In rec.aviation.owning Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com If it is just the suck that has to be tiny and not the pump, how about a toilet paper roll and some duct tape to make an adapter to your shop vac? -- Jim Pennino Remove -spam-sux to reply. |
Because the pump has to fit on a bench that is already overcrowded. If I was
going to use a shopvac, btw, it would be with a pvc waterpipe fitting glued to a barbed fitting with plastic tubing. I thought of that and then the hassle for each part of reaching down to turn the vacuum on for each part you want to seal. Jim shared these priceless pearls of wisdom: -If it is just the suck that has to be tiny and not the pump, how about -a toilet paper roll and some duct tape to make an adapter to your shop -vac? Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 05:53 PM |
NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 04:11 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Fiberglass Vacuum Bagging Technique...Resin Infusion | Steve | Home Built | 5 | August 8th 03 06:10 PM |
