SN10 Question
Old June 15th 21, 12:14 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Default SN10 Question
On Monday, June 14, 2021 at 3:55:36 PM UTC-4, JulietUniform wrote:
Thanks John,
Yes, I isolated the TE system and used a very small “mini” aquarium pump. I’m afraid I have damaged an internal sensor. In “vario mode” it sounds a constant tone. In “STF” mode it is silent and increasing the MC setting causes the vario needle to move down (as it should?) with no sound.
JU
My SN-10 always sounds a tone when I turn it on and the needle points to 400 fpm up. Works normally in flight. My settings are for relative netto.
KS
Old June 15th 21, 01:01 AM posted to rec.aviation.soaring
JulietUniform
Thank you Mr. Striedieck. Hopefully I have not damaged anything. Prior to doing the leak test it never made a continuous tone when I turned it on. It would “beep” then be silent. Now, the tone is always on.
John U.
SN10 K Soaring 0 September 15th 12 02:15 AM
SN10 Startup Question YourNameHere Soaring 2 October 17th 11 01:56 PM
SN10 USB question Tuno Soaring 2 August 22nd 11 02:33 PM
Ilec SN10 question Dan Goldman Soaring 0 February 20th 11 11:07 PM
Ilec SN10 question John Ferguson Soaring 3 May 29th 07 05:11 AM
