec.aviation.soaring
Dan Marotta
I've never seen such a thing, but it might not be too much work to
simply remove the panel, remove all of the switches and instruments, and
plug the square hole with fiberglass or carbon.Â* Then cut a new round
hole and remount the things you removed.Â* Except for the cure time on
the resin, it should be less than a day's work.
Good luck!
Dan
5J
Old June 10th 21, 07:39 PM posted to rec.aviation.soaring
plug the square hole with fiberglass or carbon. Then cut a new round
hole and remount the things you removed. Except for the cure time on
Good luck!
Dan
5J
This might work:
https://www.segelflug.de/osclass/index.php?
page=item&id=54270
RO
Old June 10th 21, 07:54 PM posted to rec.aviation.soaring
Good luck!
Dan
5J
This might work:
page=item&id=54270
RO
This will convert either an old rectangular radio hole, or
with the bigger plate convert an 80mm / 3.125" hole.
To contact the seller, first go to the main site, use the
English button and register (free) to be able to use the
site.
RO
FS: 2 Dittel FSG2T and 2 Becker 4201 Ross[_3_] Soaring 4 May 14th 19 04:28 PM
FS: 5 Becker 4201 + 1 Becker 3201 + 1 Dittel FSG5 Handheld Ross[_3_] Soaring 10 April 4th 18 04:36 PM
FS: 3 Becker 4201 and 1 Dittel FSG60m Ross[_3_] Soaring 6 December 29th 17 02:34 PM
Dittel or Becker? David MacVeigh Soaring 9 September 19th 15 08:25 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
