![]() "Dale" wrote in message ... I'm flying a pair of Cessna P206s that have the Wing X STOL extended wings. This mod adds about 18 inches to each wing at the tip. (And for anyone thinking of STOL mods I highly recommend these..they reduce takeoff roll 20-30%). One mandate from the STC is that Vne is lowered to 189 MPH from the usual 210 MPH. There is no change in Va however. I'm wondering why the reduction in Vne? If it is a load factor issue why isn't Va also lowered? My guess is load factor is probably not the limiting factor, dynamic pressure (Q) is. Above 189 mph, the sum of lift and drag is likely approaching the structural limit of the extension. Whereas, at Va, the max load factor can't generate enough Q to break the extensions. Gerry |
Gerry Caron wrote:
My guess is load factor is probably not the limiting factor, dynamic pressure (Q) is. Above 189 mph, the sum of lift and drag is likely approaching the structural limit of the extension. Whereas, at Va, the max load factor can't generate enough Q to break the extensions. That is the way it was described in a paper I downloaded last week. |
O-235 Lycoming Mods | Do B | Home Built | 2 | March 19th 04 02:42 PM |
clever amateur built placard mods | Joa | Home Built | 5 | January 8th 04 08:10 AM |
Scaled Composites X-Prize vehicle flying again after mods | David O | Home Built | 0 | October 26th 03 05:47 AM |
