![]() "Jim Weir" wrote in message ... I don't know. I've never used a handheld. I've got a Kenwood 231 mounted like an airplane radio in the stack and plumbed through the audio panel to the headsets. Are the mike inputs and audio outputs compatible with the aviation headset impedance? I'm a lapsed ham and am considering 2M Aero mobile. I find I know NOTHING about the present day equipment. When I was active, everything had nice filaments to keep stuff warm G I'd like to find a piece of 2 meter gear that is generally plug and play. I'll stick a 19 inch on the belly of my aircraft, and take to the airwaves----AFTER I retake the exams. I let an advanced class license lapse. (*&^^%$ Thanks Paul Anton ex WA6NXL WA7ESD HL9VL |
"Paul"
shared these priceless pearls of wisdom: - -"Jim Weir" wrote in message .. . - I don't know. I've never used a handheld. I've got a Kenwood 231 mounted -like - an airplane radio in the stack and plumbed through the audio panel to the - headsets. - - -Are the mike inputs and audio outputs compatible with the aviation headset -impedance? Not really. The standard aircraft mic simulates an old carbon element. You get roughly half a volt to a volt p-p across something like 300 ohms. A standard dynamic input to a ham rig is a few millivolts across a couple of dozen ohms. A standard electret input is a couple of tenths of a volt across 2K or so. The standard aircraft earphone wants a volt or two p-p across 150 ohms. The normal ham rig output is speaker level (a couple of volts into 8 ohms). The point is, there IS no ham radio standard, while the aircraft headset standard is quite well defined. You can't just hook the aircraft headset into the ham rig on a PNP basis. You always wind up dicking around with voltage and impedance shifters to make it play well. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
In rec.aviation.owning Jim Weir wrote:
"Paul" shared these priceless pearls of wisdom: - -"Jim Weir" wrote in message .. . - I don't know. I've never used a handheld. I've got a Kenwood 231 mounted -like - an airplane radio in the stack and plumbed through the audio panel to the - headsets. - - -Are the mike inputs and audio outputs compatible with the aviation headset -impedance? Not really. The standard aircraft mic simulates an old carbon element. You get roughly half a volt to a volt p-p across something like 300 ohms. A standard dynamic input to a ham rig is a few millivolts across a couple of dozen ohms. A standard electret input is a couple of tenths of a volt across 2K or so. The standard aircraft earphone wants a volt or two p-p across 150 ohms. The normal ham rig output is speaker level (a couple of volts into 8 ohms). The point is, there IS no ham radio standard, while the aircraft headset standard is quite well defined. You can't just hook the aircraft headset into the ham rig on a PNP basis. You always wind up dicking around with voltage and impedance shifters to make it play well. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com FWIW, the July QST Hints & Kinks column had this discussion with a simple circuit to use an aviation headset with a ham rig. -- Jim Pennino |
On Sun, 6 Jul 2003 16:32:41 +0000 (UTC), Jim Pennino
wrote: In rec.aviation.owning Jim Weir wrote: "Paul" shared these priceless pearls of wisdom: - -"Jim Weir" wrote in message .. . - I don't know. I've never used a handheld. I've got a Kenwood 231 mounted -like - an airplane radio in the stack and plumbed through the audio panel to the - headsets. - - -Are the mike inputs and audio outputs compatible with the aviation headset -impedance? Not really. The standard aircraft mic simulates an old carbon element. You get roughly half a volt to a volt p-p across something like 300 ohms. A standard dynamic input to a ham rig is a few millivolts across a couple of dozen ohms. A standard electret input is a couple of tenths of a volt across 2K or so. The standard aircraft earphone wants a volt or two p-p across 150 ohms. The normal ham rig output is speaker level (a couple of volts into 8 ohms). The point is, there IS no ham radio standard, while the aircraft headset standard is quite well defined. You can't just hook the aircraft headset into the ham rig on a PNP basis. You always wind up dicking around with voltage and impedance shifters to make it play well. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com FWIW, the July QST Hints & Kinks column had this discussion with a simple circuit to use an aviation headset with a ham rig. It's far, far simpeler to just get one of the little ear pieces with the small lapel mike. Probably cheaper in the long run ... They are inexpensive so why bother messing around with a good head set when you don't have to. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) |
