![]() Mark, I don't understand stand your comment about not having to wear a cannula - you'd rather wear a mask? And EDS doesn't allow cannulas? Dan is correct- I was referring to the Oximizer "mustache" cannula that looks like a large flesh colored growth on your upper lip. They help conserve O2 with a properly calibrated manual flow valve and a constant flow system, but the more efficient EDS uses a normal cannula. NOTE: Do NOT use the Oximizer cannula with the EDS! It will not reliably trigger the pressure transducers in the EDS and you will not receive sufficient O2. |
The money you will save on oxygen refills using the EDS will pay for the unit.
Ditto on leaving the unit on automatic and use it from take-off to landing. It was very impressive to experience how much more alert I felt at the end of a long day of flying when I used the EDS as compared to the old manual systems. Consider the EDS to be an airbag system for your brain. |
On Monday, June 14, 2021 at 8:18:09 AM UTC-5, Guy Acheson wrote:
The money you will save on oxygen refills using the EDS will pay for the unit. Ditto on leaving the unit on automatic and use it from take-off to landing. It was very impressive to experience how much more alert I felt at the end of a long day of flying when I used the EDS as compared to the old manual systems. Consider the EDS to be an airbag system for your brain. Thanks everybody for the feedback. Looks like I'll be going with the MH system. I appreciate your opinions and advice. |
There is a good presentation on types of O2 systems at
http://aviation.derosaweb.net/presentations/#oxygen. About the fingertip O2 saturation monitors. Being in a glider we need one that is sunlight readable. The cheap OLED ones don't seem to be sunlight readable. Anyone found one that is? Also, anyone have good experiences with the wris****ch type O2 monitors? Thanks, John (OHM) |
Ka-6 Oxygen | Peter von Tresckow | Soaring | 3 | January 4th 12 03:42 AM |
Oxygen | Jim[_18_] | Soaring | 5 | September 28th 11 11:59 PM |
SZD-55 and oxygen | David Pye[_2_] | Soaring | 1 | February 27th 07 04:56 PM |
Do you always have oxygen? | Mxsmanic | Piloting | 32 | November 18th 06 10:30 PM |
hi alt oxygen | Arquebus257WeaMag | Military Aviation | 62 | March 28th 04 04:57 PM |
