Experimental Instrument Rated?
Old February 7th 04, 07:52 PM
S Green
"Stealth Pilot" wrote in message
On Sat, 07 Feb 2004 03:24:11 GMT, "CFLav8r"
Is it true that an experimental aircraft can not be instrument certified
by
the FAA?
David (KORL)
since the australian rules are a transplant of the american an aussie
answer may be valid.
experimental amateur built aircraft are by default signed off for day
vfr.
IFR requirements are another set of regulations.
If the aircraft meets the requirements of those regulations then the
signoff can be amended to incorporate the necessary endorsements for
IFR.
havent seen ifr in person but I have mediated for an experimental
Thorp T18 being endorsed for night vfr in this country. was easy.
Stealth Pilot
Australia
The UK equivalent of experimental is the "permit to fly". They are limited
to VFR only.
Old February 7th 04, 10:11 PM
Geoff Lane
"S Green" wrote in
limited to VFR only.
It appears that you can do so much more in UK with an FAA PPL in an N-reg
aircraft than you can with a JAA PPL in a G-reg. Also (from this thread) N-
reg experimentals can legally fly over conurbations, at night, and in IMC
(which UK PFA types cannot). So, is it possible to build and maintain an N-
reg experimental in UK? If not, is it possible to import a US homebuilt and
keep it on the N register?
TIA,
Geoff Lane
Cornwall, UK
Old February 8th 04, 10:38 PM
Paul Lee
At least in US many homebuilt ("experimental") are authorized
for IRF. Certified is somewhat a wrong term to use since
experimental aircraft are never type certified for any flight.
I am just in process of getting a homebuilt checked out
by FAA for airworthiness. It is on the airworthiness operating
limitations that the FAA indicates whether the aircraft is
authorized for VFR day, night or IFR - at the time of inspection.
If you ever attend Oshkosh, go to the FAA booth and have all your
questions aswered.
Paul Lee, SQ2000 canard project: http://www.abri.com/sq2000
"CFLav8r" wrote in message m...
Is it true that an experimental aircraft can not be instrument certified by
the FAA?
David (KORL)
Old February 9th 04, 03:34 PM
Ron Natalie
"CFLav8r" wrote in message ...
the FAA?
Most homebuilts get a clause in their operating limitations that say they can be
flown IFR provided they are equipped by the regs.
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 02:11 PM
