Gord Beaman wrote:
Well, CJ, I wouldn't want you to pass up a good thing because of incorrect info so perhaps you should check out about this 'illegal' thing. They have cell phones installed in the seat backs of some commercial airliners for the use of passengers (I've seen them but haven't used one) so they sure aren't illegal, These are not cell phones. They are attached to a ship-board communications system which uses a satellite link (or possibly dedicated ground stations) to patch you through to the terrestrial phone network. Different system completely from cell phones. |
Roy Smith wrote:
Gord Beaman wrote: Well, CJ, I wouldn't want you to pass up a good thing because of incorrect info so perhaps you should check out about this 'illegal' thing. They have cell phones installed in the seat backs of some commercial airliners for the use of passengers (I've seen them but haven't used one) so they sure aren't illegal, These are not cell phones. They are attached to a ship-board communications system which uses a satellite link (or possibly dedicated ground stations) to patch you through to the terrestrial phone network. Different system completely from cell phones. Yes...dedicated ground stations...as I said Roy...actually I believe that they utilize regular cel towers some of which are equipped with somewhat different receiver systems...also there's many fewer of them than regular cel service because of the generally much longer range of the airbourne units. It's quite a large budding service...there was a big writeup about it in...?...'life' maybe?...awhile ago... -- -Gord. (use gordon in email) |
Gord Beaman wrote:
Roy Smith wrote: Gord Beaman wrote: Well, CJ, I wouldn't want you to pass up a good thing because of incorrect info so perhaps you should check out about this 'illegal' thing. They have cell phones installed in the seat backs of some commercial airliners for the use of passengers (I've seen them but haven't used one) so they sure aren't illegal, These are not cell phones. They are attached to a ship-board communications system which uses a satellite link (or possibly dedicated ground stations) to patch you through to the terrestrial phone network. Different system completely from cell phones. Yes...dedicated ground stations...as I said Roy...actually I believe that they utilize regular cel towers some of which are equipped with somewhat different receiver systems...also there's many fewer of them than regular cel service because of the generally much longer range of the airbourne units. I would not be surprised if they used some of the same towers, but just because they're on a cell phone tower doesn't make them a cell phone. Towers are a limited resource and most of them are shared by all sorts of unrelated servics (often even direct competitors). The terrestrial cell phone infrastructure is optimized for phones on the surface which are either stationary or moving at relatively low speeds (i.e. highway speed or less). The antenna coverage, cell overlap, signal propigation patterns, and switching algorithms are all designed around these assumptions. Using a cell phone in an airplane not only gives the phone line of sight to many more cells than the system was designed for, but the high speed motion also causes it to switch from cell to cell faster than normal. Both of these break design assumptions and degrade the system. That's why the FCC bans cell phone use from airplanes. Systems designed for aviation use may share some of the basic cell system ideas (and even some of the physical infrastructure like towers), but the ground station grid and switching algorithms are optimized for their intended use. |
I understand that AirCell phones use the same system as regular cell
phones. There is a special antenna on the aircraft which gives a lower power shaped transmission which cannot broadcast past the existing cell region. Each region is made up of a network of cell phones. They may have some dedicated frequencies or channels but they use the same network of cell towers and regions. |
David Lesher wrote:
(Roy Smith) writes: Gord sed: Yes...dedicated ground stations...as I said Roy...actually I believe that they utilize regular cel towers some of which are equipped with somewhat different receiver systems...also there's many fewer of them than regular cel service because of the generally much longer range of the airbourne units. I would not be surprised if they used some of the same towers, but just because they're on a cell phone tower doesn't make them a cell phone. Towers are a limited resource and most of them are shared by all sorts of unrelated servics (often even direct competitors). Well, in reality, the towers and sometimes the RF gear is owned by a company such as American Tower, Inc. and oh yes, they stack as many carriers as they can on one piece of iron. (And it's more than tower space; co-location means they can share generator backup, fiber feeds, etc..) As for if airborne is "cellular" -- that depends on whose definition you want to use. Is it Jill Winecooler 'cellular'? Nope. But can it share the name? You decide. Of course...and the term is no longer 'cellular' anyway it seems, they now seem to prefer 'Mobile phones' so I guess it's a moot point, but ISTM that the aircraft cel system is a helluva lot closer to the terrestrial cel system than anything else. -- -Gord. (use gordon in email) |
On Sun, 09 Jan 2005 19:01:30 GMT, Gord Beaman
wrote: Of course...and the term is no longer 'cellular' anyway it seems, they now seem to prefer 'Mobile phones' so I guess it's a moot point, but ISTM that the aircraft cel system is a helluva lot closer to the terrestrial cel system than anything else. The term "cellular" has a specific meaning within the FCC rules. There is a section of the rules (I forget which one) that regulates the "cellular service", and another section of the rules that regulates PCS phones (the "personal communications service"). The former is not allowed to be used in the air whereas the latter is. A few years ago there was a company that was experimenting with ways to use the "cellular service" from the air without bringing up too many cells, etc. They were working with a special waiver from the FCC. I don't know what all ever became of their work. CJ |
Cell towers do not work individually, each tower only has a few
channels of the huge amout of frequencies available. Your cell phone simply picks the strongest available frequency. That is usually the nearest cell tower, but if all available channels are in use that may be the next nearest tower. There are not just cells but also regions of cell towers, each region will use all of the available channels and have a limited number of land lines available to it. The problem occures when the cell phone access several regions with several towers of the same frequency. Aircell phones have a lower power and a shaped antenna giving a norrow beam down to the ground. |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
