Hi all,
discussing Pelican's Perch #15: Manifold Pressure Sucks! ( http://www.avweb.com/cgi-bin/udt/im....ry.id=1820 81 ) with some friends, we came to a point in the 172RG manual which says: Starting engine Mixture - RICH Propeller - HIGH RPM carburetor heat - COLD Throttle - PUMP once or twice ?????? Does anyone know, wy to do that. Does this carburetor has an accelerator pump like an carburetor for a car???? As far as I know an aircraft carburetor does not have such a pump. But what other reason should that pumping have?? Any idea? Georg |
![]() "Georg Himmeroeder" wrote in message news:2004031811252616807%ghim@gmxnet... Hi all, discussing Pelican's Perch #15: Manifold Pressure Sucks! ( http://www.avweb.com/cgi-bin/udt/im....id=avweb&story. id=182081 ) with some friends, we came to a point in the 172RG manual which says: Starting engine Mixture - RICH Propeller - HIGH RPM carburetor heat - COLD Throttle - PUMP once or twice ?????? Does anyone know, wy to do that. Does this carburetor has an accelerator pump like an carburetor for a car???? As far as I know an aircraft carburetor does not have such a pump. But what other reason should that pumping have?? Any idea? The Marvelous Dribbler carbs do have an accelerator pump. Pumping the throttle on an updraft carb is sure to load the air box with raw fuel in addition to priming the engine. One good backfire and ................. |
John Kunkel wrote:
"Georg Himmeroeder" wrote in message with some friends, we came to a point in the 172RG manual which says: Starting engine Mixture - RICH Propeller - HIGH RPM carburetor heat - COLD Throttle - PUMP once or twice ?????? Does anyone know, wy to do that. Does this carburetor has an accelerator pump like an carburetor for a car???? As far as I know an aircraft carburetor does not have such a pump. But what other reason should that pumping have?? Any idea? The Marvelous Dribbler carbs do have an accelerator pump. Pumping the throttle on an updraft carb is sure to load the air box with raw fuel in addition to priming the engine. One good backfire and ................ Actually, while most of the Marvels have a pump, some of the smaller models don't. And, while what you say is true of the updraft versions, the HA-6 that is used on George's 172RG is a side draft design, and pumping the throttle is an acceptably safe means to prime the engine. Heck, the 180 HP Lake amphibian doesn't even have a seperate primer, the throttle is all you've got! Happy Flying! Scott Skylane |
