![]() Jay Honeck wrote: : The radios in our plane have probably been replaced six times since 1974. : Worse, every guy that put in a new radio seemed to string new wires, simply : cutting off the old antenna wires. This meant that there are several : "antenna wires to no where" under the panel -- making determining which one : was disconnected an exercise in frustration. I have often speculated that iffen I were clean-sheet designing a nav/com; I would do about what ICOM did on at least one series of VHF amateur transceivers. There'd be a control panel, with display and controls. It has fiber fiber back to the box under the rear seat. The control panel is say 1" deep -- it has nothing but the displays, LED's, optical spin encoders, and a minimum of drive electronics. This gets all the electronics of import out of the jungle oven known as "in front of the panel" to where they can be easily wired, seen and cooled. CG permitting, you could add a adjacent 3AH GelCell as emergency power. You could also do the same with GPS, xponder, etc. In fact the panels might be the same hardware, except for labels. Yea, I know, that's ~~what the ARINC standard used to do on DC-6 era beasts -- remote everything down to the radio bay. One issue you add is the interconnecting wiring as failure points. But if we use flexible fiber jumpers, instead of 18-odd wires, that's a different kettle of fish. Further, if it loses the fiber connectivity, the radio can revert to ?121.5? and preset volume, etc. Now, I don't think anyone will ever do this -- for all the reasons the GA fleet is what it is. But I still think it is a fun engineering dream, at least. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher wrote:
I have often speculated that iffen I were clean-sheet designing a nav/com; I would do about what ICOM did on at least one series of VHF amateur transceivers. There'd be a control panel, with display and controls. It has fiber fiber back to the box under the rear seat. The control panel is say 1" deep -- it has nothing but the displays, LED's, optical spin encoders, and a minimum of drive electronics. This gets all the electronics of import out of the jungle oven known as "in front of the panel" to where they can be easily wired, seen and cooled. CG permitting, you could add a adjacent 3AH GelCell as emergency power. You could also do the same with GPS, xponder, etc. In fact the panels might be the same hardware, except for labels. Yea, I know, that's ~~what the ARINC standard used to do on DC-6 era beasts -- remote everything down to the radio bay. One issue you add is the interconnecting wiring as failure points. But if we use flexible fiber jumpers, instead of 18-odd wires, that's a different kettle of fish. Further, if it loses the fiber connectivity, the radio can revert to ?121.5? and preset volume, etc. Now, I don't think anyone will ever do this -- for all the reasons the GA fleet is what it is. But I still think it is a fun engineering dream, at least. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 Back in the "good old days" when I was an avionics tech, they HAD to put things in the back; the equipment was just too big to fit it all behind the panel. The equipment rack in the back of your average Cessna/Piper is no heaven for equipment. It vibrates just as much and it is actually hotter than behind the panel. Remember, there are no vents back there while up front you have cabin vents. Most of the problems with the old MK-12 solid state inverter power supplies and the AT-5 transponders were due to the heat and vibration in the back. Running cables of any kind from the back to behind the panel is also highly labor intensive when done correctly. Basically, you just about have to gut the seats and carpets to get under there and make sure the cables are properly secured and protected so they don't wind up interfering with control mechanisms or getting chaffed in two where they run over all the sharp metal edges down there. Lots of problems turned out to be nothing more than marginal installation of cables under the floor done by somebody on the cheap. The only solution was to rip it all out and replace it correctly. While you could replace a lot of the wiring with a fiber optic data cable, you still have to run power back there and you still have to keep the cables protected and out of the workings. Plus splicing and putting connectors correctly on fiber is a pain in the butt. -- Jim Pennino Remove -spam-sux to reply. |
David Lesher wrote:
writes: Back in the "good old days" when I was an avionics tech, they HAD to put things in the back; the equipment was just too big to fit it all behind the panel. The equipment rack in the back of your average Cessna/Piper is no heaven for equipment. It vibrates just as much and it is actually hotter than behind the panel. Remember, there are no vents back there while up front you have cabin vents. But you can easily have ventilation. You don't need outside air; a few boxer fans will help a great deal. The big thing is you have volume and *access*. The big issue I see is protecting against cokes spilled on/through the seat. Hmmm, more wires to run, more stuff to put in the plane. The equipment didn't go under the rear seat; it went behind the panel behind the bagage compartment. Most of the problems with the old MK-12 solid state inverter power supplies and the AT-5 transponders were due to the heat and vibration in the back. We're talking an order of magnitude more heat in a MK-12 inverter than for a current whole stack, I bet... I seem to recall those even used geranium transistors... Probably slightly less heat, and yes, the transistors were germanium. Can't see why vibration is worse under the rear seat; only that the panel has mounts. So, put stuff on mounts. The vibration is the same; if you wanted it to last you DID put it on mounts. Running cables of any kind from the back to behind the panel is also highly labor intensive when done correctly. Agreed. But one real plus is fiber, even mil-spec "tank-proof" fiber, is tiny as compared to the ahem equine reproductive equipment it replaces here. (I installed LOTS of those in police cars years ago..) The diameter (up to a point) of a cable bundle isn't an issue; it's having to run it at all. And you end up running coax from each antenna, mike/headphone/etc up into a very tight location where you work by feel.... Fiber all avoids ground loops as well. I could see a audio panel with a front panel for control, a knee-level jack panel for mikes/headphones/PTT/CD player in, and a 2nd in the rear for those passengers. You didn't have ground loops back then with wires either if you put stuff in correctly. While you could replace a lot of the wiring with a fiber optic data cable, you still have to run power back there and you still have to keep the cables protected and out of the workings. Plus splicing and putting connectors correctly on fiber is a pain in the butt. I'd buy connectorized flexible duplex jumpers. But yes, you'd need to run power there. Good place for the avionics master contactor. Hmmm, 3 more wires; power in, power out, and control or have 2 separate contactors for the front and rear stuff and avoid the power out? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 -- Jim Pennino Remove -spam-sux to reply. |
Big Bertha Thing blogs | Tony Lance | Owning | 14 | January 19th 05 10:17 PM |
Big Bertha Thing blogs | Tony Lance | Military Aviation | 9 | August 31st 04 11:01 PM |
OSH - the chair thing | Montblack | Owning | 9 | July 24th 03 08:19 PM |
SUV thing | Fastglasair | Home Built | 4 | July 12th 03 05:32 AM |
