Talk me out of this...
Old February 9th 04, 04:09 AM
Paul Folbrecht
Yeah, the winds worked against me both ways. A bit annoying. I am
totally going to write a complaint letter to the NWS.
So was this one of your XCs? Dual?
Chris Hoffmann wrote:
You ain't kidding about the winds. They were from 250 when I was planning at
around 3 o'clock - by 3:30 they'd spun round to 200. Statrted double
checking my planning when it was obvious we were heading northwest instead
of northeast. 138 kts out - 78 kts back. Ouch.
  #52
Old February 9th 04, 06:59 AM
Chris Hoffmann
This was sort of a "refresher" - I did both duals back in October, so we're
just catching up a bit before I take the phase check. Planned out a flight
to Manitowoc, but we didn't go much past West Bend. With the low ceilings
and winds, I was just fine with that.
Heh, SVFR practice? Not quite...
"Paul Folbrecht" wrote in message
link.net...
planning at
instead
  #53
Old February 9th 04, 11:02 AM
Abafon Goula
On Mon, 09 Feb 2004 02:17:20 GMT, Paul Folbrecht
8. Unless you fly regularly (200 hours a year) you'll never
cost-justify the purchase vs. renting, so take that out of the
equation.
Your advice is being considered, sir. As to your last point- I'm a bit
curious about that as I normally see a lower number brandied about as
the break-even.
All those hidden pop-up things that can't be put down on paper. And
don't think for one minute you'll be satisfied once you own it.
You'll want to make it the best damn airplane in the GA fleet!
And don't stick a fork in the toaster.
  #54
Old February 9th 04, 12:50 PM
Jay Honeck
at
We flew back from WI yesterday. Winds aloft 230 at 55.
Ground speed on the GPS: 88 knots.
Our plane normally does 140 knots.
It was a loooong flight... :-(
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #55
Old February 9th 04, 01:56 PM
If you're interested in 150's, send me an email. I've got a two pretty good
leads here in Central Wis.
Jim Burns III
Remove "nospam" to reply
  #56
Robert A. Barker
hlink.net...
Bob.. did I by any chance chat w/you at the EAA museum a couple months
ago??
Nope I wasn't there.
Bob
  #57
Old February 9th 04, 04:05 PM
Nathan Young
On Mon, 09 Feb 2004 02:10:04 GMT, Paul Folbrecht
Well, a new 235 is about $20K, and I'd thought a major overhaul was
about half that, but apparantly I was wrong given the number of people
in this thread who're telling me I am.
Jeff wrote:
sounds like that engine is about due a overhaul.
I dont know what an engine costs for a 152, but you may want to check on
that so you know about how much your going to have to invest in the new
engine.
Factoryengines.com lists O-235s for 15.2k, 17.9k, and 22.5k (overhaul,
remanufactured, and new respectively). Plus, you will have install
costs and have accessories to overhaul or replace. You could hit $20k
easily for an installed overhauled engine.
-Nathan
  #58
Old February 9th 04, 06:00 PM
Jim Weir
If fuel economy is your goal, then let me do some math for you.
Let's presume you want to put, oh, say 500 hours on this rascal before you trade
up. Let's also presume you go at 6 gallons/hour. This means that in 500 hours
you will burn about 3000 gallons of fuel.
In a 150, you can burn autogas at $1.50 a gallon for a total cost of $4500.
In a 152 you have to burn 100(LL) at $2.50 a gallon for a total cost of $7500.
Factor the extra $3 grand into your equation.
Paul Folbrecht
I had actually been drawn to
-150s/152s because of the fuel economy
http://www.rst-engr.com
  #59
Old February 9th 04, 06:08 PM
Jim Weir
About To Be New Plane Owner:
HEAR THIS. HEAR THIS if I have to repeat it ten thousand times. You can
legally DO ANYTHING yourself. **ANYTHING**. You just can't sign it off. If
you can find a mechanic willing to oversee your work, you can do ANYTHING.
Got it?
Paul Folbrecht
-$250 for an oil change?! Now, that's something I can legally do myself-
-why on earth would I pay that for it.
  #60
Old February 9th 04, 06:13 PM
G.R. Patterson III
Or you can get an auto gas STC from either Petersen or the EAA. The EAA page notes
that modifications to the engine are required; even so, it's going to be cheaper
than running avgas.
George Patterson
Love, n.: A form of temporary insanity afflicting the young. It is curable
either by marriage or by removal of the afflicted from the circumstances
under which he incurred the condition. It is sometimes fatal, but more
often to the physician than to the patient.
Want to talk with Eggenfellner customers Ed Wischmeyer Home Built 3 December 19th 04 04:20 PM
Radio talk in the UK Paul General Aviation 36 March 8th 04 10:57 PM
Can we talk about the Randolph problem? Michael Horowitz Home Built 5 October 30th 03 04:44 PM
Thunderbirds members to talk about flight history Otis Willie Military Aviation 0 August 20th 03 04:13 AM
crazy talk - 320 into a 360 application? [email protected] Owning 1 August 6th 03 03:32 PM
Copyright Š2004-2025 AviationBanter.