Because there are those of us who see clipping a handheld to a window with a
rubber duckie is not the way we want to do things. Why buy a $300 headset and an audio panel to get the best possible audio into your aircraft transceiver if you aren't willing to do the same thing for your ham rig? It really ain't rocket science, and besides, somewhere I read that "fostering advancement of the state of the radio art" had a place in Part 97. Jim - -They are inexpensive so why bother messing around with a good head set -when you don't have to. - -Roger Halstead (K8RI EN73 & ARRL Life Member) -www.rogerhalstead.com -N833R World's oldest Debonair? (S# CD-2) Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir writes:
Because there are those of us who see clipping a handheld to a window with a rubber duckie is not the way we want to do things. Why buy a $300 headset and an audio panel to get the best possible audio into your aircraft transceiver if you aren't willing to do the same thing for your ham rig? It really ain't rocket science, and besides, somewhere I read that "fostering advancement of the state of the radio art" had a place in Part 97. Yep. I just got done adapting an IC207H VHF/UHF rig to a King KMA28 audio panel. It wasn't rocket science by any stretch of the imagination. In fact, about four or five passive components in a small aluminum enclosure is all it took. At some point I might want to add sidetone, which will involve a few more components. But either way, it's pretty simple. -jav w6vms |
On Mon, 07 Jul 2003 06:36:47 -0700, Jim Weir wrote:
Because there are those of us who see clipping a handheld to a window with a rubber duckie is not the way we want to do things. Why buy a $300 headset and an audio panel to get the best possible audio into your aircraft transceiver if you aren't willing to do the same thing for your ham rig? Lord, no! :-)) I guess you'll have to define "best possible audio" Jim. I want "communications" quality where the band width is tailored to the best for getting information across on both the aircraft and ham rigs. Now and example of what I don't want is something that sounds like one of those expensive Heil mikes used for contesting. The lapel mike has excellent quality along with noise canceling and works great which was a real surprise when I compare it to the prices some of the guys spend on mikes. No, the earpiece doesn't sound like hi-fi, but then again, I can't hear anything above 8K anyway. In the airplane I'm lucky to hear anything above 4K with the extra noise. The ANRs do help out there. I can hear the higher frequency sounds much better while wearing them. To top it off there is no discernable aircraft sound picked up by the mike. It's the little Kenwood combo. I tried the speaker mikes from Yaesu, Icom, and Kenwood, but never found one I liked, or that had half way decent sound. Probably the best sounding one was the Icom compact headset with the boom mike, but then I had to remember to turn off the VOX. I called approach on 146.52 more than once using that setup. What I didn't like was the little head band that went over the top. It really wasn't long enough and even with the big Telex head set on the little one felt like it was falling off. It never did, but it always felt that way. So far I've found the little Kenwood to be easy to use/convenient, comfortable, and sound good, which gives me little incentive to try and wire it in. Now, when I get the G-III together it'll have either a duoband VHF/UHF FM rig, or a VHF/UHF all mode rig in the panel and that will be wired in through the audio panel. Actually, I'd like to put that little Yaesu 100 watt HF/VHF/UHF all mode rig in the G-III...but haven't figured out how to make a trailing wire work in a plastic airplane. I'd also have to wire in an auto retrieve to prevent aerobatics and landing with the thing extended, or I'd probably use it as an arresting hook over the power lines just short of the field. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) It really ain't rocket science, and besides, somewhere I read that "fostering advancement of the state of the radio art" had a place in Part 97. Jim - -They are inexpensive so why bother messing around with a good head set -when you don't have to. - -Roger Halstead (K8RI EN73 & ARRL Life Member) -www.rogerhalstead.com -N833R World's oldest Debonair? (S# CD-2) Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Ham Radio In The Airplane | Doug Carter | Home Built | 24 | July 8th 03 03:30 AM |
Ham Radio In The Airplane | Doug Carter | Owning | 0 | July 5th 03 02:27 AM |
