On Mon, 09 Feb 2004 02:10:04 GMT, Paul Folbrecht
wrote: Well, a new 235 is about $20K, and I'd thought a major overhaul was about half that, but apparantly I was wrong given the number of people in this thread who're telling me I am. Jeff wrote: sounds like that engine is about due a overhaul. I dont know what an engine costs for a 152, but you may want to check on that so you know about how much your going to have to invest in the new engine. Factoryengines.com lists O-235s for 15.2k, 17.9k, and 22.5k (overhaul, remanufactured, and new respectively). Plus, you will have install costs and have accessories to overhaul or replace. You could hit $20k easily for an installed overhauled engine. -Nathan |
So that $15.2K is for a remanufactured engine or to remanufacture _your_
engine?? Cause I thought doing the latter (tearing it down and replacing most of the parts) was the 'usual' method, and I thought (had been told) that around $10K for everything for a 235 was about right. (No, not told by the FBO that's selling the plane.) Factoryengines.com lists O-235s for 15.2k, 17.9k, and 22.5k (overhaul, remanufactured, and new respectively). Plus, you will have install costs and have accessories to overhaul or replace. You could hit $20k easily for an installed overhauled engine. -Nathan |
On Tue, 10 Feb 2004 02:43:34 GMT, Paul Folbrecht
wrote: So that $15.2K is for a remanufactured engine or to remanufacture _your_ engine?? Cause I thought doing the latter (tearing it down and replacing most of the parts) was the 'usual' method, and I thought (had been told) that around $10K for everything for a 235 was about right. (No, not told by the FBO that's selling the plane.) Factoryengines.com lists O-235s for 15.2k, 17.9k, and 22.5k (overhaul, remanufactured, and new respectively). Plus, you will have install costs and have accessories to overhaul or replace. You could hit $20k easily for an installed overhauled engine. Factoryengines usually has pretty good prices, but I was surprised about the $15k for a O-235 overhaul. I have a O-360 in my Cherokee, and its overhaul is only $13.8k. Regarding the differences between overhauls - I'm not an expert at this by any means, but here's my take... Overhauled engine: Engine parts are replaced or reworked as necessary to be within overhaul limits. You need to be careful about what type of overhaul is specified. There are two main kinds of overhauls, service limits, and new limits. Service limits are the absolute minimums as specified by the engine manufacturer (a bad idea in my opinion). There are also overhauls to new limits, ie the components of the engine have the same tolerances as a new engine. Either way, the engine comes out with the same logbook, and total time is not reset. It is however 0 hours since major overhaul. Blueprinted engines: There are speciality shops that match/balance components to provide a smoother and more powerful engine. These typically cost more than a regular overhaul, and perhaps more than a remanufactured engine. Regardless, the engine will not be zero timed. It is essentially an overhaul to super-specifications. Remanufactured. Engine components are reworked/replaced to new limits. Engine is issued a new logbook and is 0 TT / 0 SMOH. Many question the value of the reman besides having a zerotimed logbook. New engine: This the easy one. It is brand new from Lycoming. O TT, 0 TSMOH. Avweb has a good article on engine overhauls: http://www.avweb.com/news/maint/182826-1.html -Nathan |
![]() Paul Folbrecht wrote: So that $15.2K is for a remanufactured engine or to remanufacture _your_ engine?? Cause I thought doing the latter (tearing it down and replacing most of the parts) was the 'usual' method, and I thought (had been told) that around $10K for everything for a 235 was about right. That outfit will sell you an overhauled engine for $15.2K. You will have to remove yours, install theirs, and send them yours as a "core". You re-use all the old peripherals, such as the carb, alternator, etc.. There are lots of extra goodies that you should replace at this time, such as the cooling baffle material. Now, an overhauled engine is one in which the engine is disassembled, every part is checked to make sure it meets the specs for *return to service*, and the engine is put back together with any part that doesn't meet those specs replaced with one that is *serviceable*. A remanufactured engine is one in which every part meets the specs for a *new* part, not just a *serviceable* one. A new engine is just that. What you're describing is generally referred to as a "field overhaul". There are pluses and minuses to doing it this way. If the mech is good and you opt for replacing unserviceable parts with new ones, you can wind up with a better engine than swapping for a major shop overhauled engine, but if you do that, it'll likely cost you in the 15K range anyway. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
Want to talk with Eggenfellner customers | Ed Wischmeyer | Home Built | 3 | December 19th 04 04:20 PM |
Radio talk in the UK | Paul | General Aviation | 36 | March 8th 04 10:57 PM |
Can we talk about the Randolph problem? | Michael Horowitz | Home Built | 5 | October 30th 03 04:44 PM |
Thunderbirds members to talk about flight history | Otis Willie | Military Aviation | 0 | August 20th 03 04:13 AM |
crazy talk - 320 into a 360 application? | [email protected] | Owning | 1 | August 6th 03 03:32 PM |
