![]() On 5-Aug-2003, "Wayne" wrote: I am getting the 1961 175B Cessna that I mentioned before here. I am trying to figure out how fast it should be. The owner said that it would go GPH. Then I looked at the original specifications from Cessna. It was supposed to cruise at 122 knots @ 75% power at 7500'. I had assumed that he meant 125 MPH but that is only a little less than 109 knots. This has the Lycoming O360 conversion with a constant speed prop, I would think that would make it slightly faster and surely better on takeoff performance. The 2003 172 that I fly is supposed to cruise at 115 knots @ 75% (I forget the altitude) so I wouldn't expect this one to fly faster than a new one with the same HP and a fixed pitch prop. Anyone have a simular plane? Anyone know what I should expect? Did Cessna stretch things that far in 1961? Wayne I don't have any experience with C-175s, either with the original geared engine or with the 0-360 conversion. However, over hundreds of hours in a C-172N (with the original 150 hp 0-320) I can state that it is a 112 kt airplane at best. The important thing to remember is that, for a given airframe, cruise speed will vary as the cube root of horsepower. Thus, going from 150 hp to 180 hp, for instance, will increase cruise speed (at a given percentage power setting) by only 6.3%. That would boost a 112 kt cruise speed to 119 kts. The idea that you can boost cruise speed with a modest power increase is mostly wishful thinking. A bigger engine really helps mostly in takeoff and climb performance (or, in some cases, allowing for more useful load). A significant increase in cruise speed generally requires aerodynamic cleanup of the airframe. You will rarely meet a seller who can resist exaggerating the performance of the plane he/she is selling. However, with the availability of handheld GPS units, measuring cruise speed during a test flight is fairly easy. Just fly in three headings 120 degrees apart, within a relatively small area (so the wind will not change) and record groundspeed (from the GPS) for each heading. From that data it is easy to compute the wind component, and then the true airspeed. If the air is reasonably smooth you should be able to calculate to within a knot or two. -Elliott Drucker |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 07:22 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
T Tail question | Paul Austin | Military Aviation | 7 | September 23rd 03 06:05 PM |
